Dear support,
I'm using the NFC pairing on SDK 15.0.0 on PC10056 PDK. I install the micro-ecc library and the example works.
First question: The coupling between smartphone and NFC antenna provided with PDK board is very hard and complex, the the pairing fails very often. Find the right position to have a good NFC connection is very difficult and a little misalignment has result on fails NFC connection.
Second question: I will try NFC pairing also with SDK 15.2.0, but I'm not be able to compile the project: I have some errors on many include files (here above a screen that shows a sample)
Where I wrong? Can you help me?
Many thanks in advance
