Turning on WDT after clearing bonds and resetting causes halt
I have noticed that when I run in release mode, turn WDT on, write bonding info, clear bonding info, and reset, my application suddenly uses 2mA more and takes 5 minutes (the length of my WDT timeout) to respond again. But there is no fatal error reported, even though I turned on logs for release mode. When I use GDB, it shows this, implying watchdog_enable is the problem. But how can this be? I have also noticed that if I skip the "write bonding info, clear bonding info" steps, the "5 minute unresponsiveness" does not happen. Is the unresponsiveness because of the ENTER_CRITICAL_REGION? I noticed that if I comment out watchdog_enable, the unresponsiveness goes away.
(gdb) list
1327
1328	static void watchdog_enable(void){
1329
1330	    //Configure WDT.
1331	    nrf_drv_wdt_config_t config = NRF_DRV_WDT_DEAFULT_CONFIG;
1332	    config.reload_value = NRF_WATCHDOG_RELOAD_VALUE;
1333	    nrf_drv_wdt_init(&config, wdt_event_handler);
1334	    nrf_drv_wdt_channel_alloc(&m_channel_id);
1335	    nrf_drv_wdt_enable();
1336	}
SDK 14.0
Softdevice S132 5.0.0
