Hi
I was trying to do the page up and down key, I just built it successfully but it is no response.
Could anyone find out the reason for me.
I appreciate for your assistance.
/* Copyright (c) 2012 Nordic Semiconductor. All Rights Reserved.
* The information contained herein is property of Nordic Semiconductor ASA.
* Terms and conditions of usage are described in detail in NORDIC
* SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
* Licensees are granted free, non-transferable use of the information. NO
* WARRANTY of ANY KIND is provided. This heading must NOT be removed from
* the file.
/** @file
* @defgroup ble_sdk_app_hids_keyboard_main main.c
* @ingroup ble_sdk_app_hids_keyboard
* @brief HID Keyboard Sample Application main file.
* This file contains is the source code for a sample application using the HID, Battery and Device
* Information Services for implementing a simple keyboard functionality.
* Pressing Button 0 will send text 'hello' to the connected peer. On receiving output report,
* it toggles the state of LED 2 on the mother board based on whether or not Caps Lock is on.
* This application uses the @ref app_scheduler.
* Also it would accept pairing requests from any peer device.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "nrf_assert.h"
#include "app_error.h"
#include "nrf_gpio.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advertising.h"
#include "ble_advdata.h"
#include "ble_hids.h"
#include "ble_conn_params.h"
#include "bsp.h"
#include "bsp_btn_ble.h"
#include "app_scheduler.h"
#include "softdevice_handler_appsh.h"
#include "app_timer_appsh.h"
#include "device_manager.h"
#include "app_button.h"
#include "pstorage.h"
#include "app_trace.h"
#if BUTTONS_NUMBER <2
#error "Not enough resources on board"
#define PAGE_UP BSP_BUTTON_2
#define PAGE_DOWN BSP_BUTTON_3
#define IS_SRVC_CHANGED_CHARACT_PRESENT 0 /**< Include or not the service_changed characteristic. if not enabled, the server's database cannot be changed for the lifetime of the device*/
#define CENTRAL_LINK_COUNT 0 /**< Number of central links used by the application. When changing this number remember to adjust the RAM settings*/
#define PERIPHERAL_LINK_COUNT 1 /**< Number of peripheral links used by the application. When changing this number remember to adjust the RAM settings*/
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 1 /**< UART RX buffer size. */
#define KEY_PRESS_BUTTON_ID 0 /**< Button used as Keyboard key press. */
#define SHIFT_BUTTON_ID 1 /**< Button used as 'SHIFT' Key. */
#define DEVICE_NAME "PEN" /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME "WEDY" /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_TIMER_PRESCALER 0 /**< Value of the RTC1 PRESCALER register. */
#define APP_TIMER_OP_QUEUE_SIZE 4 /**< Size of timer operation queues. */
#define BATTERY_LEVEL_MEAS_INTERVAL APP_TIMER_TICKS(2000, APP_TIMER_PRESCALER) /**< Battery level measurement interval (ticks). */
#define MIN_BATTERY_LEVEL 81 /**< Minimum simulated battery level. */
#define MAX_BATTERY_LEVEL 100 /**< Maximum simulated battery level. */
#define BATTERY_LEVEL_INCREMENT 1 /**< Increment between each simulated battery level measurement. */
#define APP_ADV_FAST_INTERVAL 0x0028 /**< Fast advertising interval (in units of 0.625 ms. This value corresponds to 25 ms.). */
#define APP_ADV_SLOW_INTERVAL 0x0C80 /**< Slow advertising interval (in units of 0.625 ms. This value corrsponds to 2 seconds). */
#define APP_ADV_FAST_TIMEOUT 30 /**< The duration of the fast advertising period (in seconds). */
#define APP_ADV_SLOW_TIMEOUT 180 /**< The duration of the slow advertising period (in seconds). */
/*lint -emacro(524, MIN_CONN_INTERVAL) // Loss of precision */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(7.5, UNIT_1_25_MS) /**< Minimum connection interval (7.5 ms) */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(30, UNIT_1_25_MS) /**< Maximum connection interval (30 ms). */
#define SLAVE_LATENCY 6 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(430, UNIT_10_MS) /**< Connection supervisory timeout (430 ms). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
//11/14 wedy add for button control
