Write with authorization of one byte results in UnlikelyError
we configure a GATT Server with a characteristic that is configuered for write with authorization. If we then try to write one byte to this characteristic from the client, we get an ErrorResponse with UnlikelyError.
The Error seems to be send directly from the softdevice, since it is send even before we can handle the authorization request. If the characteristic is configuered for write without authorization it works fine, so do writes of multiple bytes. We also tried using NRFConnect on PC and Mobile as Clients to make sure its not caused by our client Firmware.
This only happened after we migrated from SDK12.2 with SoftDevice 3.1 to SDK15 with SoftDevice 6.1. If we revert to the old state it works.
If someone has an idea what could have been changed since SDK12.2 with Softdevice3.1 that could cause this issue, I would appreciate some help.
Niclas
    Where exactly are you receiving this "ErrorResponse with UnlikelyError." ? What function?
  • Hi Sigurd,
    we can see the UnlikelyError in the ATT ErrorResponse over Bluetooth and it is reported by the nrfConnect App, when trying to write one byte.
    On the server we get no notification about this error or why it is happening, just the normal BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST. If we then send the sd_ble_gatts_rw_authorize_reply we get a wrongState Error (most likely because the softdevice already ended the authorization request when sending the UnlikelyError).
    Even if we ignore the BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST, the error is sent immediately in the next connection event following the received write request.
    Thanks for looking into it.
    Niclas
    Have you enable the Service Changed characteristic? (NRF_SDH_BLE_SERVICE_CHANGED set to 1 in sdk_config)
    Could you try to "Refresh device cache" using nRF Connect ?
  • Hi Sigurd,
    yes we have enabled service changed.
    We normally use our own Client Firmware to do the write operation and just used nRF Connect to verify it's not caused by our Client FW. What exactly does Refresh device cache do with the server? Or is it just something for the nRF Connect Client?
    It would cause some hassle to rewrite the code again to work with nRFConnect and through our tests with multiple client-softwares we are confident it's not caused by the Client behaviour, so I want to make sure.
    Could you maybe also look into the softdevice code what even can cause an Unlikely Error, so we can look at those parts? As the name implies I imagine there can't be many occurences. Especially since it already triggered the BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST. I would think that all checks are done before sending the event, not after since it gets obsolete if a check fails and the authorisation procedure is canceled.
    Niclas
  • Hi Sigurd,
    since there was no further answer to my question we tried to refresh the device cache, but it didn't work.
    If you have any other idea, what could cause this I would be grateful. Please also regard my other reply with the open question on softdevice behaviour.
    Niclas
