Hi everyone,
Device : nRF52832
SDK version : 14.2
Softdevice : S132 v5.0
I am facing a problem when changing the interrupt priority dynamically. Let me explain the context of my application. My BLE module is basically a bridge between BLE and UART. I am a slave for the BLE and master for the UART.
I would like to have UART priority set to 2 when I am waiting for an answer from the nested device over UART, and UART priority set to 7 when I am not waiting for an answer (since I am the master for that communication).
The code was already developped for another application using a cortex-M4 from NXP and works perfectly fine.
Below you can see the intruction used for that:
Now I am facing a problem since Nordic does not recommend (forbid?) to disable IRQ using __disable_irq() since it blocks the time-critical operation of the softdevice.
But in all documentation I found, it is strongly recommended to disable all IRQ before using the function NVIC_SetPriority.
Actually now my code looks like this :
I am actually using the sd_ wrapper function for the NVIC_SetPriority, since no SVC calls are made inside it I assume that this should not be a problem calling it from interrupt level 2.
Using sd_nvic_critical_region_enter/exit function instead of __disable_irq() is not sufficient if I want to follow the recommendation since it disable only the application interruption.
Do you recommend a workaround to dynamically change the interrupt priority?
This is my first message on the DevZone, I hope that I explained my issue well enough.
