BLE App Uart nRF52810
I'm trying to get the ble_app_uart example working on a nRF52810. I'm using SDK 15.2.0 together with Softdevice S112.
The infocenter says the Example needs Softdevice S132 or S140 http://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.sdk5.v15.2.0%2Findex.html. But that's not available for nRF52810. So what's the solution to run the ble_app_uart demo on the nRF52810?
If I try to use the ble_app_uart on the nRF52810 with the pca10040e then it doesn't work. I don't get UART output and also don't see any UART device with the nRF Connect App.
    The pca10040e configuration requires softdevice s112 (\components\softdevice\s112\hex) which will be uploaded automatically if you use Segger Embedded studio. Does you board include a 32kHz crystal? If not, make sure to change the clock source to use the internal RC in sdk_config.h.
    // <h> Clock - SoftDevice clock configuration
    // <o> NRF_SDH_CLOCK_LF_SRC  - SoftDevice clock source.
    // <0=> NRF_CLOCK_LF_SRC_RC
    // <1=> NRF_CLOCK_LF_SRC_XTAL
    // <2=> NRF_CLOCK_LF_SRC_SYNTH
    #ifndef NRF_SDH_CLOCK_LF_SRC
    #define NRF_SDH_CLOCK_LF_SRC 0
    // <o> NRF_SDH_CLOCK_LF_RC_CTIV - SoftDevice calibration timer interval.
    #ifndef NRF_SDH_CLOCK_LF_RC_CTIV
    #define NRF_SDH_CLOCK_LF_RC_CTIV 16
    // <o> NRF_SDH_CLOCK_LF_RC_TEMP_CTIV - SoftDevice calibration timer interval under constant temperature.
    // <i> How often (in number of calibration intervals) the RC oscillator shall be calibrated
    // <i>  if the temperature has not changed.
    #ifndef NRF_SDH_CLOCK_LF_RC_TEMP_CTIV
    #define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2
    // <o> NRF_SDH_CLOCK_LF_ACCURACY  - External clock accuracy used in the LL to compute timing.
    // <0=> NRF_CLOCK_LF_ACCURACY_250_PPM
    // <1=> NRF_CLOCK_LF_ACCURACY_500_PPM
    // <2=> NRF_CLOCK_LF_ACCURACY_150_PPM
    // <3=> NRF_CLOCK_LF_ACCURACY_100_PPM
    // <4=> NRF_CLOCK_LF_ACCURACY_75_PPM
    // <5=> NRF_CLOCK_LF_ACCURACY_50_PPM
    // <6=> NRF_CLOCK_LF_ACCURACY_30_PPM
    // <7=> NRF_CLOCK_LF_ACCURACY_20_PPM
    // <8=> NRF_CLOCK_LF_ACCURACY_10_PPM
    // <9=> NRF_CLOCK_LF_ACCURACY_5_PPM
    // <10=> NRF_CLOCK_LF_ACCURACY_2_PPM
    // <11=> NRF_CLOCK_LF_ACCURACY_1_PPM
    #ifndef NRF_SDH_CLOCK_LF_ACCURACY
    #define NRF_SDH_CLOCK_LF_ACCURACY 1
    Thanks for the fast answer. I already did that but it still doesn't work. I'm using arm gcc under Linux. I have also removed the emulation flags in the Makefile.
    How are you connecting the UART interface to your PC, do you have a USB<->UART bridge? I've tested the example (GCC - make flash_softdevice && make flash) with 52DK where the 52832 has been replaced with a nRF52810 and it worked.
    You can compile the the example with -DDEBUG then view the debug log with RTTviewer to see if there are any runtime errors.
    I have Pin6 connected to a USB - UART converter. I'm using a BL651 from Laird with a Breakout Board. I have tried to compile the Example with DDEBUG but don't see anything in RTTviewer. Any more ideas? For me it looks like it doesn't do anything at all.
    I would suggest that you debug the code, see if the program reaches main() for instance. You may use Segger embedded studio for debugging if you don't have a different debug setup. Also, since you have a custom board, note that the code enables pinreset on P0.21 by default (is active low).
