Discovering characteristics on a vs service with 16 vs characterisitcs, but only receiving 7 characteristic
Hi Nordic,
I am currently working on ble_app_interactive on nrf52 DK with the DK as central and a hearingaid as peripheral. I have had some help from you guys to configure my characteristic discovery, so that I can discovery vs characteristics uuids. That is working, but my new problem is that, when discovery on a service with a lot of characteristics, I only see 7 of them, even though there are more, I can even see that the handle range on that service, is 31-65, but what I receive is in the range 32-45. Even if I try on a different service, with also 10+ vs characteristic, I also only get 7 characteristics. Do you know why this is happening?
I think it has something to do with the count I receive. When received characteristic information in on_characteristics_discovery_rsp, I can see that the count is only 7, even though it should be more.
Below is all the commands I have used, I have also added some extra logging for handles and so on:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2018.11.30 12:04:18 =~=~=~=~=~=~=~=~=~=~=~=
uart_cli:~$ BLE app with command line interface example started.
uart_cli:~$ Press Tab to view all available commands.
uart_cli:~$ connect 1uart_cli:~$ uart_cli:~$ <info> app: Scanning
uart_cli:~$ Connected to address: uart_cli:~$ 40 uart_cli:~$ 4F uart_cli:~$ 0C uart_cli:~$ 33 uart_cli:~$ 57 uart_cli:~$ 2E uart_cli:~$
uart_cli:~$ <info> app: CENTRAL: Connected, handle: 0.
uart_cli:~$ <info> peer_manager_handler: Connection secured: role: Central, conn_handle: 0, procedure: Encryption
uart_cli:~$ Current MTU: 158
uart_cli:~$ MTU changed successfully
uart_cli:~$ <info> app: Data length updated to 27 bytes.
uart_cli:~$ gatt services 40:4F:0C:33:57:2E uart_cli:~$ <info> app: GATT Services
uart_cli:~$ <info> app: Services count: 9
uart_cli:~$ Found service UUIDs:
uart_cli:~$ UUID: 1800 type: 0x1 uart_cli:~$ Handle range: 1-9
uart_cli:~$ UUID: 1801 type: 0x1 uart_cli:~$ Generic Attribute uart_cli:~$ Handle range: 12-15
uart_cli:~$ UUID: 180A type: 0x1 uart_cli:~$ Device Information Service uart_cli:~$ Handle range: 16-26
uart_cli:~$ UUID: 180F type: 0x1 uart_cli:~$ Battery Service uart_cli:~$ Handle range: 27-30
uart_cli:~$ UUID: F4BD type: 0x2 uart_cli:~$ MFi Hearing Aid Service uart_cli:~$ Handle range: 31-65
uart_cli:~$ UUID: F2B4 type: 0x3 uart_cli:~$ MFi Authentication Service uart_cli:~$ Handle range: 66-75
uart_cli:~$ UUID: 3049 type: 0x4 uart_cli:~$ Handle range: 76-90
uart_cli:~$ UUID: 2EAF type: 0x5 uart_cli:~$ WDH HI Service uart_cli:~$ Handle range: 91-145
uart_cli:~$ UUID: AE62 type: 0x6 uart_cli:~$ Bonding Service uart_cli:~$ Handle range: 146-156
uart_cli:~$ gatt characteristics 40:4F:0C:33:57:2E F2B4uart_cli:~$ <info> app: Char range: 66-75
uart_cli:~$ <info> app: Number of characteristics: 4
