The imprecision SAADC data just after VDD voltage measurement
Hello all,
I have a question about the SAADC of nRF52832.
Now I use the SAADC to measure the some external sensor voltage and the internal VDD voltage.
The sensor connection is follows,
- differential mode (sensor =AIN1, and stable constant voltage=AIN0)
- oversampling x256
- GAIN 1/4
- internal reference 0.6V
- use CH[0]
meanwhile, the VDD is
- single-end mode
- oversampling x128
- GAIN 1/6
- use CH[0]
I measure the sensor voltage in almost time and sometime measure the VDD.
The VDD source is coin battery (CR2032).
Finished the VDD and switched to the sensor , just 1st ADC data of sensor voltage is strange.
The 1st data is always 20-30LSB (14bit mode) higher than other normal data.
The sensor voltage is not change at this moment, but the data changed.
When switch from VDD to the sensor, I of course run the uninit() and the init() to reset.
But I use the same channel CH[0]  on both VDD and sensor.
Is that wrong?
Should I set the individual channels at each measurement sources?
Please let me know the correct way to use.
Kiyoshi Iwai
