Development Kit - nrf52
SDK Version - 15.0.0
IDE - Segger Embedded Studio
Computer Platform - Windows 7 - 64 Bit
Setup : I am trying to interface an E Paper Display with the nrf52832 chip.
The issue is that I have a EPD.lib file and an EPD.h which includes the methods to drive the E Paper Display. I've imported both the .h and the .lib file in the project, but I'm still unable to use the methods defined in the .h file. Is there a way this can be done using the .lib file or do I need to change it to some other format like .a?
Below is the code in my EPD.h file
/* Copyright (c) 2015 Nordic Semiconductor. All Rights Reserved.
* The information contained herein is property of Nordic Semiconductor ASA.
* Terms and conditions of usage are described in detail in NORDIC
* SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
* Licensees are granted free, non-transferable use of the information. NO
* WARRANTY of ANY KIND is provided. This heading must NOT be removed from
* the file.
/** @file
* @defgroup app_pwm Pulse-width modulation (PWM)
* @ingroup app_common
* @brief Module for generating a pulse-width modulated output signal.
* @details This module provides a PWM implementation using timers, GPIOTE, and PPI.
* Resource usage:
* - 2 PPI channels per instance + 2 PPI channels per PWM channel.
* - 1 PPI group per instance.
* - 1 GPIOTE channel per PWM channel.
* For example, a PWM instance with two channels will consume 2+4 PPI channels, 1 PPI group, and 2 GPIOTE channels.
* The maximum number of PWM channels per instance is 2.
#ifndef EPD143_H__
#define EPC143_H__
#include <stdint.h>
#include <stdbool.h>
#include <stdio.h>
// EPD E014TT6 //
// GPIO Define
#define EPD_OEI 15
#define EPD_RESET 31
#define EPD_SDO 30
#define EPD_SDI 28
#define EPD_SCL 29
#define EPD_BUSY 22
#define EPD_CSB 27
static uint8_t data_array_jinco[16] = "www.jinco.com.tw";
/***************************** ET014TT6 ************************/
void init_EPD(void);
void TCON_POWER_ON(int VCOM);
void TCON_POWER_OFF(void);
void write_EPD(int nbyte);
//void write_image(int imagedata);
void EPD_PanelClear(void);
void write_image(const unsigned char *img);
void write_EPDBLOCK20(void);
Varun
