Abort event. Reason: 0xD DFU SDK Mesh 2.2.0
Hello, i did the DFU quick start guide and everything work fine however when i try to send a ZIP file (124KB) with my own code the receiver show "Abort event. Reason: 0xD DFU", i suposse that the file is so big, are there some way to do work with that file?
Thanks.
  • Hi.
    1) This is the DFU quick start guide you follow?
    2) Which version of nrfutil did you create the packet with? Can you check by running nrfutil version in CMD?
    3) Have you tried to debug the code to see where the error is triggered?
    Best regards.
    Andreas
  • 1) yes it is.
    2)nrfutil version 0.3.0.0
    3)this is what show the DK what receive the file from mesh network:
     0> <t:         70>, main.c,  206, ----- Bluetooth Mesh DFU Example -----
     0> <t:         73>, main.c,  215, rom_base   260DD
     0> <t:         75>, main.c,  216, rom_end    423DC
     0> <t:         77>, main.c,  217, rom_length 1C2FF
     0> <t:         79>, main.c,  218, bank_addr   43000
     0> <t:         81>, mesh_softdevice_init.c,  117, Initializing SoftDevice...
     0> <t:          0>, mesh_softdevice_init.c,   75, Enabling BLE...
     0> <t:         16>, mesh_softdevice_init.c,  109, sd_ble_enable: app_ram_base should be adjusted to 0x20002DA0
     0> <t:        608>, serial_handler_prov.c,  267, Generating encryption keypair...
     0> <t:       5480>, main.c,  224, Initialization complete!
     0> <t:       5487>, nrf_mesh_dfu.c,  527, 	RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFE
     0> <t:       5491>, nrf_mesh_dfu.c,  560, 	SERIAL TX!
     0> <t:      10268>, main.c,  244, Enabling serial interface...
     0> <t:      10280>, main.c,  248, DFU example started!
     0> <t:    7702042>, nrf_mesh_dfu.c,  389, 	New firmware!
     0> <t:    7702045>, nrf_mesh_dfu.c,  527, 	RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFD
     0> <t:    7702049>, nrf_mesh_dfu.c,  533, Killing a TX slot prematurely (repeats done: 24).
     0> <t:    7702053>, nrf_mesh_dfu.c,  560, 	SERIAL TX!
     0> <t:    7769287>, nrf_mesh_dfu.c,  527, 	RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFD
     0> <t:    7769291>, nrf_mesh_dfu.c,  533, Killing a TX slot prematurely (repeats done: 0).
     0> <t:    7769295>, nrf_mesh_dfu.c,  560, 	SERIAL TX!
     0> <t:    7834264>, nrf_mesh_dfu.c,  382, 	Abort event. Reason: 0xD
     0> <t:    7834268>, nrf_mesh_dfu.c,  527, 	RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFE
     0> <t:    7834272>, nrf_mesh_dfu.c,  533, Killing a TX slot prematurely (repeats done: 19).
     0> <t:    7834275>, nrf_mesh_dfu.c,  560, 	SERIAL TX!
    and this is what show the DK what send the file for mesh network:
     0> <t:         73>, mesh_softdevice_init.c,  117, Initializing SoftDevice...
     0> <t:        577>, mesh_stack.c,  107, HOLA 1..1
     0> <t:        579>, mesh_stack.c,  109, HOLA 1..2
     0> <t:        582>, mesh_stack.c,  111, HOLA 1..3
     0> <t:        584>, mesh_stack.c,  113, HOLA 1..4
     0> <t:        586>, serial_handler_prov.c,  267, Generating encryption keypair...
     0> <t:       5472>, main.c,  224, Initialization complete!
     0> <t:       5478>, nrf_mesh_dfu.c,  528, 	RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFE
     0> <t:       5483>, nrf_mesh_dfu.c,  561, 	SERIAL TX!
     0> <t:      10261>, main.c,  244, Enabling serial interface...
     0> <t:      10274>, main.c,  248, DFU example started!
     0> <t:     221226>, nrf_mesh_dfu.c,  390, 	New firmware!
     0> <t:     221229>, nrf_mesh_dfu.c,  528, 	RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFD
     0> <t:     221233>, nrf_mesh_dfu.c,  534, Killing a TX slot prematurely (repeats done: 1).
     0> <t:     221236>, nrf_mesh_dfu.c,  561, 	SERIAL TX!
     0> <t:     287118>, nrf_mesh_dfu.c,  528, 	RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFD
     0> <t:     287122>, nrf_mesh_dfu.c,  534, Killing a TX slot prematurely (repeats done: 20).
     0> <t:     287125>, nrf_mesh_dfu.c,  561, 	SERIAL TX!
