hi....
i am facing the problem , after debugging the program is not running,run option is disable , i couldn't able to do start code execution .. see the pic below
i am using keil version ..sdk12.3 ..
hi....
Click the on run button to start the code. See this page.
If this is a BLE example, make sure that you have programmed the SoftDevice.
i clicked but the run option is disable
In the screenshot you posted, it seems like you have not pushed the button yet? Could you post a screenshot on how it looks like after you click the button?
yes .... while i am pressing the run button
i am getting fatal error in include chain(sdk_errors.h):'sdk_config.h' file not found
If you are running into the error-handler, then please see this guide on how to debug and find the error code.