#define BUTTON_DETECTION_DELAY APP_TIMER_TICKS(50, APP_TIMER_PRESCALER)
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
#define OUTPUT_REPORT_INDEX 0 /**< Index of Output Report. */
#define OUTPUT_REPORT_MAX_LEN 5 /**< Maximum length of Output Report. */
#define INPUT_REPORT_KEYS_INDEX 0 /**< Index of Input Report. */
#define OUTPUT_REPORT_BIT_MASK_CAPS_LOCK 0x02 /**< CAPS LOCK bit in Output Report (based on 'LED Page (0x08)' of the Universal Serial Bus HID Usage Tables). */
#define INPUT_REP_REF_ID 0 /**< Id of reference to Keyboard Input Report. */
#define OUTPUT_REP_REF_ID 0 /**< Id of reference to Keyboard Output Report. */
//Wedy 11/14 add for other report
#define INPUT_REPORT_COUNT 1
#define APP_FEATURE_NOT_SUPPORTED BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2 /**< Reply when unsupported features are requested. */
#define MAX_BUFFER_ENTRIES 5 /**< Number of elements that can be enqueued */
#define BASE_USB_HID_SPEC_VERSION 0x0101 /**< Version number of base USB HID Specification implemented by this application. */
#define INPUT_REPORT_KEYS_MAX_LEN 2 /**< Maximum length of the Input Report characteristic. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define SCHED_MAX_EVENT_DATA_SIZE MAX(APP_TIMER_SCHED_EVT_SIZE,\
BLE_STACK_HANDLER_SCHED_EVT_SIZE) /**< Maximum size of scheduler events. */
#define SCHED_QUEUE_SIZE 10 /**< Maximum number of events in the scheduler queue. */
#define MODIFIER_KEY_POS 0 /**< Position of the modifier byte in the Input Report. */
#define SCAN_CODE_POS 2 /**< This macro indicates the start position of the key scan code in a HID Report. As per the document titled 'Device Class Definition for Human Interface Devices (HID) V1.11, each report shall have one modifier byte followed by a reserved constant byte and then the key scan code. */
#define SHIFT_KEY_CODE 0x02 /**< Key code indicating the press of the Shift Key. */
#define MAX_KEYS_IN_ONE_REPORT (INPUT_REPORT_KEYS_MAX_LEN - SCAN_CODE_POS) /**< Maximum number of key presses that can be sent in one Input Report. */
typedef enum
BLE_NO_ADV, /**< No advertising running. */
BLE_DIRECTED_ADV, /**< Direct advertising to the latest central. */
BLE_FAST_ADV_WHITELIST, /**< Advertising with whitelist. */
BLE_FAST_ADV, /**< Fast advertising running. */
BLE_SLOW_ADV, /**< Slow advertising running. */
BLE_SLEEP, /**< Go to system-off. */
} ble_advertising_mode_t;
/** Abstracts buffer element */
typedef struct hid_key_buffer
uint8_t data_offset; /**< Max Data that can be buffered for all entries */
uint8_t data_len; /**< Total length of data */
uint8_t * p_data; /**< Scanned key pattern */
ble_hids_t * p_instance; /**< Identifies peer and service instance */
}buffer_entry_t;
STATIC_ASSERT(sizeof(buffer_entry_t) % 4 == 0);
/** Circular buffer list */
typedef struct
buffer_entry_t buffer[MAX_BUFFER_ENTRIES]; /**< Maximum number of entries that can enqueued in the list */
uint8_t rp; /**< Index to the read location */
uint8_t wp; /**< Index to write location */
uint8_t count; /**< Number of elements in the list */
}buffer_list_t;
STATIC_ASSERT(sizeof(buffer_list_t) % 4 == 0);
static ble_hids_t m_hids; /**< Structure used to identify the battery service. */
static bool m_in_boot_mode = false; /**< Current protocol mode. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static dm_application_instance_t m_app_handle; /**< Application identifier allocated by device manager. */
static dm_handle_t m_bonded_peer_handle; /**< Device reference handle to the current bonded central. */
static bool m_caps_on = false; /**< Variable to indicate if Caps Lock is turned on. */
static ble_uuid_t m_adv_uuids[] = {{BLE_UUID_HUMAN_INTERFACE_DEVICE_SERVICE, BLE_UUID_TYPE_BLE}};
//Wedy 11/14 add for pen control
typedef enum
RELEASE_KEY = 0x00,
PEN_UP = 0x01,
PEN_DOWN = 0x02,
} pen_control_t;
/** List to enqueue not just data to be sent, but also related information like the handle, connection handle etc */
static buffer_list_t buffer_list;
static void on_hids_evt(ble_hids_t * p_hids, ble_hids_evt_t * p_evt);
/**@brief Callback function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] file_name File name of the failing ASSERT call.
