I try to read analog voltage over P28. Digital value(result variable in the code) always 238 as decimal.
What is the missed thing in the code?
Voltages supplied with power supply(as 0.5V,1V,2V)
volatile int16_t result = 0;
volatile float precise_result = 0;
//HFCLK
while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
NRF_SAADC->CH[4].CONFIG = (SAADC_CH_CONFIG_GAIN_Gain1_6 << SAADC_CH_CONFIG_GAIN_Pos) |
(SAADC_CH_CONFIG_MODE_SE << SAADC_CH_CONFIG_MODE_Pos) |
(SAADC_CH_CONFIG_REFSEL_Internal << SAADC_CH_CONFIG_REFSEL_Pos) |
(SAADC_CH_CONFIG_RESN_Bypass << SAADC_CH_CONFIG_RESN_Pos) |
(SAADC_CH_CONFIG_RESP_Bypass << SAADC_CH_CONFIG_RESP_Pos) |
(SAADC_CH_CONFIG_TACQ_3us << SAADC_CH_CONFIG_TACQ_Pos);
NRF_SAADC->CH[4].PSELP = SAADC_CH_PSELP_PSELP_VDD << SAADC_CH_PSELP_PSELP_Pos;
NRF_SAADC->CH[4].PSELN = SAADC_CH_PSELN_PSELN_NC << SAADC_CH_PSELN_PSELN_Pos;
NRF_SAADC->RESOLUTION = SAADC_RESOLUTION_VAL_8bit << SAADC_RESOLUTION_VAL_Pos;
NRF_SAADC->RESULT.MAXCNT = 1;
NRF_SAADC->RESULT.PTR = (uint32_t)&result;
NRF_SAADC->SAMPLERATE = SAADC_SAMPLERATE_MODE_Task << SAADC_SAMPLERATE_MODE_Pos;
NRF_SAADC->ENABLE = SAADC_ENABLE_ENABLE_Enabled << SAADC_ENABLE_ENABLE_Pos;
NRF_SAADC->TASKS_START = 1;
while (NRF_SAADC->EVENTS_STARTED == 0);
NRF_SAADC->EVENTS_STARTED = 0;
NRF_SAADC->TASKS_SAMPLE = 1;
while (NRF_SAADC->EVENTS_END == 0);
NRF_SAADC->EVENTS_END = 0;
NRF_SAADC->TASKS_STOP = 1;
while (NRF_SAADC->EVENTS_STOPPED == 0);
NRF_SAADC->EVENTS_STOPPED = 0;
result;
precise_result = (float)result / 4551.1f;
precise_result;
while(1) //breakpoint here
Thanks
