I am using Fanstel's BM832 bare chip which is based on nrf52832. The bluetooth isnt advertising. I'm using hid keyboard example & SDK 15.2.
You can try to change the clock source from XTAL to RC if you haven't done so already. Look at this post to see how it's done. devzone.nordicsemi.com/.../156345
Hi Hakon,
I made the changes in sdkconfig.h. I also checked https://devzone.nordicsemi.com/f/nordic-q-a/39333/nrf52832-problem-with-without-32-768khz-x-tal-or-other-problem/152344#152344
But these changes did not help.
Have you tried to flash an application that does not use the soft device? If not you can try to flash a simple application, that for instance toggles a gpio pin to make sure it is working.
Yes I tried to toggle an LED which worked! But not the BLE examples!
Are you sure you're using a BM832 - not a BM832A ... ?
Yes I'm using BM832 which uses S132. BM832A uses S112.
Have you stepped through your code in the debugger to see what's happening?
