PPK v1.1.0 with nRF Connect v2.6.0 issue
Hi
I installed nRFConnect v2.6 and command line v9.8.1 and want to use PPK to measure current.
When first connect, it will update FW into PPK and works well to measure.
But when I adjust "Voltage regulator" after swtich SW2 (External) and SW4 (Reg) then I got below item issues.
1. I adjusted 2V on voltage regulator, the output voltage is ~2V on P16 (External DUT)
2. I adjusted < 2V on voltage regulator, the output voltage is 2.1~2.2V on P16 (External DUT). Why?
3. When I adjust the scroll bar on voltage regulator many times, it will get error message on nRFConnect and PPK cannot connect with nRF Connect v2.6.0 any more.
    I tried to erase PPK FW and reprogrammed but PPK still cannot connect to nRF Connect v2.6.0
   But PPK can connect with nRF Connect v2.4.0. Why?
 Please refer attach picture and help to check item 2 and 3 issues.
Thanks.
BR
Atlas
