nrf52832 adc wrong value
I try to read analog voltage over P28. Digital value(result variable in the code) always 238 as decimal.
What is the missed thing in the code?
Voltages supplied with power supply(as 0.5V,1V,2V)
  volatile int16_t result = 0;
  volatile float precise_result = 0;
   //HFCLK
  while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
  NRF_SAADC->CH[4].CONFIG = (SAADC_CH_CONFIG_GAIN_Gain1_6    << SAADC_CH_CONFIG_GAIN_Pos) |
                            (SAADC_CH_CONFIG_MODE_SE         << SAADC_CH_CONFIG_MODE_Pos) |
                            (SAADC_CH_CONFIG_REFSEL_Internal << SAADC_CH_CONFIG_REFSEL_Pos) |
                            (SAADC_CH_CONFIG_RESN_Bypass     << SAADC_CH_CONFIG_RESN_Pos) |
                            (SAADC_CH_CONFIG_RESP_Bypass     << SAADC_CH_CONFIG_RESP_Pos) |
                            (SAADC_CH_CONFIG_TACQ_3us        << SAADC_CH_CONFIG_TACQ_Pos);
  NRF_SAADC->CH[4].PSELP = SAADC_CH_PSELP_PSELP_VDD << SAADC_CH_PSELP_PSELP_Pos;
  NRF_SAADC->CH[4].PSELN = SAADC_CH_PSELN_PSELN_NC << SAADC_CH_PSELN_PSELN_Pos;
  NRF_SAADC->RESOLUTION = SAADC_RESOLUTION_VAL_8bit << SAADC_RESOLUTION_VAL_Pos;
  NRF_SAADC->RESULT.MAXCNT = 1;
  NRF_SAADC->RESULT.PTR = (uint32_t)&result;
  NRF_SAADC->SAMPLERATE = SAADC_SAMPLERATE_MODE_Task << SAADC_SAMPLERATE_MODE_Pos;
  NRF_SAADC->ENABLE = SAADC_ENABLE_ENABLE_Enabled << SAADC_ENABLE_ENABLE_Pos;
  NRF_SAADC->TASKS_START = 1;
  while (NRF_SAADC->EVENTS_STARTED == 0);
  NRF_SAADC->EVENTS_STARTED = 0;
  NRF_SAADC->TASKS_SAMPLE = 1;
  while (NRF_SAADC->EVENTS_END == 0);
  NRF_SAADC->EVENTS_END = 0;
  NRF_SAADC->TASKS_STOP = 1;
  while (NRF_SAADC->EVENTS_STOPPED == 0);
  NRF_SAADC->EVENTS_STOPPED = 0;
  result;
  precise_result = (float)result / 4551.1f;
  precise_result;
  while(1) //breakpoint here
Thanks
