Hello!
I am using NRF51822 in receiver mode with enabled interrupt on ADDRESS event, and even if transmitter is switched off I still get a few messages every second. It also applies to END event. How should I solve this?
Main, radio configuration and irq handler fuctions are described below.
clock_initialization();
// Set radio configuration parameters
radio_configure();
NRF_RADIO->PACKETPTR = (uint32_t)&packet;
NRF_RADIO->INTENSET = RADIO_INTENSET_ADDRESS_Enabled << RADIO_INTENSET_ADDRESS_Pos;
NVIC_ClearPendingIRQ(RADIO_IRQn);
NVIC_SetPriority(RADIO_IRQn, 0);
NVIC_EnableIRQ(RADIO_IRQn);
NRF_RADIO->EVENTS_READY = 0U;
// Enable radio and wait for ready
NRF_RADIO->TASKS_RXEN = 1U;
while (NRF_RADIO->EVENTS_READY == 0U);
NRF_RADIO->TASKS_START = 1U;
while (true)
void radio_configure()
// Radio config
NRF_RADIO->TXPOWER = (RADIO_TXPOWER_TXPOWER_Pos4dBm << RADIO_TXPOWER_TXPOWER_Pos);
NRF_RADIO->FREQUENCY = 75UL;
NRF_RADIO->MODE = (RADIO_MODE_MODE_Nrf_2Mbit << RADIO_MODE_MODE_Pos);
// Radio address config
NRF_RADIO->PREFIX0 =
((uint32_t)swap_bits(0xC3) << 24) // Prefix byte of address 3 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC2) << 16) // Prefix byte of address 2 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC1) << 8) // Prefix byte of address 1 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC0) << 0); // Prefix byte of address 0 converted to nRF24L series format
NRF_RADIO->PREFIX1 =
((uint32_t)swap_bits(0xC7) << 24) // Prefix byte of address 7 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC6) << 16) // Prefix byte of address 6 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC4) << 0); // Prefix byte of address 4 converted to nRF24L series format
NRF_RADIO->BASE0 = bytewise_bitswap(0x01234567UL); // Base address for prefix 0 converted to nRF24L series format
NRF_RADIO->BASE1 = bytewise_bitswap(0x89ABCDEFUL); // Base address for prefix 1-7 converted to nRF24L series format
NRF_RADIO->TXADDRESS = 0x00UL; // Set device address 0 to use when transmitting
NRF_RADIO->RXADDRESSES = 0x01UL; // Enable device address 0 to use to select which addresses to receive
// Packet configuration
NRF_RADIO->PCNF0 = (PACKET_S1_FIELD_SIZE << RADIO_PCNF0_S1LEN_Pos) |
(PACKET_S0_FIELD_SIZE << RADIO_PCNF0_S0LEN_Pos) |
(PACKET_LENGTH_FIELD_SIZE << RADIO_PCNF0_LFLEN_Pos); //lint !e845 "The right argument to operator '|' is certain to be 0"
NRF_RADIO->PCNF1 = (RADIO_PCNF1_WHITEEN_Disabled << RADIO_PCNF1_WHITEEN_Pos) |
(RADIO_PCNF1_ENDIAN_Big << RADIO_PCNF1_ENDIAN_Pos) |
(PACKET_BASE_ADDRESS_LENGTH << RADIO_PCNF1_BALEN_Pos) |
(PACKET_STATIC_LENGTH << RADIO_PCNF1_STATLEN_Pos) |
(PACKET_PAYLOAD_MAXSIZE << RADIO_PCNF1_MAXLEN_Pos); //lint !e845 "The right argument to operator '|' is certain to be 0"
// CRC Config
NRF_RADIO->CRCCNF = (RADIO_CRCCNF_LEN_Disabled << RADIO_CRCCNF_LEN_Pos); // Number of checksum bits
if ((NRF_RADIO->CRCCNF & RADIO_CRCCNF_LEN_Msk) == (RADIO_CRCCNF_LEN_Two << RADIO_CRCCNF_LEN_Pos))
NRF_RADIO->CRCINIT = 0xFFFFUL; // Initial value
NRF_RADIO->CRCPOLY = 0x11021UL; // CRC poly: x^16+x^12^x^5+1
else if ((NRF_RADIO->CRCCNF & RADIO_CRCCNF_LEN_Msk) == (RADIO_CRCCNF_LEN_One << RADIO_CRCCNF_LEN_Pos))
NRF_RADIO->CRCINIT = 0xFFUL; // Initial value
NRF_RADIO->CRCPOLY = 0x107UL; // CRC poly: x^8+x^2^x^1+1
void RADIO_IRQHandler(void)
NRF_RADIO->EVENTS_ADDRESS = 0;
defines from radio_configure.h:
#define PACKET_BASE_ADDRESS_LENGTH (1UL)
#define PACKET_STATIC_LENGTH (0UL)
#define PACKET_PAYLOAD_MAXSIZE (PACKET_STATIC_LENGTH)
