nrf51822 uart only works when connected to debugger
I am using nRF5_SDK_12.3.0 and writing customized firmware based on uart example.
Everything works fine with the DK. Then I program the firmware to a nrf51822 module using the DK after modifying the board definition to fix my customized board.
My firmware will send out a start up message though uart after uart initiation. However, I can only capture that uart message if the customized board is connected with the DK.
Here is my initialization code:
    #define RX_PIN_NUMBER  UART_PIN_DISCONNECTED
    #define TX_PIN_NUMBER  3
    #define CTS_PIN_NUMBER UART_PIN_DISCONNECTED
    #define RTS_PIN_NUMBER UART_PIN_DISCONNECTED
    const app_uart_comm_params_t comm_params =
          RX_PIN_NUMBER,
          TX_PIN_NUMBER,
          RTS_PIN_NUMBER,
          CTS_PIN_NUMBER,
          APP_UART_FLOW_CONTROL_DISABLED,
          false,
          UART_BAUDRATE_BAUDRATE_Baud115200
                         UART_RX_BUF_SIZE,
                         UART_TX_BUF_SIZE,
                         uart_error_handle,
                         APP_IRQ_PRIORITY_LOWEST,
                         err_code);
I have also tried to send message periodically as followings:
        uart_tx_length = sprintf(uart_tx_buf, "START\r\n");
        while(true)
            nrf_delay_ms(250);
            user_uart_write(uart_tx_buf, uart_tx_length);
where user_uart_write is as follows:
void user_uart_write(char *buf, uint8_t length)
    for (uint32_t i = 0; i < length; i++)
            while (app_uart_put(buf[i]) != NRF_SUCCESS);
It keep sending the "START\r\n" when connected to the DK and stop when I unplug the customized board from it.
Any idea what have I don't wrong?
