nrf52832, sd card and accelerometer.
Hello!
I have both SD Card and accelerometer in same SPI bus. Both of them working like charm if another is not present. I'am using app_sdcard from 52 sdk.
Can i use spi manager for my accelerometer or does that effect to sd card drivers?
I have found that SD Card drivers are using gpio to enable and disable CS but problem is that its uses handler. When i try to use same SPI master the sd card:s handler doesn't like data from accelerometer.
I have tried to add NRFX_SPIM_FLAG_NO_XFER_EVT_HANDLER to modified nrf_drv_spi_transfer, but then i don't get any data out and it still gives me
<error> app: ERROR 3 [NRF_ERROR_INTERNAL] at C:\nrf\components\libraries\sdcard\app_sdcard.c:987
PC at: 0x0002D26B
And error is from app_sdcard spi_handler.
As i did have few pins to spare. I seperated SD Card and accelerometer to own busses and it still does not work.
SD Card setup:
CS: pin 11
SCK: 16
MOSI: 17
MISO: 18
Using SPI 2 instance
Accelerometer:
CS: 12
SCK: 5
MOSI: 4
MISO: 3
Using SPI 1 instance
The one which initializes first works and other is not doing anything.
I have another sensor which uses i2c and it uses TWI instance 0
  • Schematics:
    gleapper.pdf
    Code:
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    * Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
    * All rights reserved.
    * list of conditions and the following disclaimer.
    * Semiconductor ASA integrated circuit in a product or a software update for
    * such product, must reproduce the above copyright notice, this list of
    * conditions and the following disclaimer in the documentation and/or other
    * materials provided with the distribution.
    * contributors may be used to endorse or promote products derived from this
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    What have i missed? In main fatfs_example() works if it is called first and same does initAcc()
  • Hi, what happens if you do not initialize the TWI sensor? The TWI peripheral is shared with the SPI peripheral, so you can't have both SPI0 and TWI0 enabled at the same time. SPI1 and TWI1 etc.
  • And regarding using the same SPI bus with two slaves,  I need to setup a project here to see what happens with the SD-card driver.
    What you could try is to use two different SPI instances for the two slaves, but use the same GPIO configuration. Then you will have to uninitialize and re-initialize the SPI instance every time you want to start a new transfer, but at least the handlers are separate for the different instances.
    First we would have to figure out why you can only enable one SPI instance at a time though. So please try to disable the TWI instance.
  • Hi Stian, I moved my code to "test" enviroment so i'm now only using spi instance 1 and spi instance 2. TWI is not enabled. It's quite frustrating that they are working, but not as together.
  • So it seems I can't have 2 spi masters initialized at the same time.
    Program works if i uninitialize sd card before executing initAcc.
    What would be the best solution to use both at "same" time? Is constantly initializing and unitializing the spi master heavy duty?
1 2 3
