I am currently trying to implement an IR sending functionality. My plan is to use a timer to toggle gpiote through ppi. For the width of an IR pulse (or mark) and space, I count the number of timer pulses generated.
Now I can clearly see the generated pulses with correct period (26us for 38kHz). However, the number of pulses is always several pulses more than expected. The following is my timer event handler codes, and configurations. The handler will be called every 13us, and basically the test codes send 99 sets of mark and space pairs (mark 500us, space 400us)
void IRsendBase::mark(uint16_t time)
next_target = (2 * time * mFreqKHz) / 1000;
nrfx_gpiote_out_task_enable(mPinNumber);
extent += time;
void IRsendBase::space(uint16_t time)
nrfx_gpiote_out_task_disable(mPinNumber);
extent += time;
void IRsendBase::handleTmrEvent(nrf_timer_event_t event_type)
if(NRF_TIMER_EVENT_COMPARE0 == event_type)
if (next_target == tick_cnt++)
// current_cnt = tick_cnt-1;
// if(send_index == sizeof(data)/2 - 1)
if (send_index == 99 - 1)
space(0);
tick_cnt = 0;
send_index = 0;
next_target = 0;
// current_cnt = 0;
nrfx_timer_disable(&gIRLib2SendTimer);
return;
if (send_index & 1)
// space(data[send_index++]);
space(400);
// mark(data[send_index++]);
mark(500);
send_index++;
tick_cnt = 0;
(code is based on IRLib2 for arduino, but with much different implementation of sending function)
nrfx_gpiote_out_config_t gpiote_config; gpiote_config.init_state = NRF_GPIOTE_INITIAL_VALUE_LOW; gpiote_config.task_pin = true; gpiote_config.action = NRF_GPIOTE_POLARITY_TOGGLE;
Any suggestion is welcomed, or other better solution please advise.
Thanks a lot
Bo