     0> <t:     353059>, nrf_mesh_dfu.c,  430, 	DFU start
     0> <t:     353062>, nrf_mesh_dfu.c,  528, 	RADIO TX! SLOT 7, count 6, interval: exponential, handle: FFFC
     0> <t:     752767>, nrf_mesh_dfu.c,  528, 	RADIO TX! SLOT 1, count 3, interval: exponential, handle: FFFC
     0> <t:     759664>, nrf_mesh_dfu.c,  528, 	RADIO TX! SLOT 2, count 3, interval: exponential, handle: FFFC
     0> <t:     766609>, nrf_mesh_dfu.c,  528, 	RADIO TX! SLOT 3, count 3, interval: exponential, handle: FFFC
     0> <t:     773519>, nrf_mesh_dfu.c,  528, 	RADIO TX! SLOT 4, count 3, interval: exponential, handle: FFFC
     0> <t:     780473>, nrf_mesh_dfu.c,  528, 	RADIO TX! SLOT 5, count 3, interval: exponential, handle: FFFC
     0> <t:     787384>, nrf_mesh_dfu.c,  528, 	RADIO TX! SLOT 6, count 3, interval: exponential, handle: FFFC
     0> <t:     794327>, nrf_mesh_dfu.c,  528, 	RADIO TX! SLOT 7, count 3, interval: exponential, handle: FFFC
     0> <t:     801264>, nrf_mesh_dfu.c,  528, 	RADIO TX! SLOT 1, count 3, interval: exponential, handle: FFFC
     0> <t:    1128944>, nrf_mesh_dfu.c,  297, ABORT Timeout fired @34283798
     0> <t:    1128947>, nrf_mesh_dfu.c,  528, 	RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFE
     0> <t:    1128952>, nrf_mesh_dfu.c,  561, 	SERIAL TX!
  • Hi again.
    Could you post the output from your command window when you are on Point 10?
    And can you also do the Troubleshooting: Verifying your bootloader with the bootloader_verify.py script and post the output?
    Best regards.
    Andreas
  • Hello AndreasF,  this is the output from my command window:
     C:\Users\ingeniero.app1\Documents\Programa_LEPS_Btm_2.2.0\nrf5_SDK_for_Mesh_v2.2.0_src> nrfutil --verbose dfu serial -pkg dfu_test.
    zip -p COM15 -b 115200 -fc --mesh
    Upgrading target on COM15 with DFU package C:\Users\ingeniero.app1\Documents\Programa_LEPS_Btm_2.2.0\nrf5_SDK_for_Mesh_v2.2.0_src\dfu_test.zip. Flow control is enabled.
      [------------------------------------]    0%Flushing com-port...
    Opened com-port
    Starting DFU upgrade of type 4, SoftDevice size: 0, bootloader size: 0, application size: 124568
    Sending DFU start packet, afterwards we wait for the flash on target to be initialized before continuing.
    PC -> target: 0502aabbccdd
    target -> PC: 0582aabbccdd
    Got echo response
    Sending DFU init packet
    PC -> target: 1378fdff040f7dcca1b754454e33010002000000
    target -> PC: 16a60454454e3301000200000054454e33020001000000
    target -> PC: 03847800
    PC -> target: 1478fcff00007dcca1b7ffffffffa679000040000c
    target -> PC: 0da2020454454e33010002000000
    Sending firmware file
      [------------------------------------]    1%  0d 00:11:52PC -> target: 1978fcff01007dcca1b738bd0020356202006562020067620200
    PC -> target: 1978fcff02007dcca1b7696202006b6202006d62020000000000
    PC -> target: 1978fcff03007dcca1b70000000000000000000000006f620200
    PC -> target: 1978fcff04007dcca1b771620200000000007362020075620200
    PC -> target: 1978fcff05007dcca1b7796202007b620200f5670200891e0400
    PC -> target: 1978fcff06007dcca1b781620200836202003986020087620200
    PC -> target: 1978fcff07007dcca1b78962020041680200b17e03008f620200
    PC -> target: 1978fcff08007dcca1b791620200936202009562020097620200
    PC -> target: 1978fcff09007dcca1b79962020025b50300d5cd02009f620200
    PC -> target: 1978fcff0a007dcca1b74db50300a362020025170400a7620200
    PC -> target: 1978fcff0b007dcca1b7a9620200ab620200ad620200af620200
    PC -> target: 1978fcff0c007dcca1b7b1620200b36202007762020077620200
    PC -> target: 1978fcff0d007dcca1b7b5620200b7620200b9620200bb620200
    PC -> target: 1978fcff0e007dcca1b7bd620200bf620200c162020035493648
    PC -> target: 1978fcff0f007dcca1b70a1a02d0072291438d46344934480a1a
    PC -> target: 1978fcff10007dcca1b706d00722914381f30988022282f31488
    PC -> target: 1978fcff11007dcca1b730483149314a00f043f831483149324a
    PC -> target: 1978fcff12007dcca1b700f03ef831483249324a00f039f83248
    PC -> target: 1978fcff13007dcca1b73249334a00f034f832483349334a00f0
    PC -> target: 1978fcff14007dcca1b72ff833483349344a00f02af833483449
    PC -> target: 1978fcff15007dcca1b7344a00f025f834483449002200f02bf8
    PC -> target: 1978fcff16007dcca1b733483449002200f026f833483349091a
    PC -> target: 1978fcff17007dcca1b7082903db00220260043001601f482049
    PC -> target: 1978fcff18007dcca1b7884205d00268043003b4904703bcf7e7
    and this is the verifying boot loader output:
    thanks for your help.
  • Hi again.
     Is this all the log? It seems that some logging is missing.
    Could you please post all the log.
    I did the quick start guide now, and I got this output:
    nrfutilmesh --verbose dfu serial -pkg dfu_test.zip -p COM4 -b 115200 -fc --mesh
    Upgrading target on COM4 with DFU package C:\NordicSemi\nrf5_SDK_for_Mesh_v2.2.0_src_2\dfu_quick_start\dfu_test.zip. Flow control is enabled.
