Write with authorization of one byte results in UnlikelyError
we configure a GATT Server with a characteristic that is configuered for write with authorization. If we then try to write one byte to this characteristic from the client, we get an ErrorResponse with UnlikelyError.
The Error seems to be send directly from the softdevice, since it is send even before we can handle the authorization request. If the characteristic is configuered for write without authorization it works fine, so do writes of multiple bytes. We also tried using NRFConnect on PC and Mobile as Clients to make sure its not caused by our client Firmware.
This only happened after we migrated from SDK12.2 with SoftDevice 3.1 to SDK15 with SoftDevice 6.1. If we revert to the old state it works.
If someone has an idea what could have been changed since SDK12.2 with Softdevice3.1 that could cause this issue, I would appreciate some help.
Niclas
    What exactly does Refresh device cache do with the server? Or is it just something for the nRF Connect Client?
    Smartphones will typically cache the attributes(service and characteristics) it discovered last time it connected to the BLE device(server). In that way, it doesn’t need to do the service discovery procedure each time it connects to a known device. Refresh device cache will clear/refresh this cache.
    1) Do you have a sniffer log showing the sequence of packets leading to this error? (nRF sniffer v2 link)
    2)
    Could you post some code that shows how the service and characteristic is configured?
    3)
    BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST. If we then send the sd_ble_gatts_rw_authorize_reply we get a wrongState Error
    From the SD API doc, this means that there is either a "Invalid Connection State or no authorization request pending.". Could you post the code on how you use the sd_ble_gatts_rw_authorize_reply() ?
    4) You reproduced this with using nRF Connect for desktop as the central ?
  • Hi Sigurd,
    thank you for the explanation, since we do a full chip erase before the test on both Client and Server I think we are save.
    to 1)
    20181121_WriteResp_UnlikelyError.zip
    to 2)
    Since we use a two-chip approach and additionally control the parameters over our testing environment I can't  copy our code directly, but i will try to combine it so you can see how we configure the characteristic:
    ble_gatts_char_md_t char_md;
    ble_gatts_attr_md_t cccd_md;
    ble_gatts_attr_md_t attr_md;
    ble_gatts_attr_t    attr_char_value;
    ble_gatts_char_handles_t tmphandles;
    memset(&char_md, 0, sizeof(char_md));
    memset(&cccd_md,0, sizeof(cccd_md));
    memset(&attr_md, 0, sizeof(attr_md));
    memset(&attr_char_value, 0, sizeof(attr_char_value));
    /*Set CCCD*/
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
    cccd_md.write_perm.sm = 1;
    cccd_md.write_perm.lv = 1;
    cccd_md.vloc       = BLE_GATTS_VLOC_STACK;
    /*Set Char*/
    char_md.char_props.broadcast     = 0;
    char_md.char_props.read          = 0;
    char_md.char_props.write         = 1;
    char_md.char_props.write_wo_resp = 0;
    char_md.char_props.notify        = 0;
    char_md.char_props.indicate      = 1;
    char_md.char_props.auth_signed_wr = 0;
    char_md.p_char_user_desc = NULL;
    char_md.p_char_pf        = NULL;
    char_md.p_user_desc_md   = NULL;
    char_md.p_cccd_md        = &cccd_md;
    char_md.p_sccd_md        = NULL;
    /* Set Attr */
    attr_md.read_perm.sm = 0;
    attr_md.read_perm.lv = 0;
    attr_md.write_perm.sm = 1;
    attr_md.write_perm.lv = 1;
    attr_md.vloc       = BLE_GATTS_VLOC_STACK;
    attr_md.vlen       = 1;
    attr_md.rd_auth    = 0;
    attr_md.wr_auth    = 1;
    attr_char_value.p_uuid    = &ble_uuid;
    attr_char_value.p_attr_md = &attr_md;
    attr_char_value.init_len  = 20;
    attr_char_value.init_offs = 0;
    attr_char_value.max_len   = 20;
    attr_char_value.p_value   = NULL;
    err_code = sd_ble_gatts_characteristic_add(service_handle,
          &char_md,
          &attr_char_value,
          &tmphandles);
    to 3)
    As the UnlikelyError happens indepent of sending the sd_ble_gatts_rw_authorize_reply(). We can see that we are still in a connection, but with sending the ATT-Error we think the authorization request is cancelled. So most likely "no authorization request pending" is the cause of the wrong state. This should be resolved automatically if we can prevent the UnlikelyError.
    to 4)
    As I said, our default usecase is having our own Firmware for Client/Central and Server/Peripheral. Just to be sure we modiefied our tests, so we could use nRFConnect as a Client/Central. This we tried with an Android Phone as well as with PC using a Nordic Dongle.
    Thank you,
    Niclas
  • Thank you for the sniffer log.
    Q1) After you get the event BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST, do you call any other sd_* function except for the sd_ble_gatts_rw_authorize_reply() function?
    Q2) Are you calling sd_ble_gatts_hvx() ? If yes, under what conditions are you calling it?
  • So, we found the error.
    A colleague implemented a new service and checked the length before checking the handle.
    Sorry for the trouble and thanks for all the help.
    Niclas
