ZigBee controller and Osram and Develco smart plugs
Hi
I am using the light controller and added zb_nlme_permit_joining_request to allowing devices to join the network.
I get a good ZB_ZDO_SIGNAL_DEVICE_ANNCE signal and for the IKEA trådfre lamp I have that works fine but when
i use the Develoc smart plug or Osram smart+ plug they both end up in a loop sending:
ZB_ZDO_SIGNAL_LEAVE_INDICATION
Any pointer on what is needed to get them to stop doing this is greatly appreciated.
Before thy disconnect I can get information like zb_zdo_simple_desc_req with a valid result, is there any mandatory message I need
to send for the device to figure out that its connected ?
/Jimmy
  • Found the problem, the devices are not zcl version 2 and I enabled the legacy device support in main but it didn't work. Moving the setting to
    signalhander seams to fix the issue.
        switch (sig)
        case ZB_BDB_SIGNAL_DEVICE_FIRST_START:
        case ZB_BDB_SIGNAL_DEVICE_REBOOT:
            if (status == RET_OK)
                zb_bdb_set_legacy_device_support(1);
                comm_status = bdb_start_top_level_commissioning(ZB_BDB_NETWORK_STEERING);