    Opened com-port
    Starting DFU upgrade of type 4, SoftDevice size: 0, bootloader size: 0, application size: 1912
    Got echo response
    PC -> target: 1378fdff040f7fed04c759000000010002000000
    target -> PC: 16a6045900000001000200000059000000010001000000
    PC -> target: 1478fcff00007fed04c7ffffffffde01000040000c
    target -> PC: 0da2010459000000010002000000
      [------------------------------------]    1%  0d 00:11:50PC -> target: 1978fcff01007fed04c700fd0020196602004166020043660200
    PC -> target: 1978fcff02007fed04c745660200476602004966020000000000
      [------------------------------------]    2%  0d 00:11:39PC -> target: 1978fcff03007fed04c70000000000000000000000004b660200
    PC -> target: 1978fcff04007fed04c74d660200000000004f66020051660200
      [#-----------------------------------]    4%  0d 00:07:23PC -> target: 1978fcff05007fed04c753660200536602005366020053660200
    PC -> target: 1978fcff06007fed04c753660200536602005366020053660200
      [##----------------------------------]    5%  0d 00:05:43PC -> target: 1978fcff07007fed04c753660200536602005366020053660200
    PC -> target: 1978fcff08007fed04c753660200536602005366020053660200
      [##----------------------------------]    7%  0d 00:04:46PC -> target: 1978fcff09007fed04c753660200536602005366020053660200
    PC -> target: 1978fcff0a007fed04c753660200536602005366020053660200
      [###---------------------------------]    9%  0d 00:04:09PC -> target: 1978fcff0b007fed04c753660200536602005366020053660200
    PC -> target: 1978fcff0c007fed04c753660200536602000000000000000000
      [###---------------------------------]   10%  0d 00:03:41PC -> target: 1978fcff0d007fed04c753660200536602005366020053660200
    PC -> target: 1978fcff0e007fed04c753660200536602005366020000000000
      [####--------------------------------]   12%  0d 00:03:21PC -> target: 1978fcff0f007fed04c700000000000000000000000000000000
    PC -> target: 1978fcff10007fed04c700000000000000000000000000000000
      [#####-------------------------------]   13%  0d 00:02:02PC -> target: 1978fcff11007fed04c700000000000000000000000000000000
    PC -> target: 1978fcff12007fed04c700000000000000000000000000000000
      [#####-------------------------------]   15%  0d 00:01:47PC -> target: 1978fcff13007fed04c700000000000000000000000000000000
    PC -> target: 1978fcff14007fed04c700000000000000000000000000000000
      [######------------------------------]   17%  0d 00:01:37PC -> target: 1978fcff15007fed04c700000000000000000000000000000000
    PC -> target: 1978fcff16007fed04c700000000000000000000000000000000
      [######------------------------------]   18%  0d 00:01:29PC -> target: 1978fcff17007fed04c700000000000000000000000000000000
    PC -> target: 1978fcff18007fed04c700000000000000000000000000000000
      [#######-----------------------------]   20%  0d 00:01:23PC -> target: 1978fcff19007fed04c700000000000000000000000000000000
    PC -> target: 1978fcff1a007fed04c700000000000000000000000000000000
      [#######-----------------------------]   21%  0d 00:01:19PC -> target: 1978fcff1b007fed04c700000000000000000000000000000000
    PC -> target: 1978fcff1c007fed04c700000000000000000000000000000000
      [########----------------------------]   23%  0d 00:01:14PC -> target: 1978fcff1d007fed04c700000000000000000000000000000000
    PC -> target: 1978fcff1e007fed04c700000000000000000000000000000000
      [#########---------------------------]   25%  0d 00:01:11PC -> target: 1978fcff1f007fed04c700000000000000000000000000000000
    PC -> target: 1978fcff20007fed04c700000000000000000000000000000000
      [#########---------------------------]   26%  0d 00:01:07PC -> target: 1978fcff21007fed04c710b5054c237833b9044b13b10448aff3
    PC -> target: 1978fcff22007fed04c700800123237010bd3833002000000000
      [##########--------------------------]   28%  0d 00:01:05PC -> target: 1978fcff23007fed04c7fc6602000c4b43b10c480d4910b5aff3
    PC -> target: 1978fcff24007fed04c700800c48036823b910bd0a48036833b9
      [##########--------------------------]   30%  0d 00:01:02PC -> target: 1978fcff25007fed04c77047094b002bf7d0bde810401847064b
    PC -> target: 1978fcff26007fed04c7002bf5d0184700bf00000000fc660200
      [###########-------------------------]   31%  0d 00:00:59PC -> target: 1978fcff27007fed04c73c3300203433002000000000154b002b
    PC -> target: 1978fcff28007fed04c708bf134b9d46a3f5803a00218b460f46
      [###########-------------------------]   33%  0d 00:00:57PC -> target: 1978fcff29007fed04c71348144a121a00f01dfa0f4b002b00d0
    PC -> target: 1978fcff2a007fed04c798470e4b002b00d09847002000210400
      [############------------------------]   34%  0d 00:00:55PC -> target: 1978fcff2b007fed04c70d000d48002802d00c48aff3008000f0
    PC -> target: 1978fcff2c007fed04c7e5f92000290000f013f800f0cbf900bf
      [#############-----------------------]   36%  0d 00:00:53PC -> target: 1978fcff2d007fed04c70000080000fd00200000000000000000
    PC -> target: 1978fcff2e007fed04c738330020543300200000000000000000