/**@brief Function for handling Service errors.
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
static void service_error_handler(uint32_t nrf_error)
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling advertising errors.
static void ble_advertising_error_handler(uint32_t nrf_error)
/**@brief Function for the Timer initialization.
* @details Initializes the timer module.
static void timers_init(void)
uint32_t err_code;
// Initialize timer module, making it use the scheduler.
APP_TIMER_APPSH_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, true);
* @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
* device including the device name, appearance, and the preferred connection parameters.
uint32_t err_code;
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_HID_KEYBOARD);
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
/**@brief Function for initializing HID Service.
static void hids_init(void)
uint32_t err_code;
ble_hids_init_t hids_init_obj;
ble_hids_inp_rep_init_t input_report_array[1];
ble_hids_inp_rep_init_t * p_input_report;
ble_hids_outp_rep_init_t output_report_array[1];
ble_hids_outp_rep_init_t * p_output_report;
uint8_t hid_info_flags;
memset((void *)input_report_array, 0, sizeof(ble_hids_inp_rep_init_t));
memset((void *)output_report_array, 0, sizeof(ble_hids_outp_rep_init_t));
static uint8_t report_map_data[] =
//Wedy 11/13 to simulate the project
//Report ID 1: BT
0x05, 0x01, // Usage Page (Generic Desktop)
0x09, 0x06, // Usage (Keyboard)
0xA1, 0x01, // Collection: (Application)
0x85, 0x01, // Report ID(1) simulate project
0x05, 0x07, // Usage Page (Key Codes/ Keyboard)
0x09, 0x4B, // USAGE(Page Up Key) //0x08
0x09, 0x4E, // USAGE(Page Down Key) //0x10
0x09, 0xE3, // USAGE(Left Windows Key) //0x20
0x15, 0x00, // LOGICAL_MINIMUM(0) //range of the value
0x25, 0x01, // LOGICAL_MAXIMUM(1) //range of the value
0x75, 0x01, // REPORT_SIZE(1) //1 bit
0x95, 0x05, // REPORT_COUNT(2) // just 1 item = 2 bit
0x81, 0x02, // INPUT (Data, Var, Abs)
0x95, 0x03, // REPORT_COUNT(3)
0x81, 0x03, // INPUT(Cnst, Var, Abs)
0xC0 // End Collection ->41byte
// Initialize HID Service
p_input_report = &input_report_array[INPUT_REPORT_KEYS_INDEX];
p_input_report->max_len = INPUT_REPORT_KEYS_MAX_LEN;
p_input_report->rep_ref.report_id = INPUT_REP_REF_ID;
p_input_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_INPUT;
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_input_report->security_mode.cccd_write_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_input_report->security_mode.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_input_report->security_mode.write_perm);
p_output_report = &output_report_array[OUTPUT_REPORT_INDEX];
p_output_report->max_len = OUTPUT_REPORT_MAX_LEN;
p_output_report->rep_ref.report_id = OUTPUT_REP_REF_ID;
p_output_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_OUTPUT;
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_output_report->security_mode.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_output_report->security_mode.write_perm);
hid_info_flags = HID_INFO_FLAG_REMOTE_WAKE_MSK | HID_INFO_FLAG_NORMALLY_CONNECTABLE_MSK;
memset(&hids_init_obj, 0, sizeof(hids_init_obj));
hids_init_obj.evt_handler = on_hids_evt;
hids_init_obj.error_handler = service_error_handler;
hids_init_obj.is_kb = true;
hids_init_obj.is_mouse = false;
hids_init_obj.inp_rep_count = INPUT_REPORT_COUNT; //Wedy note 11/14 add for other report but it won't start the LED scanning
hids_init_obj.p_inp_rep_array = input_report_array;
hids_init_obj.outp_rep_count = 1;
hids_init_obj.p_outp_rep_array = output_report_array;
hids_init_obj.feature_rep_count = 0;
hids_init_obj.p_feature_rep_array = NULL;
hids_init_obj.rep_map.data_len = sizeof(report_map_data);
hids_init_obj.rep_map.p_data = report_map_data;
hids_init_obj.hid_information.bcd_hid = BASE_USB_HID_SPEC_VERSION;
hids_init_obj.hid_information.b_country_code = 0;
hids_init_obj.hid_information.flags = hid_info_flags;
hids_init_obj.included_services_count = 0;
hids_init_obj.p_included_services_array = NULL;
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.rep_map.security_mode.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.rep_map.security_mode.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.hid_information.security_mode.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.hid_information.security_mode.write_perm);
&hids_init_obj.security_mode_boot_kb_inp_rep.cccd_write_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_kb_inp_rep.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.security_mode_boot_kb_inp_rep.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_kb_outp_rep.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_kb_outp_rep.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_protocol.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_protocol.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.security_mode_ctrl_point.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_ctrl_point.write_perm);
err_code = ble_hids_init(&m_hids, &hids_init_obj);
hids_init();
/**@brief Function for handling a Connection Parameters error.
uint32_t err_code;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = NULL;
cp_init.error_handler = conn_params_error_handler;
/**@brief Function for handling the HID Report Characteristic Write event.
