Compile errors in MQTT example .
Hi!
I'm testing a mqtt publish example in nRF5 SDK v15.2.0 with nRF52832 DK(pca10040).
It succeeded in connecting with raspberry's mqtt-broker with non-secure type. It works well!
But If I just add one more app-timer-handler(it's output APPL_LOG data repeatly in 1 second) causing
compiler error like this.
linking...
.\_build\nrf52832_xxaa.axf: Error: L6406E: No space in execution regions with .ANY selector matching
system_nrf52.o(.data).
rand.o(.data).
nrf_drv_rng.o(.data).
nrf_sdh.o(.data).
pbuf.o(.data).
iot_context_manager.o(.data).
mem_manager.o(.data).
nrf_log_backend_rtt.o(.data).
nrf_sdh_ble.o(.data).
.\_build\nrf52832_xxaa.axf: Error: L6407E: Sections of aggregate size 0x24 bytes could not fit into
.ANY selector(s).
Not enough information to list image symbols.
Not enough information to list the image map.
Finished: 2 information, 0 warning and 10 error messages.
".\_build\nrf52832_xxaa.axf" - 10 Error(s), 0 Warning(s).
Target not created.
I changed define condition in "sdk_config.h"
#define IOT_BLE_6LOWPAN_CONFIG_LOG_ENABLED 1
#define BLE_6LOWPAN_LEGACY_MODE 0
#define MQTT_CONFIG_LOG_ENABLED 1
#define NRF_LOG_BACKEND_RTT_ENABLED 1
#define NRF_LOG_BACKEND_UART_ENABLED 0
I need your help.
    .ANY selector(s).
    You do not have enough space in RAM to successfully compile your project. It's not by much, so you can try tuning your optimization settings a bit, or disable logging.
    You could also try to reduce the stack size a bit, by setting the ASM preprocessor "__STACK_SIZE=7168" (NOTE: not in the C preprocessor, but in the ASM preprocessor!)
    Håkon
