hi,
I am compiling nrf52840 light switch sample code in an embedded studio, I am getting the error as extern "C" {: Invalid argument, how to get out of this
hi,
Copy & paste the complete error message.
Also the piece of code to which it relates.
Tell us where that code came from - and have you modified it?
How to post source code:
Building ‘light_switch_proxy_server_nrf52840_xxAA_s140_6.0.0’ from solution ‘light_switch_proxy_server_nrf52840_xxAA_s140_6.0.0’ in configuration ‘Debug’
Compiling ‘mesh_provisionee.c’
Compiling ‘app_onoff.c’
Compiling ‘rtt_input.c’
Compiling ‘simple_hal.c’
boards.h: No such file or directory
Build failed
/* Copyright (c) 2010 - 2018, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
#include <stdint.h>
#include <string.h>
/* HAL */
#include "boards.h"
#include "simple_hal.h"
#include "app_timer.h"
/* Core */
#include "sdk_config.h"
#include "nrf_mesh_configure.h"
#include "nrf_mesh.h"
#include "mesh_stack.h"
#include "device_state_manager.h"
#include "access_config.h"
#include "net_state.h"
#include "mesh_adv.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "ble_conn_params.h"
#include "ble_hci.h"
#include "proxy.h"
#include "mesh_opt_gatt.h"
#include "mesh_config.h"
/* Provisioning and configuration */
#include "mesh_provisionee.h"
#include "mesh_app_utils.h"
#include "mesh_softdevice_init.h"
/* Models */
#include "generic_onoff_server.h"
/* Logging and RTT */
#include "log.h"
#include "rtt_input.h"
/* Example specific includes */
#include "app_config.h"
#include "example_common.h"
#include "nrf_mesh_config_examples.h"
#include "light_switch_example_common.h"
#include "app_onoff.h"
#define ONOFF_SERVER_0_LED (BSP_LED_0)
#define DEVICE_NAME "nRF5x Mesh Light"
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(150, UNIT_1_25_MS) /**< Minimum acceptable connection interval. */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(250, UNIT_1_25_MS) /**< Maximum acceptable connection interval. */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(100) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called. */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(2000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call. */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
static bool m_device_provisioned;
static void gap_params_init(void);
static void conn_params_init(void);
static void app_onoff_server_set_cb(const app_onoff_server_t * p_server, bool onoff);
static void app_onoff_server_get_cb(const app_onoff_server_t * p_server, bool * p_present_onoff);
/* Generic OnOff server structure definition and initialization */
APP_ONOFF_SERVER_DEF(m_onoff_server_0,
APP_CONFIG_FORCE_SEGMENTATION,
APP_CONFIG_MIC_SIZE,
app_onoff_server_set_cb,
app_onoff_server_get_cb)
/* Callback for updating the hardware state */
/* Resolve the server instance here if required, this example uses only 1 instance. */
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Setting GPIO value: %d\n", onoff)
hal_led_pin_set(ONOFF_SERVER_0_LED, onoff);
/* Callback for reading the hardware state */
*p_present_onoff = hal_led_pin_get(ONOFF_SERVER_0_LED);
static void app_model_init(void)
/* Instantiate onoff server on element index 0 */
ERROR_CHECK(app_onoff_init(&m_onoff_server_0, 0));
static void on_sd_evt(uint32_t sd_evt, void * p_context)
(void) nrf_mesh_on_sd_evt(sd_evt);
NRF_SDH_SOC_OBSERVER(mesh_observer, NRF_SDH_BLE_STACK_OBSERVER_PRIO, on_sd_evt, NULL);
static void node_reset(void)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- Node reset -----\n");
hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_RESET);
/* This function may return if there are ongoing flash operations. */
mesh_stack_device_reset();
static void config_server_evt_cb(const config_server_evt_t * p_evt)
if (p_evt->type == CONFIG_SERVER_EVT_NODE_RESET)
node_reset();
static void button_event_handler(uint32_t button_number)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Button %u pressed\n", button_number);
switch (button_number)
/* Pressing SW1 on the Development Kit will result in LED state to toggle and trigger
the STATUS message to inform client about the state change. This is a demonstration of
state change publication due to local event. */
case 0:
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "User action \n");