      [#############-----------------------]   38%  0d 00:00:51PC -> target: 1978fcff2f007fed04c770b5002301224ff0a041032002fa03f4
    PC -> target: 1978fcff30007fed04c714f4f01f18bf03f5e07403f1010318bf
      [##############----------------------]   39%  0d 00:00:49PC -> target: 1978fcff31007fed04c741f82400202bf1d14ff0a0434ff4f012
    PC -> target: 1978fcff32007fed04c70a4dc3f808250022c3f80c251c4645f0
      [##############----------------------]   41%  0d 00:00:48PC -> target: 1978fcff33007fed04c70105d4f8043583f40033c4f804356426
    PC -> target: 1978fcff34007fed04c74ff47a40a847013efad1f2e7f0660200
      [###############---------------------]   42%  0d 00:00:46PC -> target: 1978fcff35007fed04c7094b1b78062b0cd1084b1b681a0708d1
    PC -> target: 1978fcff36007fed04c7074b186800f0f000a0f1300358425841
      [################--------------------]   44%  0d 00:00:44PC -> target: 1978fcff37007fed04c770470020704700bfe00f00f0e40f00f0
    PC -> target: 1978fcff38007fed04c7e80f00f00c4b1b78062b10d10b4b1b68
      [################--------------------]   46%  0d 00:00:43PC -> target: 1978fcff39007fed04c71a070cd10a4b186800f0f003302b08d0
    PC -> target: 1978fcff3a007fed04c700f0e000a0f140035842584170470020
      [#################-------------------]   47%  0d 00:00:41PC -> target: 1978fcff3b007fed04c770470120704700bfe00f00f0e40f00f0
    PC -> target: 1978fcff3c007fed04c7e80f00f008b5fff7ddff28b17f4b804a
      [#################-------------------]   49%  0d 00:00:40PC -> target: 1978fcff3d007fed04c71b68c3f304231360fff7baff10b17d4b
    PC -> target: 1978fcff3e007fed04c77d4a1a60fff7ceff28b17c4b7c4a1b68
      [##################------------------]   50%  0d 00:00:38PC -> target: 1978fcff3f007fed04c7c3f342331360fff7abff20b1794ad368
    PC -> target: 1978fcff40007fed04c723f08073d360fff7bdff40b14ff08043
      [##################------------------]   52%  0d 00:00:37PC -> target: 1978fcff41007fed04c70022c3f80c21c3f81021c3f83825fff7
    PC -> target: 1978fcff42007fed04c797ff10b1704b03221a60fff791ff40b1
      [###################-----------------]   54%  0d 00:00:35PC -> target: 1978fcff43007fed04c76e4b05221a6001229a6700229a603f22
    PC -> target: 1978fcff44007fed04c75a606b4b1b78062b09d16a4b1b681907
      [####################----------------]   55%  0d 00:00:34PC -> target: 1978fcff45007fed04c705d1694b1b6803f0f003502b67d0fff7
    PC -> target: 1978fcff46007fed04c791ff28b1654b664a1b6803f04f031360
      [####################----------------]   57%  0d 00:00:32PC -> target: 1978fcff47007fed04c7fff788ff48b14ff08043d3f80024d207
    PC -> target: 1978fcff48007fed04c744bf6ff00102c3f800245e4b1b68062b
      [#####################---------------]   59%  0d 00:00:31PC -> target: 1978fcff49007fed04c704d15d4b1b68062b00f091805b4ad2f8
    PC -> target: 1978fcff4a007fed04c7883043f47003c2f88830bff34f8fbff3
      [#####################---------------]   60%  0d 00:00:30PC -> target: 1978fcff4b007fed04c76f8f4ff01023d3f80022002a03dbd3f8
    PC -> target: 1978fcff4c007fed04c70432002b2fda524b0122c3f80425d3f8
      [######################--------------]   62%  0d 00:00:28PC -> target: 1978fcff4d007fed04c70024002afbd04ff010221521c2f80012
    PC -> target: 1978fcff4e007fed04c7d3f80024002afbd04ff010231522c3f8
      [#######################-------------]   63%  0d 00:00:27PC -> target: 1978fcff4f007fed04c70422474b1a46d3f800140029fbd00021
    PC -> target: 1978fcff50007fed04c7c3f80415d2f80034002bfbd0bff34f8f
      [#######################-------------]   65%  0d 00:00:26PC -> target: 1978fcff51007fed04c73e49404bca6802f4e0621343cb60bff3
    PC -> target: 1978fcff52007fed04c74f8f00bffde73c4b3c4a1a6008bd4ff0
      [########################------------]   67%  0d 00:00:25PC -> target: 1978fcff53007fed04c780523b4bd2f80414c3f82015d2f80814
    PC -> target: 1978fcff54007fed04c7c3f82415d2f80c14c3f82815d2f81014
      [########################------------]   68%  0d 00:00:23PC -> target: 1978fcff55007fed04c7c3f82c15d2f81414c3f83015d2f81814
    PC -> target: 1978fcff56007fed04c7c3f83415d2f81c14c3f84015d2f82014
      [#########################-----------]   70%  0d 00:00:22PC -> target: 1978fcff57007fed04c7c3f84415d2f82414c3f84815d2f82814
    PC -> target: 1978fcff58007fed04c7c3f84c15d2f82c14c3f85015d2f83014
      [#########################-----------]   71%  0d 00:00:21PC -> target: 1978fcff59007fed04c7c3f85415d2f83414c3f86015d2f83814
    PC -> target: 1978fcff5a007fed04c7c3f86415d2f83c14c3f86815d2f84014
      [##########################----------]   73%  0d 00:00:20PC -> target: 1978fcff5b007fed04c7c3f86c15d2f84424c3f870254fe7194a
    PC -> target: 1978fcff5c007fed04c7136843f48063136068e700bf24030010
      [###########################---------]   75%  0d 00:00:18PC -> target: 1978fcff5d007fed04c74035014074c007400df0adba44020010
    PC -> target: 1978fcff5e007fed04c73c050040f0ed00e0a005004010560040
      [###########################---------]   76%  0d 00:00:17PC -> target: 1978fcff5f007fed04c7e00f00f0e40f00f0e80f00f058020010
    PC -> target: 1978fcff60007fed04c7e40e0040300100103401001000ed00e0
