PWM cannot set to 125khz frequency
I am using the nrf-52840 DK.
I modified the pwm_library to output 125khz frequency.
app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_2CH(125000L, NRF_GPIO_PIN_MAP(1,0) , NRF_GPIO_PIN_MAP(1,3));
I check the oscilloscope, the IC cannot generate such high frequency PWM.
Please advise how to set the PWM to generate 125kHz fequency.
Thanks
  • APP_PWM_INSTANCE(PWM1,1);                   // Create the instance "PWM1" using TIMER1.
    static volatile bool ready_flag;            // A flag indicating PWM status.
    void pwm_ready_callback(uint32_t pwm_id)    // PWM callback function
        ready_flag = true;
        ret_code_t err_code;
        /* 2-channel PWM, 125kHz, output on DK LED pins. */
        app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_2CH(8L, BSP_LED_0, BSP_LED_1);
        /* Switch the polarity of the second channel. */
        pwm1_cfg.pin_polarity[1] = APP_PWM_POLARITY_ACTIVE_HIGH;
        /* Initialize and enable PWM. */
        err_code = app_pwm_init(&PWM1,&pwm1_cfg,pwm_ready_callback);
        app_pwm_enable(&PWM1);
        app_pwm_channel_duty_set(&PWM1, 0, 50);
        app_pwm_channel_duty_set(&PWM1, 1, 50);
        while (true)
