I have read through this tutorials on how to develop custom UUID, and I have implemented it successfully.
But I need to have 2 characteristics. I have basically duplicated the codes for the custom UUID in order to have 2 characteristics.
I am not sure that is the way to do it.
When I compile, there is no error but I am not able to see the second characteristics on the nRF Connect.
Below is snippet of the code for ble_cus.h
// CUSTOM_SERVICE_UUID_BASE f364adc9-b000-4042-ba50-05ca45bf8abc : ADC9 taken as the 16bit Serivice. Added 1 to have the characteristics #define CUSTOM_SERVICE_UUID_BASE {0xBC, 0x8A, 0xBF, 0x45, 0xCA, 0x05, 0x50, 0xBA, \ 0x42, 0x40, 0x00, 0xB0, 0xC9, 0xAD, 0x64, 0xF3} #define CUSTOM_SERVICE_UUID 0xADC9 #define CUSTOM_VALUE_CHAR_UUID 0xADCA #define CUSTOM_VALUE2_CHAR_UUID 0xADCB /**<Added for second characteristics, and increased NRF_SDH_BLE_VS_UUID_COUNT to 2 but it didn't advertise*/ /**@brief Custom Service event type. */ typedef enum { BLE_CUS_EVT_NOTIFICATION_ENABLED, /**< Custom value notification enabled event. */ BLE_CUS_EVT_NOTIFICATION_DISABLED, /**< Custom value notification disabled event. */ BLE_CUS_EVT_DISCONNECTED, BLE_CUS_EVT_CONNECTED } ble_cus_evt_type_t; /**@brief Custom Service event. */ typedef struct { ble_cus_evt_type_t evt_type; /**< Type of event. */ } ble_cus_evt_t; // Forward declaration of the ble_cus_t type. typedef struct ble_cus_s ble_cus_t; /**@brief Custom Service event handler type. */ typedef void (*ble_cus_evt_handler_t) (ble_cus_t * p_bas, ble_cus_evt_t * p_evt); /**@brief Battery Service init structure. This contains all options and data needed for * initialization of the service.*/ typedef struct { ble_cus_evt_handler_t evt_handler; /**< Event handler to be called for handling events in the Custom Service. */ uint8_t initial_custom_value; /**< Initial custom value */ ble_srv_cccd_security_mode_t custom_value_char_attr_md; /**< Initial security level for first Custom characteristics attribute */ ble_srv_cccd_security_mode_t custom_value2_char_attr_md; /**< Initial security level for second Custom characteristics attribute */ } ble_cus_init_t; /**@brief Custom Service structure. This contains various status information for the service. */ struct ble_cus_s { ble_cus_evt_handler_t evt_handler; /**< Event handler to be called for handling events in the Custom Service. */ uint16_t service_handle; /**< Handle of Custom Service (as provided by the BLE stack). */ ble_gatts_char_handles_t custom_value_handles; /**< Handles related to the Custom Value first characteristic. */ ble_gatts_char_handles_t custom_value2_handles; /**< Handles related to the Custom Value second characteristic. */ uint16_t conn_handle; /**< Handle of the current connection (as provided by the BLE stack, is BLE_CONN_HANDLE_INVALID if not in a connection). */ uint8_t uuid_type; }; /**@brief Function for initializing the Custom Service. * * @param[out] p_cus Custom Service structure. This structure will have to be supplied by * the application. It will be initialized by this function, and will later * be used to identify this particular service instance. * @param[in] p_cus_init Information needed to initialize the service. * * @return NRF_SUCCESS on successful initialization of service, otherwise an error code. */ uint32_t ble_cus_init(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init); /**@brief Function for handling the Application's BLE Stack events. * * @details Handles all events from the BLE stack of interest to the Battery Service. * * @note * * @param[in] p_cus Custom Service structure. * @param[in] p_ble_evt Event received from the BLE stack. */ void ble_cus_on_ble_evt( ble_evt_t const * p_ble_evt, void * p_context); /**@brief Function for updating the custom value. * * @details The application calls this function when the cutom value should be updated. If * notification has been enabled, the custom value characteristic is sent to the client. * * @note * * @param[in] p_bas Custom Service structure. * @param[in] Custom value * * @return NRF_SUCCESS on success, otherwise an error code. */ uint32_t ble_cus_custom_value_update(ble_cus_t * p_cus, uint8_t custom_value); uint32_t ble_cus_custom_value2_update(ble_cus_t * p_cus, uint8_t custom_value2); #endif // BLE_CUS_H__
I also tried to change the NRF_SDH_BLE_VS_UUID_COUNT from 1 to 2 but instead the DK does not advertise.
I appreciate any guide to resolving this. Thanks.