      [############################--------]   78%  0d 00:00:16PC -> target: 1978fcff61007fed04c700e001400400fa05c83200200090d003
    PC -> target: 1978fcff62007fed04c700c000403c1700400649074a074b9b1a
      [############################--------]   80%  0d 00:00:15PC -> target: 1978fcff63007fed04c703dd043bc858d050fbdcfff7c3fefff7
    PC -> target: 1978fcff64007fed04c71dfe000008670200c832002038330020
      [#############################-------]   81%  0d 00:00:14PC -> target: 1978fcff65007fed04c7fee7fee7fee7fee7fee7fee7fee7fee7
    PC -> target: 1978fcff66007fed04c7fee7fee708b5074b044613b10021aff3
      [#############################-------]   83%  0d 00:00:12PC -> target: 1978fcff67007fed04c70080054b1868836a03b19847204600f0
    PC -> target: 1978fcff68007fed04c731f800bf00000000f866020070b50d4e
      [##############################------]   84%  0d 00:00:11PC -> target: 1978fcff69007fed04c70d4ca41ba4100025a54209d10b4e0c4c
    PC -> target: 1978fcff6a007fed04c700f022f8a41ba4100025a54205d170bd
      [###############################-----]   86%  0d 00:00:10PC -> target: 1978fcff6b007fed04c756f8253098470135eee756f825309847
    PC -> target: 1978fcff6c007fed04c70135f2e72c3300202c3300202c330020
      [###############################-----]   88%  0d 00:00:09PC -> target: 1978fcff6d007fed04c73033002002440346934200d1704703f8
    PC -> target: 1978fcff6e007fed04c7011bf9e7fee700bff8b500bff8bc08bc
      [################################----]   89%  0d 00:00:08PC -> target: 1978fcff6f007fed04c79e467047f8b500bff8bc08bc9e467047
    PC -> target: 1978fcff70007fed04c70338fdd870470000cc32002000000000
      [################################----]   91%  0d 00:00:07PC -> target: 1978fcff71007fed04c76cfbff7f010000000090d00300000000
    PC -> target: 1978fcff72007fed04c700000000000000000000000000000000
      [#################################---]   92%  0d 00:00:05PC -> target: 1978fcff73007fed04c700000000000000000000000000000000
    PC -> target: 1978fcff74007fed04c700000000000000000000000000000000
      [##################################--]   94%  0d 00:00:04PC -> target: 1978fcff75007fed04c700000000000000000000000000000000
    PC -> target: 1978fcff76007fed04c700000000000000000000000000000000
      [##################################--]   96%  0d 00:00:03PC -> target: 1978fcff77007fed04c700000000000000000000000025620200
    PC -> target: 1178fcff78007fed04c70162020000000000
      [###################################-]   97%  0d 00:00:02PC -> target: 1978fcff79007fed04c7140fefd5b3fafa8097c9d867cf04603a
    PC -> target: 1978fcff7a007fed04c7b0852c72a1688ff5a01121145eff1891
      [###################################-]   99%  0d 00:00:01PC -> target: 1978fcff7b007fed04c7ba420404fb3aaeb3952905c13fe38f79
    PC -> target: 1978fcff7c007fed04c79825538f37a1586e52ca531ccc3e4b7f
      [####################################]  100%             DFU upgrade took 69.5340001583s
    Closing serial port...
    Device programmed.
    You can try my setup if you want, download it here: dfu_quick_start.zip
    Just edit the dfu_quick_start.bat file like this:
    REM Generate DFU packet
    nrfutil dfu genpkg --application ../bin/blinky/blinky_nrf52832_xxAA_s132_6.0.0.hex --company-id 0x00000059 --application-id 1 --application-version 2 --key-file ..\dfu_quick_start\private_key.txt --sd-req 0x009D --mesh dfu_test.zip
    REM ERASE
    nrfjprog -e --snr <serial number to board 1>
    nrfjprog -e --snr <serial number to board 2>
    nrfjprog -e --snr <serial number to board 3>
    REM SOFTDEVICE
    nrfjprog --program softdevice.hex --verify --snr <serial number to board 1>
    nrfjprog --program softdevice.hex --verify --snr <serial number to board 2>
    nrfjprog --program softdevice.hex --verify --snr <serial number to board 3>
    REM serial bootloader
    nrfjprog --program bootloader.hex --verify --snr <serial number to board 1>
    nrfjprog --program bootloader.hex --verify --snr <serial number to board 2>
    nrfjprog --program bootloader.hex --verify --snr <serial number to board 3>
    REM application
    nrfjprog --program app.hex --verify --snr <serial number to board 1>
    nrfjprog --program app.hex --verify --snr <serial number to board 2>
    nrfjprog --program app.hex --verify --snr <serial number to board 3>
    REM device page
    nrfjprog --program device_page.hex --verify --snr <serial number to board 1>
    nrfjprog --program device_page.hex --verify --snr <serial number to board 2>
    nrfjprog --program device_page.hex --verify --snr <serial number to board 3>
    REM RESET
    nrfjprog --reset --snr <serial number to board 1>
    nrfjprog --reset --snr <serial number to board 2>
    nrfjprog --reset --snr <serial number to board 3>
    REM DFU
    nrfutil --verbose dfu serial -pkg dfu_test.zip -p <COM PORT to one of the boards> -b 115200 -fc --mesh
    Just add your serial numbers to the different boards where it says <serial number to board 1/2/3> and add you COM Port to the nrfutil command
    Best regards.
