why it return SUCCESS in SD7.0 while fail in SD6.0?
Hi all,
I found something different between SD6.0 and SD7.0:
1.KB bonds with iPad successfully;
2.Click OFF the bluetooth button in iPad setting, then KB goes into advertising mode;
3.Click any button in KB continuously and click ON the bluetooth button in iPad setting;
4.Sometimes, the iPad indicates CONNECTED and the KB works well, but, sometimes KB does not work;
5.For SD7.0 and SDK6.0, the err_code returns SUCCESS when keys_send() called, no matter the KB works well or not;
6.For SD6.0 and SDK5.2, the err_code returns SUCCESS when KB works well, but NOT SUCCESS when KB does not work with iPad indicates NOT CONNECTED;
So, for SD7.0 and SDK6.0, there will be one condiction sometimes: the iPad indicates KB connected but not response any KB function, and the firmware could not detect it by err_code returned from SD.
But, it never happen in SD6.0 and SDK 5.2, with the same operation.
Could you help to confirm this ?
Thanks for reply.
Edit: Format (please use the preview feature)
