Log latency data in Thread
Hi. I have set up a nine node mesh using Thread and the nRF52840 chips. I am using the COAP example. All my nodes are visible and i am able to send pings between them. I am stuck as to how i can record/log the ping latency between any two nodes. I want the data set consisting of IP addresses of the nodes pinging and the latency for each ping. For example, i will use the syntax:
ping XXXXXXXX 8 100 1, where XX... is the address of the node i am pinging, 8 is the byte size of the ping, 100 is the packet count and 1 is the time between sending each ping.
Please, help. Thank you.