    Andreas
    I work with David Villarraga.
    We solved the "Abort event. Reason: 0xD DFU" problem doing this:
    1. In the Segger compiler we selected the code size optimization option
    2. In the code we modified the Flash settings, so that the starting address of the DFU file is above the end of the current application -> make sure they do not overlap.
    Your .bat file suggestion helped us a lot with the debug.
    BUT:
    Now the DFU file apparently is totally received (we see the 100% complete bar and the "device programmed" text) but we are now getting the following errors:
    0> <t: 9974248>, nrf_mesh_dfu.c, 296, ABORT Timeout fired @-918597344
    0> <t: 9974252>, nrf_mesh_dfu.c, 584, RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFE
    And the device does not boot with the new code...
    We have searched the Web looking for hints on what to do to fix this, but nothing. What could be the reason to get those messages?
  • Hi.
    Can you try with a precompiled blinky .hex file located in the <Mesh SDK>\bin\blinky folder?
    And use the nrfutil command:
    nrfutil --verbose dfu serial -pkg dfu_test.zip -p <COM PORT to one of the boards> -b 115200 -fc --mesh -i 800
    I got the following output:
    λ nrfutil --verbose dfu serial -pkg dfu_test.zip -p COM19 -b 115200 -fc --mesh -i 800
    Upgrading target on COM19 with DFU package C:\NordicSemi\nrf5_SDK_for_Mesh_v2.2.0_src_2\dfu_quick_start\dfu_test.zip. Flow control is enabled.
    Opened com-port
    Got echo response
    PC -> target: 1378fdff040f301de70859000000010002000000
    PC -> target: 1478fcff0000301de708ffffffffde01000040000c
      [------------------------------------]    1%  0d 00:11:50PC -> target: 1978fcff0100301de70800fd0020196602004166020043660200
    PC -> target: 1978fcff0200301de70845660200476602004966020000000000
      [------------------------------------]    2%  0d 00:11:39PC -> target: 1978fcff0300301de7080000000000000000000000004b660200
    PC -> target: 1978fcff0400301de7084d660200000000004f66020051660200
      [#-----------------------------------]    4%  0d 00:07:33PC -> target: 1978fcff0500301de70853660200536602005366020053660200
    PC -> target: 1978fcff0600301de70853660200536602005366020053660200
      [##----------------------------------]    5%  0d 00:05:57PC -> target: 1978fcff0700301de70853660200536602005366020053660200
    PC -> target: 1978fcff0800301de70853660200536602005366020053660200
      [##----------------------------------]    7%  0d 00:05:04PC -> target: 1978fcff0900301de70853660200536602005366020053660200
    PC -> target: 1978fcff0a00301de70853660200536602005366020053660200
      [###---------------------------------]    9%  0d 00:04:28PC -> target: 1978fcff0b00301de70853660200536602005366020053660200
    PC -> target: 1978fcff0c00301de70853660200536602000000000000000000
      [###---------------------------------]   10%  0d 00:04:02PC -> target: 1978fcff0d00301de70853660200536602005366020053660200
    PC -> target: 1978fcff0e00301de70853660200536602005366020000000000
      [####--------------------------------]   12%  0d 00:03:42PC -> target: 1978fcff0f00301de70800000000000000000000000000000000
    PC -> target: 1978fcff1000301de70800000000000000000000000000000000
      [#####-------------------------------]   13%  0d 00:02:26PC -> target: 1978fcff1100301de70800000000000000000000000000000000
    PC -> target: 1978fcff1200301de70800000000000000000000000000000000
      [#####-------------------------------]   15%  0d 00:02:13PC -> target: 1978fcff1300301de70800000000000000000000000000000000
    PC -> target: 1978fcff1400301de70800000000000000000000000000000000
      [######------------------------------]   17%  0d 00:02:03PC -> target: 1978fcff1500301de70800000000000000000000000000000000
    PC -> target: 1978fcff1600301de70800000000000000000000000000000000
      [######------------------------------]   18%  0d 00:01:56PC -> target: 1978fcff1700301de70800000000000000000000000000000000
    PC -> target: 1978fcff1800301de70800000000000000000000000000000000
      [#######-----------------------------]   20%  0d 00:01:50PC -> target: 1978fcff1900301de70800000000000000000000000000000000
    PC -> target: 1978fcff1a00301de70800000000000000000000000000000000
      [#######-----------------------------]   21%  0d 00:01:44PC -> target: 1978fcff1b00301de70800000000000000000000000000000000
    PC -> target: 1978fcff1c00301de70800000000000000000000000000000000
      [########----------------------------]   23%  0d 00:01:40PC -> target: 1978fcff1d00301de70800000000000000000000000000000000
    PC -> target: 1978fcff1e00301de70800000000000000000000000000000000
      [#########---------------------------]   25%  0d 00:01:36PC -> target: 1978fcff1f00301de70800000000000000000000000000000000