* @param[in] p_evt HID service event.
static void on_hid_rep_char_write(ble_hids_evt_t *p_evt)
if (p_evt->params.char_write.char_id.rep_type == BLE_HIDS_REP_TYPE_OUTPUT)
uint32_t err_code;
uint8_t report_val;
uint8_t report_index = p_evt->params.char_write.char_id.rep_index;
if (report_index == OUTPUT_REPORT_INDEX)
// This code assumes that the outptu report is one byte long. Hence the following
// static assert is made.
STATIC_ASSERT(OUTPUT_REPORT_MAX_LEN == 5);
err_code = ble_hids_outp_rep_get(&m_hids,
report_index,
OUTPUT_REPORT_MAX_LEN,
0,
&report_val);
//Wedy 11/13 add for BT pen
/**@brief Function for sending consumer control data
static uint32_t pen_control_send(pen_control_t cmd)
return ble_hids_inp_rep_send(&m_hids, INPUT_REPORT_KEYS_INDEX, INPUT_REPORT_KEYS_MAX_LEN, (uint8_t*)&cmd);
static uint32_t hid_kbd_send_string(void)
uint8_t temp_buf[INPUT_REPORT_KEYS_MAX_LEN] = {0x00, 0x00};
return ble_hids_inp_rep_send(&m_hids, INPUT_REPORT_KEYS_INDEX, INPUT_REPORT_KEYS_MAX_LEN, (uint8_t*)temp_buf);
static uint32_t hid_kbd_send_release(void)
uint8_t temp_buf[INPUT_REPORT_KEYS_MAX_LEN] = {0, 0};
/**@brief Function for handling button events.
* @param[in] pin_no The pin number of the button pressed.
static void button_event_handler(uint8_t pin_no, uint8_t button_action)
if (button_action == APP_BUTTON_PUSH)
switch (pin_no)
case PAGE_UP:
APP_ERROR_CHECK(pen_control_send(PEN_UP));
case PAGE_DOWN:
APP_ERROR_CHECK(pen_control_send(PEN_DOWN));
APP_ERROR_HANDLER(pin_no);
else if (button_action == APP_BUTTON_RELEASE)
switch (pin_no)
case PAGE_UP:
/* Fall-through */
case PAGE_DOWN:
APP_ERROR_CHECK(pen_control_send(RELEASE_KEY));
/**@brief Function for initializing the button handler module.
static void buttons_init(void)
static app_button_cfg_t buttons[] =
{PAGE_UP, false, BUTTON_PULL, button_event_handler},
{PAGE_DOWN, false, BUTTON_PULL, button_event_handler}
app_button_init(buttons, sizeof(buttons) / sizeof(buttons[0]), BUTTON_DETECTION_DELAY);
// Prepare wakeup buttons.
/**@brief Function for handling HID events.
* @details This function will be called for all HID events which are passed to the application.
* @param[in] p_hids HID service structure.
* @param[in] p_evt Event received from the HID service.
static void on_hids_evt(ble_hids_t * p_hids, ble_hids_evt_t *p_evt)
switch (p_evt->evt_type)
case BLE_HIDS_EVT_BOOT_MODE_ENTERED:
m_in_boot_mode = true;
case BLE_HIDS_EVT_REPORT_MODE_ENTERED:
case BLE_HIDS_EVT_REP_CHAR_WRITE:
on_hid_rep_char_write(p_evt);
case BLE_HIDS_EVT_NOTIF_ENABLED:
dm_service_context_t service_context;
service_context.service_type = DM_PROTOCOL_CNTXT_GATT_SRVR_ID;
service_context.context_data.len = 0;
service_context.context_data.p_data = NULL;
if (m_in_boot_mode)
// Protocol mode is Boot Protocol mode.
if (
p_evt->params.notification.char_id.uuid
BLE_UUID_BOOT_KEYBOARD_INPUT_REPORT_CHAR
// The notification of boot keyboard input report has been enabled.
