where to change name for the scanning peripheral name in the uart central code ??
i Have two development kits where one acts as uart central and another acts as uart peripheral .
In that i have given the peripherals different names(DEVICE_NAME), (the default name for ble_app_uart example is Nordic_UART.)
where do i need to change in the uart central for the scanning name ??
  • Hi.
    The UART Central example filters on UUID
    In line 164 in main.c, in the ble_app_uart_c example you find the following function call for initializing scanning:
    static void scan_init(void)
        ret_code_t          err_code;
        nrf_ble_scan_init_t init_scan;
        memset(&init_scan, 0, sizeof(init_scan));
        init_scan.connect_if_match = true;
        init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
        err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
        err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_UUID_FILTER, &m_nus_uuid);
        err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_UUID_FILTER, false);
    The two function calls you have to do in order to scan for a name is nrf_ble_scan_filters_enable() and nrf_ble_scan_filters_set().
    API for nrf_ble_scan_filters_set() is the following:
    /**@brief Function for adding any type of filter to the scanning.
     * @details This function adds a new filter by type @ref nrf_ble_scan_filter_type_t.
     *          The filter will be added if the number of filters of a given type does not exceed @ref NRF_BLE_SCAN_UUID_CNT,
     *          @ref NRF_BLE_SCAN_NAME_CNT, @ref NRF_BLE_SCAN_ADDRESS_CNT, or @ref NRF_BLE_SCAN_APPEARANCE_CNT, depending on the filter type,
     *          and if the same filter has not already been set.
     * @param[in,out] p_scan_ctx        Pointer to the Scanning Module instance.
     * @param[in]     type              Filter type.
     * @param[in]     p_data            The filter data to add.
     * @retval NRF_SUCCESS                    If the filter is added successfully.
     * @retval NRF_ERROR_NULL                 If a NULL pointer is passed as input.
     * @retval NRF_ERROR_DATA_SIZE            If the name filter length is too long. Maximum name filter length corresponds to @ref NRF_BLE_SCAN_NAME_MAX_LEN.
     * @retval NRF_ERROR_NO_MEMORY            If the number of available filters is exceeded.
     * @retval NRF_ERROR_INVALID_PARAM        If the filter type is incorrect. Available filter types: @ref nrf_ble_scan_filter_type_t.
     * @retval BLE_ERROR_GAP_INVALID_BLE_ADDR If the BLE address type is invalid.
    ret_code_t nrf_ble_scan_filter_set(nrf_ble_scan_t     * const p_scan_ctx,
                                       nrf_ble_scan_filter_type_t type,
                                       void const               * p_data);
    API for nrf_ble_scan_filters_enable() is the following:
    /**@brief Function for enabling filtering.
     * @details The filters can be combined with each other. For example, you can enable one filter or several filters.
     *          For example, (NRF_BLE_SCAN_NAME_FILTER | NRF_BLE_SCAN_UUID_FILTER) enables UUID and name filters.
     * @param[in] mode                  Filter mode: @ref NRF_BLE_SCAN_FILTER_MODE.
     * @param[in] match_all             If this flag is set, all types of enabled filters must be matched
     *                                  before generating @ref NRF_BLE_SCAN_EVT_FILTER_MATCH to the main application. Otherwise, it is enough to match
     *                                  one filter to trigger the filter match event.
     * @param[in] p_scan_ctx            Pointer to the Scanning Module instance.
     * @retval NRF_SUCCESS              If the filters are enabled successfully.
     * @retval NRF_ERROR_INVALID_PARAM  If the filter mode is incorrect. Available filter modes: @ref NRF_BLE_SCAN_FILTER_MODE.
    ret_code_t nrf_ble_scan_filters_enable(nrf_ble_scan_t * const p_scan_ctx,
                                           uint8_t                mode,
                                           bool                   match_all);
    You have to change those in parameters used in the ble_app_uart_c examples scan_init to the following:
        // Setting filters for scanning.
        err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_NAME_FILTER, false);
        err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_NAME_FILTER, m_target_periph_name);
    And also define the name you wish do search for under your defines in main.c:
    static char const m_target_periph_name[] = "Nordic_UART";     /**< Name of the device we try to connect to. This name is searched in the scan report data*/
    This should do the trick.
    Hope this was helpful.
    Best regards.
    Andreas
  • I've tried this exact code but I cannot seem to get the Central to see my advertising Peripheral.  It just keeps returning NRF_BLE_SCAN_EVT_NOT_FOUND.  My code is:
    static char const m_target_periph_name[] = "Test_Device";
    true);
    SCAN_NAME_FILTER,
    Am I missing anything?
  • Hi.
    In the function call:
    	err_code = nrf_ble_scan_filters_enable(&m_scan,NRF_BLE_SCAN_NAME_FILTER,true);
    You have set this to true, from the API declaration I posted below you can read this:
    Try to set it as false.
    Andreas