    PC -> target: 1978fcff2000301de70800000000000000000000000000000000
      [#########---------------------------]   26%  0d 00:01:32PC -> target: 1978fcff2100301de70810b5054c237833b9044b13b10448aff3
    PC -> target: 1978fcff2200301de70800800123237010bd3833002000000000
      [##########--------------------------]   28%  0d 00:01:29PC -> target: 1978fcff2300301de708fc6602000c4b43b10c480d4910b5aff3
    PC -> target: 1978fcff2400301de70800800c48036823b910bd0a48036833b9
      [##########--------------------------]   30%  0d 00:01:26PC -> target: 1978fcff2500301de7087047094b002bf7d0bde810401847064b
    PC -> target: 1978fcff2600301de708002bf5d0184700bf00000000fc660200
      [###########-------------------------]   31%  0d 00:01:23PC -> target: 1978fcff2700301de7083c3300203433002000000000154b002b
    PC -> target: 1978fcff2800301de70808bf134b9d46a3f5803a00218b460f46
      [###########-------------------------]   33%  0d 00:01:20PC -> target: 1978fcff2900301de7081348144a121a00f01dfa0f4b002b00d0
    PC -> target: 1978fcff2a00301de70898470e4b002b00d09847002000210400
      [############------------------------]   34%  0d 00:01:18PC -> target: 1978fcff2b00301de7080d000d48002802d00c48aff3008000f0
    PC -> target: 1978fcff2c00301de708e5f92000290000f013f800f0cbf900bf
      [#############-----------------------]   36%  0d 00:01:15PC -> target: 1978fcff2d00301de7080000080000fd00200000000000000000
    PC -> target: 1978fcff2e00301de70838330020543300200000000000000000
      [#############-----------------------]   38%  0d 00:01:13PC -> target: 1978fcff2f00301de70870b5002301224ff0a041032002fa03f4
    PC -> target: 1978fcff3000301de70814f4f01f18bf03f5e07403f1010318bf
      [##############----------------------]   39%  0d 00:01:11PC -> target: 1978fcff3100301de70841f82400202bf1d14ff0a0434ff4f012
    PC -> target: 1978fcff3200301de7080a4dc3f808250022c3f80c251c4645f0
      [##############----------------------]   41%  0d 00:01:08PC -> target: 1978fcff3300301de7080105d4f8043583f40033c4f804356426
    PC -> target: 1978fcff3400301de7084ff47a40a847013efad1f2e7f0660200
      [###############---------------------]   42%  0d 00:01:06PC -> target: 1978fcff3500301de708094b1b78062b0cd1084b1b681a0708d1
    PC -> target: 1978fcff3600301de708074b186800f0f000a0f1300358425841
      [################--------------------]   44%  0d 00:01:04PC -> target: 1978fcff3700301de70870470020704700bfe00f00f0e40f00f0
    PC -> target: 1978fcff3800301de708e80f00f00c4b1b78062b10d10b4b1b68
      [################--------------------]   46%  0d 00:01:02PC -> target: 1978fcff3900301de7081a070cd10a4b186800f0f003302b08d0
    PC -> target: 1978fcff3a00301de70800f0e000a0f140035842584170470020
      [#################-------------------]   47%  0d 00:01:00PC -> target: 1978fcff3b00301de70870470120704700bfe00f00f0e40f00f0
    PC -> target: 1978fcff3c00301de708e80f00f008b5fff7ddff28b17f4b804a
      [#################-------------------]   49%  0d 00:00:58PC -> target: 1978fcff3d00301de7081b68c3f304231360fff7baff10b17d4b
    PC -> target: 1978fcff3e00301de7087d4a1a60fff7ceff28b17c4b7c4a1b68
      [##################------------------]   50%  0d 00:00:56PC -> target: 1978fcff3f00301de708c3f342331360fff7abff20b1794ad368
    PC -> target: 1978fcff4000301de70823f08073d360fff7bdff40b14ff08043
      [##################------------------]   52%  0d 00:00:54PC -> target: 1978fcff4100301de7080022c3f80c21c3f81021c3f83825fff7
    PC -> target: 1978fcff4200301de70897ff10b1704b03221a60fff791ff40b1
      [###################-----------------]   54%  0d 00:00:52PC -> target: 1978fcff4300301de7086e4b05221a6001229a6700229a603f22
    PC -> target: 1978fcff4400301de7085a606b4b1b78062b09d16a4b1b681907
      [####################----------------]   55%  0d 00:00:50PC -> target: 1978fcff4500301de70805d1694b1b6803f0f003502b67d0fff7
    PC -> target: 1978fcff4600301de70891ff28b1654b664a1b6803f04f031360
      [####################----------------]   57%  0d 00:00:48PC -> target: 1978fcff4700301de708fff788ff48b14ff08043d3f80024d207
    PC -> target: 1978fcff4800301de70844bf6ff00102c3f800245e4b1b68062b
      [#####################---------------]   59%  0d 00:00:46PC -> target: 1978fcff4900301de70804d15d4b1b68062b00f091805b4ad2f8
    PC -> target: 1978fcff4a00301de708883043f47003c2f88830bff34f8fbff3
      [#####################---------------]   60%  0d 00:00:44PC -> target: 1978fcff4b00301de7086f8f4ff01023d3f80022002a03dbd3f8
    PC -> target: 1978fcff4c00301de7080432002b2fda524b0122c3f80425d3f8
      [######################--------------]   62%  0d 00:00:42PC -> target: 1978fcff4d00301de7080024002afbd04ff010221521c2f80012
    PC -> target: 1978fcff4e00301de708d3f80024002afbd04ff010231522c3f8