uart_cli:~$ Characteristics count : 4
uart_cli:~$ UUID: BF66 type: 0x7 uart_cli:~$ Parameters:
uart_cli:~$ broadcast: 0 uart_cli:~$ read: 1 uart_cli:~$ write_wo_resp: 0 uart_cli:~$ write: 0 uart_cli:~$ notify: 0 uart_cli:~$ indicate: 0 uart_cli:~$ auth_signed_wr: 0 uart_cli:~$ decl_handle: 67  value_handle: 68
uart_cli:~$ UUID: AEBE type: 0x8 uart_cli:~$ Certificate Part B uart_cli:~$ Parameters:
uart_cli:~$ broadcast: 0 uart_cli:~$ read: 1 uart_cli:~$ write_wo_resp: 0 uart_cli:~$ write: 0 uart_cli:~$ notify: 0 uart_cli:~$ indicate: 0 uart_cli:~$ auth_signed_wr: 0 uart_cli:~$ decl_handle: 69  value_handle: 70
uart_cli:~$ UUID: AEBE type: 0x9 uart_cli:~$ Certificate Part B uart_cli:~$ Parameters:
uart_cli:~$ broadcast: 0 uart_cli:~$ read: 1 uart_cli:~$ write_wo_resp: 0 uart_cli:~$ write: 0 uart_cli:~$ notify: 0 uart_cli:~$ indicate: 0 uart_cli:~$ auth_signed_wr: 0 uart_cli:~$ decl_handle: 71  value_handle: 72
uart_cli:~$ UUID: 9638 type: 0xA uart_cli:~$ Compatibility Version uart_cli:~$ Parameters:
uart_cli:~$ broadcast: 0 uart_cli:~$ read: 1 uart_cli:~$ write_wo_resp: 0 uart_cli:~$ write: 1 uart_cli:~$ notify: 1 uart_cli:~$ indicate: 0 uart_cli:~$ auth_signed_wr: 0 uart_cli:~$ decl_handle: 73  value_handle: 74
uart_cli:~$ <info> app: Discovers Descriptors
uart_cli:~$ No descriptors/No more descriptors
uart_cli:~$ gatt characteristics 40:4F:0C:33:57:2E F2B4    F4BDuart_cli:~$ <info> app: Char range: 31-65
uart_cli:~$ UUID: DFF3 type: 0xB uart_cli:~$ Battery Level uart_cli:~$ Parameters:
uart_cli:~$ broadcast: 0 uart_cli:~$ read: 1 uart_cli:~$ write_wo_resp: 0 uart_cli:~$ write: 0 uart_cli:~$ notify: 1 uart_cli:~$ indicate: 0 uart_cli:~$ auth_signed_wr: 0 uart_cli:~$ decl_handle: 32  value_handle: 33
uart_cli:~$ UUID: AC2F type: 0xC uart_cli:~$ Left/Right uart_cli:~$ Parameters:
uart_cli:~$ broadcast: 0 uart_cli:~$ read: 1 uart_cli:~$ write_wo_resp: 0 uart_cli:~$ write: 0 uart_cli:~$ notify: 0 uart_cli:~$ indicate: 0 uart_cli:~$ auth_signed_wr: 0 uart_cli:~$ decl_handle: 35  value_handle: 36
uart_cli:~$ UUID: 21D3 type: 0xD uart_cli:~$ Hearing Aid ID uart_cli:~$ Parameters:
uart_cli:~$ broadcast: 0 uart_cli:~$ read: 1 uart_cli:~$ write_wo_resp: 0 uart_cli:~$ write: 0 uart_cli:~$ notify: 0 uart_cli:~$ indicate: 0 uart_cli:~$ auth_signed_wr: 0 uart_cli:~$ decl_handle: 37  value_handle: 38
uart_cli:~$ UUID: EB9E type: 0xE uart_cli:~$ Other Hearing Aid ID uart_cli:~$ Parameters:
uart_cli:~$ broadcast: 0 uart_cli:~$ read: 1 uart_cli:~$ write_wo_resp: 0 uart_cli:~$ write: 0 uart_cli:~$ notify: 0 uart_cli:~$ indicate: 0 uart_cli:~$ auth_signed_wr: 0 uart_cli:~$ decl_handle: 39  value_handle: 40
uart_cli:~$ UUID: 94F9 type: 0xF uart_cli:~$ Mic Volume uart_cli:~$ Parameters:
uart_cli:~$ broadcast: 0 uart_cli:~$ read: 1 uart_cli:~$ write_wo_resp: 0 uart_cli:~$ write: 1 uart_cli:~$ notify: 1 uart_cli:~$ indicate: 0 uart_cli:~$ auth_signed_wr: 0 uart_cli:~$ decl_handle: 41  value_handle: 42
