Bonding sequence not finalized in first connection
Hi
I have tried to enable bonding on a application based on the Running Speed and Cadence example (Both peripheral and central). (I could not find an example with bonding enabled)
But it seems that the bonding sequence is interrupted, and after disconnection and re-connection the bonding procedure is finalized. I have created a custom service with a single characteristic, with reading, notifying and writing enabled. All with the security setting SEC_JUST_WORKS for both reading and writing.
Central - first connection
[00:00:00.002,197] <info> app: Custom Receiver Controller started.
[00:00:00.002,441] <info> app: =======================================
[00:00:00.002,441] <info> app: Deleting bonds
[00:00:00.002,441] <info> app: Erase bonds
[00:00:00.005,859] <error> peer_manager_handler: Peer deleted successfully: peer_id: 0
[00:00:00.005,859] <info> app: pm_evt_handler: EventId=10
[00:00:00.005,859] <info> peer_manager_handler: All peers deleted.
[00:00:00.005,859] <info> app: Starting scan.
[00:00:00.005,859] <info> app: scan_evt_handler: NRF_BLE_SCAN_EVT_WHITELIST_REQUEST
[00:00:09.923,828] <info> app: scan_evt_handler: NRF_BLE_SCAN_EVT_FILTER_MATCH
[00:00:09.959,228] <info> app: scan_evt_handler: 7
[00:00:09.959,228] <info> app: Connected.
[00:00:10.470,703] <info> app: pm_evt_handler: PM_EVT_CONN_SEC_PARAMS_REQ
[00:00:10.470,703] <info> app: pm_evt_handler: PM_EVT_CONN_SEC_START
[00:00:10.470,703] <info> app: Custom Service discovered.
[00:00:10.470,703] <info> app: Device Information Service discovered.
[00:00:10.501,464] <info> app: pm_evt_handler: PM_EVT_CONN_SEC_PARAMS_REQ
[00:00:10.531,005] <info> app:
[00:00:10.531,005] <info> app: Device Information:
[00:00:10.531,005] <info> app: PnP ID:
[00:00:10.531,005] <info> app:  Vendor ID Source: 0x01
[00:00:10.531,005] <info> app:  Vendor ID:        0x0059
[00:00:10.531,005] <info> app:  Product ID:       0x0001
[00:00:10.531,005] <info> app:  Product Version:  0x0002
[00:00:10.922,851] <info> peer_manager_handler: Connection secured: role: Central, conn_handle: 0, procedure: Bonding
[00:00:10.922,851] <info> app: pm_evt_handler: PM_EVT_CONN_SEC_SUCCEEDED
[00:00:10.925,537] <info> app: pm_evt_handler: PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
[00:00:10.927,978] <info> app: pm_evt_handler: PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
[00:00:10.982,910] <info> app: pm_evt_handler: PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
[00:00:30.960,449] <info> app: Disconnected. conn_handle: 0x0, reason: 0x15
Central - second connection:
[00:00:30.960,449] <info> app: Starting scan.
[00:00:30.960,449] <info> app: scan_evt_handler: NRF_BLE_SCAN_EVT_WHITELIST_REQUEST
[00:00:50.873,046] <info> app: scan_evt_handler: NRF_BLE_SCAN_EVT_WHITELIST_ADV_REPORT: F6:7F:4C:04:7F:2B
[00:00:50.873,046] <info> app: scan_evt_handler: Adv data: len=26
[00:00:50.873,046] <info> app: scan_evt_handler: Adv data: manuf_id=0xBEAF
[00:00:50.902,832] <info> app: scan_evt_handler: 7
[00:00:50.902,832] <info> app: pm_evt_handler: PM_EVT_CONN_SEC_PARAMS_REQ
[00:00:50.902,832] <info> app: pm_evt_handler: PM_EVT_CONN_SEC_START
[00:00:50.902,832] <info> app: pm_evt_handler: PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
[00:00:50.902,832] <info> app: pm_evt_handler: PM_EVT_BONDED_PEER_CONNECTED
[00:00:50.902,832] <info> app: pm_evt_handler: EventId=14
[00:00:50.902,832] <info> app: Connected.
[00:00:50.904,785] <info> app: pm_evt_handler: PM_EVT_CONN_SEC_PARAMS_REQ
[00:00:50.904,785] <info> app: pm_evt_handler: PM_EVT_CONN_SEC_START
[00:00:50.904,785] <info> app: pm_evt_handler: EventId=18
[00:00:51.084,472] <info> peer_manager_handler: Connection secured: role: Central, conn_handle: 0, procedure: Encryption
[00:00:51.084,472] <info> app: pm_evt_handler: PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
[00:00:51.084,472] <info> app: pm_evt_handler: PM_EVT_CONN_SEC_SUCCEEDED
[00:00:51.384,521] <info> peer_manager_handler: Connection secured: role: Central, conn_handle: 0, procedure: Encryption
[00:00:51.384,521] <info> app: pm_evt_handler: PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
[00:00:51.384,521] <info> app: pm_evt_handler: PM_EVT_CONN_SEC_SUCCEEDED Bonding=Yes
[00:00:51.804,443] <info> app: pm_evt_handler: PM_EVT_CONN_SEC_PARAMS_REQ
[00:00:51.804,443] <info> app: pm_evt_handler: PM_EVT_CONN_SEC_START
[00:00:51.804,443] <info> app: Notification enabled.
[00:00:51.804,443] <info> app: Custom Service discovered.
[00:00:51.804,443] <info> app: Device Information Service discovered.
[00:00:52.104,492] <info> peer_manager_handler: Connection secured: role: Central, conn_handle: 0, procedure: Encryption
[00:00:52.104,492] <info> app: pm_evt_handler: PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
[00:00:52.104,492] <info> app: pm_evt_handler: PM_EVT_CONN_SEC_SUCCEEDED
[00:00:52.164,550] <info> app:
[00:00:52.164,550] <info> app: Device Information:
[00:00:52.164,550] <info> app: PnP ID:
[00:00:52.164,550] <info> app:  Vendor ID Source: 0x01
[00:00:52.164,550] <info> app:  Vendor ID:        0x0059
[00:00:52.164,550] <info> app:  Product ID:       0x0001
[00:00:52.164,550] <info> app:  Product Version:  0x0002
[00:01:02.410,644] <info> app: AppEventBtn: 3 Pressed
[00:01:02.410,644] <info> app: Sendig config.
[00:01:02.543,945] <info> app: AppEventBtn: 3 Released
[00:01:02.543,945] <info> app: Sendig config.
I believe it should be possible to do all the bonding sequence in a single connection. Do anyone have an example, or en idea why the bonding sequence is not finalized. Is there some more debug I should create/enable?
