While developing on the nRF52840, we noticed recently that the IRQ priorities that we find in app_util_platform.h (from SDK 15.2.0) differ from the ones we can see in S140_SDS_v1.2.pdf:
S140_SDS_v1.2.pdf page 83:
app_util_platform.h line 74:
#if __CORTEX_M == (0x00U) [...] #elif __CORTEX_M == (0x04U) #define _PRIO_SD_HIGH 0 #define _PRIO_SD_MID 1 #define _PRIO_APP_HIGH 2 #define _PRIO_APP_MID 3 #define _PRIO_SD_LOW 4 #define _PRIO_SD_LOWEST 5 #define _PRIO_APP_LOW 6 #define _PRIO_APP_LOWEST 7 #define _PRIO_THREAD 15 #else [...]
The main difference is that priority level 5 should be for the application, but on the code it's _PRIO_SD_LOWEST. Is this a mistake ?
Also iif we look at the enum that comes right after:
typedef enum { #ifndef SOFTDEVICE_PRESENT APP_IRQ_PRIORITY_HIGHEST = _PRIO_SD_HIGH, #else APP_IRQ_PRIORITY_HIGHEST = _PRIO_APP_HIGH, #endif APP_IRQ_PRIORITY_HIGH = _PRIO_APP_HIGH, #ifndef SOFTDEVICE_PRESENT APP_IRQ_PRIORITY_MID = _PRIO_SD_LOW, #else APP_IRQ_PRIORITY_MID = _PRIO_APP_MID, #endif APP_IRQ_PRIORITY_LOW = _PRIO_APP_LOW, APP_IRQ_PRIORITY_LOWEST = _PRIO_APP_LOWEST, APP_IRQ_PRIORITY_THREAD = _PRIO_THREAD /**< "Interrupt level" when running in Thread Mode. */ } app_irq_priority_t;
We see that App_highest and App_high share the same level, since there are only 4 IRQ levels for the application. I guess that if level 5 was for the app as specified in the SDS, then they would be on two distinct levels.
Is there an explanation for that ? And am I right to think that I should use the levels described in the SDS and not the ones I found in app_util_platform.h ?
