Error: L6915E: Library reports error: __use_no_semihosting was requested, but a semihosting fputc was linked in
I am Using NRF52840-DK. I merged the UART  Example code (PCA10056)  into the nRFX_SPIM (PCA10056) example code. That compile successfully I want to print a simple statement using the printf function. but whenever I add the printf statement I get the error as mentioned in the subject. I checked several links regarding this on the forum I was asked to add header file <stdio.h> which I did. In spite of that, the error persists. can you please assist me regarding this.
Please Find Attachment.
Rohit Patil,
	uint32_t err_code;
	MAX30003_begin();
//uint8_t DataPacketHeader[5];
////	data |= (SPI_RX_Buff[1] << 16);
MAX30003_Reg_Read(ECG_FIFO); //0x0F
SPI_RX_Buff[0]= SPI_RX_Buff[0] >> 8;
//uint8_t my_sample_1 = SPI_RX_Buff[0];
//my_sample_1= 0x00;
    const app_uart_comm_params_t comm_params =
          RX_PIN_NUMBER,
          TX_PIN_NUMBER,
          RTS_PIN_NUMBER,
          CTS_PIN_NUMBER,
          UART_HWFC,
          false,
#if defined (UART_PRESENT)
          NRF_UART_BAUDRATE_115200
#else
          NRF_UARTE_BAUDRATE_115200
                         UART_RX_BUF_SIZE,
                         UART_TX_BUF_SIZE,
                         uart_error_handle,
                         APP_IRQ_PRIORITY_LOWEST,
                         err_code);
#ifndef ENABLE_LOOPBACK_TEST
    printf("\r\nUART example started.\r\n");
nrfx_spim_config_t spi_config = NRFX_SPIM_DEFAULT_CONFIG;
spi_config.frequency = SPIM_FREQUENCY_FREQUENCY_K125;
spi_config.ss_pin = NRFX_SPIM_SS_PIN;
spi_config.miso_pin = NRFX_SPIM_MISO_PIN;
spi_config.mosi_pin = NRFX_SPIM_MOSI_PIN;
spi_config.sck_pin = NRFX_SPIM_SCK_PIN;
spi_config.dcx_pin = NRFX_SPIM_DCX_PIN;
spi_config.use_hw_ss = true;
spi_config.ss_active_high = false;
spi_config.mode = NRF_SPIM_MODE_2; // SCK active low, sample on trailing edge of clock
nrfx_spim_xfer_desc_t xfer_desc = NRFX_SPIM_XFER_TRX(SPI_TX_Buff, sizeof(SPI_TX_Buff), SPI_RX_Buff, sizeof(SPI_TX_Buff));
APP_ERROR_CHECK(nrfx_spim_init(&spi, &spi_config, spim_event_handler, NULL));
//memcpy(&my_sample_1,SPI_RX_Buff , (sizeof(uint8_t)));
NRF_LOG_INFO("NRFX SPIM example started.");
while (1)
// Reset rx buffer and transfer done flag
memset(SPI_RX_Buff, 0, m_length);
spi_xfer_done = false;
APP_ERROR_CHECK(nrfx_spim_xfer_dcx(&spi, &xfer_desc, 0, 15));
       uint8_t cr;
        while (app_uart_get(&cr) != NRF_SUCCESS);
        while (app_uart_put(cr) != NRF_SUCCESS);
        while (!spi_xfer_done)
					 if (cr == 'q' || cr == 'Q')
           printf(" \r\nExit!\r\n");
            while (true)
                // Do nothing.
__WFE();
NRF_LOG_FLUSH();
bsp_board_led_invert(BSP_BOARD_LED_0);
//nrf_delay_ms(200);
#else
 while (true)
        uart_loopback_test();
