NRF Mesh Serial Protocol - Length Field Insufficient for Segmented Packets
The current protocol for the mesh serial interface as documented here:
http://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.sdk%2Fdita%2Fsdk%2Fmesh_sdk.html
has an issue when using it for subscriptions to mesh messages which are segmented.      When a segmented message whose total size is greater than 235 bytes is recieved,   any data past byte 235 is lost.    (384 bytes are possible with a segmented messaged  which includes the transmic and opcode).
I believe this is the result of the length field of the serial packet being represented by a single byte.      The internal serial packet struct uses a 16-bit variable to store the length byte when the packet is serialized it gets clipped to 8-bit.
I am looking at modifying the code to support full length segmented messages.  This is just a heads up for others who may be using the serial interface firmware and segmented messages.
