Emulator for nrf51
Hi all,
I know this question has been asked before, but a long time ago.
Is there any emulator for the nrf51 that I could make use of? I've tried using QEMU, but I'm not able to make it run properly (I'm not sure if the nrf51 for QEMU is a work in progress). I wanted to know if since last post (last year I think), some has been able to emulate the nrf51.
Thanks!
  • Hi Burgers,
    I am afraid that we do not have any emulator for the nRF51xxx ICs. It could be that some 3rd party has made one, but I am not familiar with any.
    Best regards
    Bjørn
  • We've got quite a full nRF52 emulator working in https://jumper.io
    Feel free to contact us as we can do the nRF51 too.
  • Greetings,
    my name is Emanuele Virgillito and I'm a computer engineering student at Politecnico di Torino. I'm developing a gdb-based c++ client to interact with jumper, but i found myself stucked in the following problem:
    even though breakpoints, run and step work, whenever i try to modify registers with my application, jumper responds "OK", but if i try to read the same register - even after a step command - the result i get is its value before the write.
    I'm using gdb rsp protocol in order to communicate to jumper and i also tried with original arm-none-eabi-gdb debugger but it behaves the same. I also tried to communicate with qemu and it works fine.
    I would be glad to hear your suggestions over this problem; you can find capture taken by wireshark on arm-none-eabi-gdb communication attached below.
    Regards
    EV
    PS. I know this isn't the right place to post this problem; I tried to reach you at [email protected] but cannot forward any mail.
    Wireshark Capture on writing register $r1 with value 0x4:
    GdbClnt: $P1=04000000#42
    Jumper: $OK#9a
    GdbClnt:$g#67
    Jumper: $0000000060080000000000207000002000000000000000000000000000000000000000000000000000000000000000000000000000000120ffffffffe6020000#09
    GdbClnt:$m2e6,4#9a
    Jumper: $9b1a03dd#58
    GdbClnt: $p19#da
    Jumper: $00000000#80
    GdbClnt:$m0,4#fd
    Jumper: $00000120#83
    Note: i also tried to perform step command in order to see if something would have changed after an istruction, but Jumper returns always $r1's value before write operation.
