I'm facing the issue, that the app_ble_uart example just works if I hook up TX/RX of my USB - UART converter. Is this a desired behaviour? It doesn't seem to start and advertise if I don't hook up TX/RX.
You may get a UART framings error if the RX pin becomes floating once you disconnect the USB-UART converter. To avoid this I would suggest to enable internal pull up on the RX pin after uart init.
/**@snippet [Handling the data received over UART] */
/**@brief Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
uint32_t err_code;
.rx_pin_no = RX_PIN_NUMBER,
.tx_pin_no = TX_PIN_NUMBER,
.rts_pin_no = RTS_PIN_NUMBER,
.cts_pin_no = CTS_PIN_NUMBER,
.use_parity = false,
#if defined (UART_PRESENT)
.baud_rate = NRF_UART_BAUDRATE_115200
#else
.baud_rate = NRF_UARTE_BAUDRATE_115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
NRF_P0->PIN_CNF[RX_PIN_NUMBER] |= GPIO_PIN_CNF_PULL_Msk;
Thanks, this was the issue!
