- I have nRF51822 DK with (s110_nrf51822_7.0.0, nRF51 SDK_v6.1.0.0) and when i try to run the project in IAR 7.20.2 i receive an error.
2 ) My icf file
- Error after i added "--drv_vector_table_base=0x0" it is not starts from main.
2 ) My icf file
The error window is indicating you are trying to program address 0x15000 which is 84K. With SDS 7.0.0 the stack goes up to 88K. I suspect you need to edit your linker config file for the proper start and size of your projects code space. You can do that by selecting projects->options->linker->config in your IDE.
I edited your code snippet to use the code formatting. I've seen that call lock up when there was a bad clock on the 32KHz external oscillator pins. What are you using for a low frequency clock? If it isn't an external oscillator with 20PPM of error, you could see this problem.