uart_cli:~$ UUID: 6200 type: 0x10 uart_cli:~$ 2nd Stream Volume uart_cli:~$ Parameters:
uart_cli:~$ broadcast: 0 uart_cli:~$ read: 1 uart_cli:~$ write_wo_resp: 0 uart_cli:~$ write: 1 uart_cli:~$ notify: 1 uart_cli:~$ indicate: 0 uart_cli:~$ auth_signed_wr: 0 uart_cli:~$ decl_handle: 44  value_handle: 45
uart_cli:~$ UUID: 4275 type: 0x11 uart_cli:~$ Available Programs Bitmask uart_cli:~$ Parameters:
uart_cli:~$ broadcast: 0 uart_cli:~$ read: 1 uart_cli:~$ write_wo_resp: 0 uart_cli:~$ write: 0 uart_cli:~$ notify: 0 uart_cli:~$ indicate: 0 uart_cli:~$ auth_signed_wr: 0 uart_cli:~$ Logs dropped (1)
decl_handle: 47  value_handle: 48
uart_cli:~$ gatt characteristics 40:4F:0C:33:57:2E F4BD    2EAFuart_cli:~$ <info> app: Char range: 91-145
uart_cli:~$ UUID: AC83 type: 0x12 uart_cli:~$ Ear uart_cli:~$ Parameters:
uart_cli:~$ broadcast: 0 uart_cli:~$ read: 1 uart_cli:~$ write_wo_resp: 0 uart_cli:~$ write: 0 uart_cli:~$ notify: 0 uart_cli:~$ indicate: 0 uart_cli:~$ auth_signed_wr: 0 uart_cli:~$ decl_handle: 92  value_handle: 93
uart_cli:~$ UUID: 17FE type: 0x13 uart_cli:~$ HI ID uart_cli:~$ Parameters:
uart_cli:~$ broadcast: 0 uart_cli:~$ read: 1 uart_cli:~$ write_wo_resp: 0 uart_cli:~$ write: 0 uart_cli:~$ notify: 0 uart_cli:~$ indicate: 0 uart_cli:~$ auth_signed_wr: 0 uart_cli:~$ decl_handle: 94  value_handle: 95
uart_cli:~$ UUID: C43D type: 0x14 uart_cli:~$ Partner HI ID uart_cli:~$ Parameters:
uart_cli:~$ broadcast: 0 uart_cli:~$ read: 1 uart_cli:~$ write_wo_resp: 0 uart_cli:~$ write: 0 uart_cli:~$ notify: 0 uart_cli:~$ indicate: 0 uart_cli:~$ auth_signed_wr: 0 uart_cli:~$ decl_handle: 96  value_handle: 97
uart_cli:~$ UUID: CC73 type: 0x15 uart_cli:~$ Basic Control Command uart_cli:~$ Parameters:
uart_cli:~$ broadcast: 0 uart_cli:~$ read: 1 uart_cli:~$ write_wo_resp: 0 uart_cli:~$ write: 0 uart_cli:~$ notify: 0 uart_cli:~$ indicate: 0 uart_cli:~$ auth_signed_wr: 0 uart_cli:~$ decl_handle: 98  value_handle: 99
uart_cli:~$ UUID: 58A1 type: 0x16 uart_cli:~$ Available Programs uart_cli:~$ Parameters:
uart_cli:~$ broadcast: 0 uart_cli:~$ read: 0 uart_cli:~$ write_wo_resp: 1 uart_cli:~$ write: 1 uart_cli:~$ notify: 0 uart_cli:~$ indicate: 0 uart_cli:~$ auth_signed_wr: 0 uart_cli:~$ decl_handle: 100  value_handle: 101
uart_cli:~$ UUID: 7A3E type: 0x17 uart_cli:~$ Selected Programs ID uart_cli:~$ Parameters:
uart_cli:~$ broadcast: 0 uart_cli:~$ read: 1 uart_cli:~$ write_wo_resp: 0 uart_cli:~$ write: 0 uart_cli:~$ notify: 0 uart_cli:~$ indicate: 0 uart_cli:~$ auth_signed_wr: 0 uart_cli:~$ decl_handle: 102  value_handle: 103
uart_cli:~$ UUID: A64E type: 0x18 uart_cli:~$ Program Info uart_cli:~$ Parameters:
uart_cli:~$ broadcast: 0 uart_cli:~$ read: 1 uart_cli:~$ write_wo_resp: 0 uart_cli:~$ write: 1 uart_cli:~$ notify: 1 uart_cli:~$ indicate: 0 uart_cli:~$ auth_signed_wr: 0 uart_cli:~$ Logs dropped (1)
decl_handle: 104  value_handle: 105
uart_cli:~$
