nrfconnect for desktop error
Hello Nordic,
I have already used an earlier version of nrfconnect on this lcomputer( windows 10 language PT-BR).
After upgrading to 2.6.1 I got the the error below:
Translating to english.
" %1 is not a valid Win32 app"
  • Sorry for late reply.Now I am testing j-link lite on Linux.
    J-link version is 6.40 and nRFConnect 2.6.0
    Are you sure that j-link lite  has serial port ?
    I can use a full j-link on the computer
    2018-12-14T11:01:35.758Z INFO Application data folder: /home/marciomontenegro/.config/nrfconnect/pc-nrfconnect-programmer
    2018-12-14T11:01:35.850Z DEBUG App pc-nrfconnect-programmer v1.0.0 official
    2018-12-14T11:01:35.850Z DEBUG App path: /home/marciomontenegro/.nrfconnect-apps/node_modules/pc-nrfconnect-programmer
    2018-12-14T11:01:35.850Z DEBUG nRFConnect 2.6.0 is supported by the app (^2.6.0)
    2018-12-14T11:01:35.850Z DEBUG nRFConnect path: /tmp/.mount_nrfcon4VNqTT/app/resources/app.asar
    2018-12-14T11:01:35.850Z DEBUG HomeDir: /home/marciomontenegro
    2018-12-14T11:01:35.850Z DEBUG TmpDir: /tmp
    2018-12-14T11:01:35.856Z INFO Using nrfjprog library 9.8.1, pc-nrfjprog-js 1.4.1
    2018-12-14T11:01:36.152Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS0
    2018-12-14T11:01:36.152Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS1
    2018-12-14T11:01:36.152Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS10
    2018-12-14T11:01:36.152Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS11
    2018-12-14T11:01:36.152Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS12
    2018-12-14T11:01:36.152Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS13
    2018-12-14T11:01:36.152Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS14
    2018-12-14T11:01:36.153Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS15
    2018-12-14T11:01:36.153Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS16
    2018-12-14T11:01:36.153Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS17
    2018-12-14T11:01:36.153Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS18
    2018-12-14T11:01:36.153Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS19
    2018-12-14T11:01:36.153Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS2
    2018-12-14T11:01:36.153Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS20
    2018-12-14T11:01:36.153Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS21
    2018-12-14T11:01:36.153Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS22
    2018-12-14T11:01:36.153Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS23
    2018-12-14T11:01:36.153Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS24
    2018-12-14T11:01:36.153Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS25
    2018-12-14T11:01:36.153Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS26
    2018-12-14T11:01:36.153Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS27
    2018-12-14T11:01:36.154Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS28
    2018-12-14T11:01:36.154Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS29
    2018-12-14T11:01:36.154Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS3
    2018-12-14T11:01:36.154Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS30
    2018-12-14T11:01:36.154Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS31
    2018-12-14T11:01:36.154Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS4
    2018-12-14T11:01:36.154Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS5
    2018-12-14T11:01:36.154Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS6
    2018-12-14T11:01:36.154Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS7
    2018-12-14T11:01:36.154Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS8
    2018-12-14T11:01:36.154Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS9
    2018-12-14T11:01:41.151Z ERROR Error while setting up device 000229001370: Cannot read property 'comName' of undefined
    2018-12-14T11:01:41.151Z INFO Target device closed.
  • Hi Marcio,
    If you have issues using the J-link lite I would just suggest you stick with the full J-Link.