      [#######################-------------]   63%  0d 00:00:40PC -> target: 1978fcff4f00301de7080422474b1a46d3f800140029fbd00021
    PC -> target: 1978fcff5000301de708c3f80415d2f80034002bfbd0bff34f8f
      [#######################-------------]   65%  0d 00:00:38PC -> target: 1978fcff5100301de7083e49404bca6802f4e0621343cb60bff3
    PC -> target: 1978fcff5200301de7084f8f00bffde73c4b3c4a1a6008bd4ff0
      [########################------------]   67%  0d 00:00:36PC -> target: 1978fcff5300301de70880523b4bd2f80414c3f82015d2f80814
    PC -> target: 1978fcff5400301de708c3f82415d2f80c14c3f82815d2f81014
      [########################------------]   68%  0d 00:00:35PC -> target: 1978fcff5500301de708c3f82c15d2f81414c3f83015d2f81814
    PC -> target: 1978fcff5600301de708c3f83415d2f81c14c3f84015d2f82014
      [#########################-----------]   70%  0d 00:00:33PC -> target: 1978fcff5700301de708c3f84415d2f82414c3f84815d2f82814
    PC -> target: 1978fcff5800301de708c3f84c15d2f82c14c3f85015d2f83014
      [#########################-----------]   71%  0d 00:00:31PC -> target: 1978fcff5900301de708c3f85415d2f83414c3f86015d2f83814
    PC -> target: 1978fcff5a00301de708c3f86415d2f83c14c3f86815d2f84014
      [##########################----------]   73%  0d 00:00:29PC -> target: 1978fcff5b00301de708c3f86c15d2f84424c3f870254fe7194a
    PC -> target: 1978fcff5c00301de708136843f48063136068e700bf24030010
      [###########################---------]   75%  0d 00:00:27PC -> target: 1978fcff5d00301de7084035014074c007400df0adba44020010
    PC -> target: 1978fcff5e00301de7083c050040f0ed00e0a005004010560040
      [###########################---------]   76%  0d 00:00:26PC -> target: 1978fcff5f00301de708e00f00f0e40f00f0e80f00f058020010
    PC -> target: 1978fcff6000301de708e40e0040300100103401001000ed00e0
      [############################--------]   78%  0d 00:00:24PC -> target: 1978fcff6100301de70800e001400400fa05c83200200090d003
    PC -> target: 1978fcff6200301de70800c000403c1700400649074a074b9b1a
      [############################--------]   80%  0d 00:00:22PC -> target: 1978fcff6300301de70803dd043bc858d050fbdcfff7c3fefff7
    PC -> target: 1978fcff6400301de7081dfe000008670200c832002038330020
      [#############################-------]   81%  0d 00:00:20PC -> target: 1978fcff6500301de708fee7fee7fee7fee7fee7fee7fee7fee7
    PC -> target: 1978fcff6600301de708fee7fee708b5074b044613b10021aff3
      [#############################-------]   83%  0d 00:00:19PC -> target: 1978fcff6700301de7080080054b1868836a03b19847204600f0
    PC -> target: 1978fcff6800301de70831f800bf00000000f866020070b50d4e
      [##############################------]   84%  0d 00:00:17PC -> target: 1978fcff6900301de7080d4ca41ba4100025a54209d10b4e0c4c
    PC -> target: 1978fcff6a00301de70800f022f8a41ba4100025a54205d170bd
      [###############################-----]   86%  0d 00:00:15PC -> target: 1978fcff6b00301de70856f8253098470135eee756f825309847
    PC -> target: 1978fcff6c00301de7080135f2e72c3300202c3300202c330020
      [###############################-----]   88%  0d 00:00:13PC -> target: 1978fcff6d00301de7083033002002440346934200d1704703f8
    PC -> target: 1978fcff6e00301de708011bf9e7fee700bff8b500bff8bc08bc
      [################################----]   89%  0d 00:00:12PC -> target: 1978fcff6f00301de7089e467047f8b500bff8bc08bc9e467047
    PC -> target: 1978fcff7000301de7080338fdd870470000cc32002000000000
      [################################----]   91%  0d 00:00:10PC -> target: 1978fcff7100301de7086cfbff7f010000000090d00300000000
    PC -> target: 1978fcff7200301de70800000000000000000000000000000000
      [#################################---]   92%  0d 00:00:08PC -> target: 1978fcff7300301de70800000000000000000000000000000000
    PC -> target: 1978fcff7400301de70800000000000000000000000000000000
      [##################################--]   94%  0d 00:00:06PC -> target: 1978fcff7500301de70800000000000000000000000000000000
    PC -> target: 1978fcff7600301de70800000000000000000000000000000000
      [##################################--]   96%  0d 00:00:05PC -> target: 1978fcff7700301de70800000000000000000000000025620200
    PC -> target: 1178fcff7800301de7080162020000000000
      [###################################-]   97%  0d 00:00:03PC -> target: 1978fcff7900301de708f732aea6d2320de64969868aeba85e88
    PC -> target: 1978fcff7a00301de708d938a5419f4e68c6468adf2d1063c416
      [###################################-]   99%  0d 00:00:01PC -> target: 1978fcff7b00301de708f64b75aed12b33bccf53bdf88e6a65f4
    PC -> target: 1978fcff7c00301de7087c8295cc145c7eaab915e990600749d0
      [####################################]  100%             DFU upgrade took 106.796000004s
    Device programmed.
    Andreas
  • Hi.
    Opened com-port
    Got echo response
    Device programmed.
    Andreas