// Save the system attribute (CCCD) information into the flash.
uint32_t err_code;
err_code = dm_service_context_set(&m_bonded_peer_handle, &service_context);
// The system attributes could not be written to the flash because
// the connected central is not a new central. The system attributes
// will only be written to flash only when disconnected from this central.
// Do nothing now.
// Do nothing.
//Wedy 11/13 add to develop the BT PEN
else if (p_evt->params.notification.char_id.rep_type == BLE_HIDS_REP_TYPE_INPUT && p_evt->params.notification.char_id.rep_index == INPUT_REP_REF_ID)
// The protocol mode is Report Protocol mode. And the CCCD for the input report
// is changed. It is now time to store all the CCCD information (system
// attributes) into the flash.
uint32_t err_code;
// Do nothing now.
// The notification of the report that was enabled by the central is not interesting
// to this application. So do nothing.
// No implementation needed.
* @param[in] ble_adv_evt Advertising event.
uint32_t err_code;
switch (ble_adv_evt)
case BLE_ADV_EVT_DIRECTED:
err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_DIRECTED);
case BLE_ADV_EVT_FAST:
case BLE_ADV_EVT_SLOW:
err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_SLOW);
case BLE_ADV_EVT_FAST_WHITELIST:
err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_WHITELIST);
case BLE_ADV_EVT_SLOW_WHITELIST:
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
case BLE_ADV_EVT_WHITELIST_REQUEST:
ble_gap_whitelist_t whitelist;
ble_gap_addr_t * p_whitelist_addr[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
ble_gap_irk_t * p_whitelist_irk[BLE_GAP_WHITELIST_IRK_MAX_COUNT];
whitelist.addr_count = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
whitelist.irk_count = BLE_GAP_WHITELIST_IRK_MAX_COUNT;
whitelist.pp_addrs = p_whitelist_addr;
whitelist.pp_irks = p_whitelist_irk;
err_code = dm_whitelist_create(&m_app_handle, &whitelist);
err_code = ble_advertising_whitelist_reply(&whitelist);
case BLE_ADV_EVT_PEER_ADDR_REQUEST:
ble_gap_addr_t peer_address;
// Only Give peer address if we have a handle to the bonded peer.
if(m_bonded_peer_handle.appl_id != DM_INVALID_ID)
err_code = dm_peer_addr_get(&m_bonded_peer_handle, &peer_address);
if (err_code != (NRF_ERROR_NOT_FOUND | DEVICE_MANAGER_ERR_BASE))
err_code = ble_advertising_peer_addr_reply(&peer_address);
/**@brief Function for handling the Application's BLE Stack events.
* @param[in] p_ble_evt Bluetooth stack event.
static void on_ble_evt(ble_evt_t * p_ble_evt)
uint32_t err_code;
ble_gatts_rw_authorize_reply_params_t auth_reply;
case BLE_GAP_EVT_CONNECTED:
// Reset m_caps_on variable. Upon reconnect, the HID host will re-send the Output
// report containing the Caps lock state.
m_caps_on = false;
// disabling alert 3. signal - used for capslock ON
err_code = bsp_indication_set(BSP_INDICATE_ALERT_OFF);
case BLE_EVT_USER_MEM_REQUEST:
err_code = sd_ble_user_mem_reply(m_conn_handle, NULL);
case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
if(p_ble_evt->evt.gatts_evt.params.authorize_request.type
!= BLE_GATTS_AUTHORIZE_TYPE_INVALID)
if ((p_ble_evt->evt.gatts_evt.params.authorize_request.request.write.op
== BLE_GATTS_OP_PREP_WRITE_REQ)
== BLE_GATTS_OP_EXEC_WRITE_REQ_NOW)
== BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
if (p_ble_evt->evt.gatts_evt.params.authorize_request.type
== BLE_GATTS_AUTHORIZE_TYPE_WRITE)
auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
err_code = sd_ble_gatts_rw_authorize_reply(m_conn_handle,&auth_reply);
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
// Disconnect on GATT Server and Client timeout events.
err_code = sd_ble_gap_disconnect(m_conn_handle,
/**@brief Function for dispatching a BLE stack event to all modules with a BLE stack event handler.
* @details This function is called from the scheduler in the main loop after a BLE stack
* event has been received.