hal_led_pin_set(ONOFF_SERVER_0_LED, !hal_led_pin_get(ONOFF_SERVER_0_LED));
app_onoff_status_publish(&m_onoff_server_0);
/* Initiate node reset */
case 3:
/* Clear all the states to reset the node. */
if (mesh_stack_is_device_provisioned())
(void) proxy_stop();
mesh_stack_config_clear();
node_reset();
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "The device is unprovisioned. Resetting has no effect.\n");
static void app_rtt_input_handler(int key)
if (key >= '0' && key <= '4')
uint32_t button_number = key - '0';
button_event_handler(button_number);
uint32_t err_code;
err_code = sd_ble_gap_disconnect(p_evt->conn_handle, BLE_HCI_CONN_INTERVAL_UNACCEPTABLE);
else if (p_evt->evt_type == BLE_CONN_PARAMS_EVT_SUCCEEDED)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Successfully updated connection parameters\n");
APP_ERROR_HANDLER(nrf_error);
static void provisioning_complete_cb(void)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Successfully provisioned\n");
/* Restores the application parameters after switching from the Provisioning service to the Proxy */
gap_params_init();
conn_params_init();
dsm_local_unicast_address_t node_address;
dsm_local_unicast_addresses_get(&node_address);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Node Address: 0x%04x \n", node_address.address_start);
hal_led_mask_set(LEDS_MASK, false);
hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_PROV);
static void models_init_cb(void)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Initializing and adding models\n");
app_model_init();
static void mesh_init(void)
uint8_t dev_uuid[NRF_MESH_UUID_SIZE];
uint8_t node_uuid_prefix[NODE_UUID_PREFIX_LEN] = SERVER_NODE_UUID_PREFIX;
ERROR_CHECK(mesh_app_uuid_gen(dev_uuid, node_uuid_prefix, NODE_UUID_PREFIX_LEN));
mesh_stack_init_params_t init_params =
.core.irq_priority = NRF_MESH_IRQ_PRIORITY_LOWEST,
.core.lfclksrc = DEV_BOARD_LF_CLK_CFG,
.core.p_uuid = dev_uuid,
.models.models_init_cb = models_init_cb,
.models.config_server_cb = config_server_evt_cb
ERROR_CHECK(mesh_stack_init(&init_params, &m_device_provisioned));
uint32_t err_code;
strlen(DEVICE_NAME));
uint32_t err_code;
ble_gap_conn_params_t gap_conn_params;
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
cp_init.p_conn_params = &gap_conn_params;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
static void initialize(void)
__LOG_INIT(LOG_SRC_APP | LOG_SRC_ACCESS | LOG_SRC_BEARER, LOG_LEVEL_INFO, LOG_CALLBACK_DEFAULT);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Light Switch Proxy Server Demo -----\n");
ERROR_CHECK(app_timer_init());
hal_leds_init();
//#if BUTTON_BOARD
ERROR_CHECK(hal_buttons_init(button_event_handler));
//#endif
uint32_t err_code = nrf_sdh_enable_request();
//#if defined S140 // todo remove that after S140 priority fixing
softdevice_irq_priority_checker();
//#endif
uint32_t ram_start = 0;
/* Set the default configuration (as defined through sdk_config.h). */
err_code = nrf_sdh_ble_default_cfg_set(MESH_SOFTDEVICE_CONN_CFG_TAG, &ram_start);
gap_params_init();
conn_params_init();
mesh_init();
static void start(void)
rtt_input_enable(app_rtt_input_handler, RTT_INPUT_POLL_PERIOD_MS);
ERROR_CHECK(mesh_stack_start());
if (!m_device_provisioned)
static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
mesh_provisionee_start_params_t prov_start_params =
.p_static_data = static_auth_data,
.prov_complete_cb = provisioning_complete_cb,
.p_device_uri = NULL
ERROR_CHECK(mesh_provisionee_prov_start(&prov_start_params));
const uint8_t *p_uuid = nrf_mesh_configure_device_uuid_get();
__LOG_XB(LOG_SRC_APP, LOG_LEVEL_INFO, "Device UUID ", p_uuid, NRF_MESH_UUID_SIZE);
initialize();
execution_start(start);
for (;;)
(void)sd_app_evt_wait();
it is nrf sdk mesh (light switch code), when I compile first time,some header files are missing, then I added those header files, next these errors -
That's not the complete message - the complete message would include the file name and line number at which the problem was detected.
nrf sdk mesh
What version?
And what version of SDK?
it is nrf5_SDK_for_Mesh_v2.2.0_src, and nRF5_SDK_15.2.0_9412b96,actually it is not showing any error at particular line, C file name is ‘mesh_provisionee.c’,and showing error like
