[nRF51 to nRF52 Migration] TWI issues
I am currently migrating my controller from nRF51 to nRF52832 . I am facing an issue where in when I try to do an TWI communication with MPU9250 on nRF52 the code gets stuck in the TWI commands.
I am using SDK12.3.
The code that I am using to access the Sensor through nRF52 is same as the one used for accessing the sensor through nRF51. Can you let me know if I need to make any change to the TWI access instruction to allow for communication between nRF52 and MPU9250.
Thanks
    Can you first confirm that the twi example in SDKv12.3 works "as-is", just to rule out hardware issues (pins, pull-ups, address etc).
    Kenneth
  • Hi Kenneth,
    I used used the twi example in SDKv12.3 and modified the code to read the who am I register in MPU9250 .
    I am getting an "NRF_ERROR_BUSY" error when I try to read the register.
    So the code progress all the way till line 44 and gets stuck there.
    Here is the code snippet.
     * @brief TWI initialization.
    void twi_init (void)
        ret_code_t err_code;
        const nrf_drv_twi_config_t twi_lm75b_config = {
           .scl                = SCL_PIN_NUMBER,
           .sda                = SDA_PIN_NUMBER,
           .frequency          = NRF_TWI_FREQ_400K,
           .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
           .clear_bus_init     = false
        err_code = nrf_drv_twi_init(&m_twi, &twi_lm75b_config, twi_handler, NULL);
        nrf_drv_twi_enable(&m_twi);
     * @brief Function for reading data from MPU9250 sensor.
    static void read_whi_data()
        m_xfer_done = false;
        uint8_t data[2] ={0,0};
        err_code= nrf_drv_twi_tx(&m_twi,0x68,&who_am_i_reg,1,1);
        if (err_code!=NRF_SUCCESS)
            CYAN_ON();
            while(1){}
        BLUE_ON();
        err_code = nrf_drv_twi_rx(&m_twi,0x68,data,1);
        if (err_code == NRF_ERROR_BUSY)
            WHITE_ON();
            while(1){}
        if (data[0] == 0x71)
            PURPLE_ON();
            GREEN_ON();
        LED_init();
        twi_init();
        RED_ON();
        nrf_delay_ms(1000);
        read_whi_data();
        while (true)
            nrf_delay_ms(500);
            do
                __WFE();
            }while (m_xfer_done == false);
  • I have 10K resistors pulling up my SCL and SDA lines to VDD. But when I check the voltage (without enabling TWI) my SDA is not pulled up to VDD.
    I have connected SDA to pin 9 which is the NFC1 input. Does this cause any issues ? My SCL is connected to Pin 8 and that is pulled up to VDD.
  • Ok, I believe the issue was that I was using the NCF 1 pin with disabling the NFC. Once I added the preprocessor directive CONFIG_NFCT_PINS_AS_GPIOS.
    I was able to get the Sensor working.
