Problem with communication with HTS221 sensor
Hello Nordic community,
I have a nrf52-DK with SDK15.2.0 and I'm trying to communicate with ST HTS221 sensor. I have the original  STEVAL-MKI141V2 evaluation board.
I use the twi_sensor example, provided in the SDK. I added the hts221 driver from the SDK and used the default functions for initialization:
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "hts221.h"
#include "nrf_twi_mngr.h"
/* TWI instance ID. */
#define TWI_INSTANCE_ID             0
#define MAX_PENDING_TRANSACTIONS    33
void sen_init();
void read_th();
NRF_TWI_MNGR_DEF(m_nrf_twi_mngr, MAX_PENDING_TRANSACTIONS, TWI_INSTANCE_ID);
NRF_TWI_SENSOR_DEF(m_nrf_twi_sensor, &m_nrf_twi_mngr, HTS221_MIN_QUEUE_SIZE);
HTS221_INSTANCE_DEF(m_hts221, &m_nrf_twi_sensor, HTS221_BASE_ADDRESS);
////static hts221_data_t m_sample;
//void print_identity(ret_code_t r, void *p_register_data)
//    NRF_LOG_INFO("Identity: %d", *((uint8_t *)p_register_data));
void sen_init ()
	uint32_t err;
    nrf_drv_twi_config_t const config = {
       .scl                = 27,
       .sda                = 26,
       .frequency          = NRF_DRV_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_LOWEST,
       .clear_bus_init     = false
    NRF_LOG_INFO("TWI sensor example started.");
    NRF_LOG_FLUSH();
    err = nrf_twi_mngr_init(&m_nrf_twi_mngr, &config);
    APP_ERROR_CHECK(err);
    err = nrf_twi_sensor_init(&m_nrf_twi_sensor);
    err = hts221_init(&m_hts221);
		err = hts221_avg_cfg (&m_hts221, HTS221_TEMP_SAMPLES_8, HTS221_HUMIDITY_SAMPLES_16);
	//	err = hts221_data_rate_cfg (&m_hts221, HTS221_ODR_ONESHOT);
	//	APP_ERROR_CHECK(err);
		uint8_t reg;
		err = hts221_who_am_i_read (&m_hts221, NULL, &reg);
		NRF_LOG_INFO("WHO AM I: %d ", reg);
    NRF_LOG_FLUSH();
void read_th()
		uint32_t err;
		int16_t temperature = 0;
		int16_t humidity = 0;
		int16_t rawtemp;
		int16_t rawhum;
			err = hts221_temp_read(&m_hts221, NULL  ,&rawtemp);
	NRF_LOG_INFO("RAW TEMP : %d\n", rawtemp);
			temperature = hts221_temp_process(&m_hts221,  rawtemp) /8;
			err = hts221_hum_read(&m_hts221, NULL , &rawhum);
	NRF_LOG_INFO("RAW HUMIDITY : %d\n", rawhum);
			humidity = hts221_hum_process(&m_hts221,  rawhum) /2;
			NRF_LOG_INFO("Temp: %d  || Humidity: %d\n", temperature, humidity);
		sen_init();
    NRF_LOG_INFO("Here.");
    NRF_LOG_FLUSH();
    //APP_ERROR_CHECK(err);
		while(1)
			nrf_delay_ms(500);
		//	read_th();
			//NRF_LOG_FLUSH();
When I try to read the whoami register, I get value 0. When I try to read the temperature and humidity data, always get the same value.
I tried to communicate with ST LIS2DH12 accelerometer the same way with the same example and everything is normal. Is it possible the problem to be in the hts221 libraries?