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
dm_ble_evt_handler(p_ble_evt);
bsp_btn_ble_on_ble_evt(p_ble_evt);
ble_advertising_on_ble_evt(p_ble_evt);
ble_conn_params_on_ble_evt(p_ble_evt);
ble_hids_on_ble_evt(&m_hids, p_ble_evt);
/**@brief Function for dispatching a system event to interested modules.
* @details This function is called from the System event interrupt handler after a system
* @param[in] sys_evt System stack event.
static void sys_evt_dispatch(uint32_t sys_evt)
pstorage_sys_event_handler(sys_evt);
ble_advertising_on_sys_evt(sys_evt);
uint32_t err_code;
nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
// Initialize the SoftDevice handler module.
SOFTDEVICE_HANDLER_APPSH_INIT(&clock_lf_cfg, true);
ble_enable_params_t ble_enable_params;
err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
PERIPHERAL_LINK_COUNT,
&ble_enable_params);
//Check the ram settings against the used number of links
CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
// Enable BLE stack.
err_code = softdevice_enable(&ble_enable_params);
// Register with the SoftDevice handler module for BLE events.
err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
/**@brief Function for the Event Scheduler initialization.
static void scheduler_init(void)
APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
uint32_t err_code;
uint8_t adv_flags;
ble_advdata_t advdata;
// Build and set advertising data
memset(&advdata, 0, sizeof(advdata));
adv_flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
advdata.name_type = BLE_ADVDATA_FULL_NAME;
advdata.include_appearance = true;
advdata.flags = adv_flags;
advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
advdata.uuids_complete.p_uuids = m_adv_uuids;
ble_adv_modes_config_t options =
BLE_ADV_WHITELIST_ENABLED,
BLE_ADV_DIRECTED_ENABLED,
BLE_ADV_DIRECTED_SLOW_DISABLED, 0,0,
BLE_ADV_FAST_ENABLED, APP_ADV_FAST_INTERVAL, APP_ADV_FAST_TIMEOUT,
BLE_ADV_SLOW_ENABLED, APP_ADV_SLOW_INTERVAL, APP_ADV_SLOW_TIMEOUT
err_code = ble_advertising_init(&advdata, NULL, &options, on_adv_evt, ble_advertising_error_handler);
/**@brief Function for handling the Device Manager events.
* @param[in] p_evt Data associated to the device manager event.
static uint32_t device_manager_evt_handler(dm_handle_t const * p_handle,
dm_event_t const * p_event,
ret_code_t event_result)
APP_ERROR_CHECK(event_result);
switch(p_event->event_id)
case DM_EVT_DEVICE_CONTEXT_LOADED: // Fall through.
case DM_EVT_SECURITY_SETUP_COMPLETE:
m_bonded_peer_handle = (*p_handle);
return NRF_SUCCESS;
/**@brief Function for the Device Manager initialization.
* @param[in] erase_bonds Indicates whether bonding information should be cleared from
* persistent storage during initialization of the Device Manager.
static void device_manager_init(bool erase_bonds)
uint32_t err_code;
dm_init_param_t init_param = {.clear_persistent_data = erase_bonds};
dm_application_param_t register_param;
// Initialize peer device handle.
err_code = dm_handle_initialize(&m_bonded_peer_handle);
// Initialize persistent storage module.
err_code = pstorage_init();
err_code = dm_init(&init_param);
memset(®ister_param.sec_param, 0, sizeof(ble_gap_sec_params_t));
register_param.sec_param.bond = SEC_PARAM_BOND;
register_param.sec_param.mitm = SEC_PARAM_MITM;
register_param.sec_param.lesc = SEC_PARAM_LESC;
register_param.sec_param.keypress = SEC_PARAM_KEYPRESS;
register_param.sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
register_param.sec_param.oob = SEC_PARAM_OOB;
register_param.sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
register_param.sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
register_param.evt_handler = device_manager_evt_handler;
register_param.service_type = DM_PROTOCOL_CNTXT_GATT_SRVR_ID;
err_code = dm_register(&m_app_handle, ®ister_param);
/**@brief Function for the Power manager.
static void power_manage(void)
uint32_t err_code = sd_app_evt_wait();
/**@brief Function for application main entry.
bool erase_bonds;
uint32_t err_code;
// Initialize.
app_trace_init();
timers_init();
//Wedy 11/14 add for BT control
buttons_init();
ble_stack_init();
scheduler_init();
device_manager_init(erase_bonds);
gap_params_init();
advertising_init();
services_init();
conn_params_init();
err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
// Enter main loop.
for (;;)
app_sched_execute();
power_manage();
