Can't debug with S110 7.0.0 using SDK6.1.0
First I load soft device through nRFgo. Then I run debug with eclipse. I then step through code in main.c ...
(I'm using QFAAG0 chip)
Stepping worked fine when I used SDK4.4.1 and S110 5.2.1. Stepping fails when I used SDK6.1.0 and S110 7.0.0. Hits signal trap. Can't step through code. However I verified program is loaded and runs correctly when I power cycle.
(Do I need to set the program counter manually?)
I have attached my log file for the failing case.
bad.txt
