hii...
i have programmed the ble_uart with twi sensor ...
complied very successfully
but while i am debugging i am getting error in void twi_init()
why and also fatal error
please give me a solution
hii...
Don't you already have a thread on this?
https://devzone.nordicsemi.com/f/nordic-q-a/40678/my-device-is-not-adverstising
read it properly ... this is different from previous post
So you've solved that other problem, then?
If so, please update the other thread to say that - and explain how you fixed it.
You also need to conclude this thread: https://devzone.nordicsemi.com/f/nordic-q-a/40564/ble_nus_string_send-error/158765#158765
Please don't just leave threads hanging
This seems to be an APP_ERROR_CHECK failure, which means that twi_init has failed with an error. What was the error number ? you can start this application in the debug mode to see exactly which call returned error and the API documentation will tell you why that occurred.
Indeed - which, most likely, is the same problem as the other thread:
https://devzone.nordicsemi.com/f/nordic-q-a/40678/my-device-is-not-adverstising/158122#158122
