multilink [ble_app_uart] - [ble_app_multilink_central](3)
OS :Windows7
HARD :(Taiyo Yuden)EBSHSN Series Evaluation Board
CPU :(Nordic) nRF52832 / ARMRegistered CortexTm-M4F 32 bit processor 28-pin Land Grid Array / 15GPIOs / SWD
Soft Ver:nRF5_SDK_15.0.0_a53641a
Using [ble_app_multilink_central] and [ble_app_uart_c], I created a program that performs multi-link UART communication, but immediately after the first peripheral was linked
Error 0x011 will be issued.
Please tell me the possible causes.
Thanking you in advance.
/* multilink uart process            										 */
#include <stdio.h>
#include <stdint.h>
#include "nordic_common.h"
#include "ble_db_discovery.h"
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_hci.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "ble_advdata.h"
#include "nrf_ble_gatt.h"
#include "nrf_pwr_mgmt.h"
/*-< multi setting >-*/
#include <string.h>
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "ble_conn_state.h"
/*-< uart setting >-*/
#include <stdbool.h>
#include "app_error.h"
#include "app_uart.h"
#include "app_util.h"
#include "ble_gap.h"
#include "nrf_sdh_soc.h"
#include "ble_nus_c.h"
/*-< log setting >-*/
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG    1                                       /**< A tag that refers to the BLE stack configuration we set with @ref sd_ble_cfg_set. Default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
#define APP_BLE_OBSERVER_PRIO   3                                       /**< Application's BLE observer priority. You shoulnd't need to modify this value. */
#define SCAN_INTERVAL           0x00A0                                  /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW             0x0050                                  /**< Determines scan window in units of 0.625 millisecond. */
#define SCAN_DURATION           0x0000                                  /**< Timout when scanning. 0x0000 disables timeout. */
#define MIN_CONNECTION_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS)         /**< Determines minimum connection interval in millisecond. */
#define MAX_CONNECTION_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS)         /**< Determines maximum connection interval in millisecond. */
#define SLAVE_LATENCY           0                                       /**< Determines slave latency in counts of connection events. */
#define SUPERVISION_TIMEOUT     MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Determines supervision time-out in units of 10 millisecond. */
#define UART_TX_BUF_SIZE        256                                     /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE        256                                     /**< UART RX buffer size. */
#define NUS_SERVICE_UUID_TYPE   BLE_UUID_TYPE_VENDOR_BEGIN              /**< UUID type for the Nordic UART Service (vendor specific). */
#define ECHOBACK_BLE_UART_DATA  0                                       /**< Echo the UART data that is received over the Nordic UART Service back to the sender. */
NRF_BLE_GATT_DEF(m_gatt);                                          		/**< GATT module instance. */
BLE_NUS_C_ARRAY_DEF(m_ble_nus_c, NRF_SDH_BLE_CENTRAL_LINK_COUNT);		/**< BLE NUS service client instance. */
BLE_DB_DISCOVERY_ARRAY_DEF(m_db_disc,  NRF_SDH_BLE_CENTRAL_LINK_COUNT);	/**< DB discovery module instance. */
static char const m_target_periph_name[] = "Nordic_UART";				/**< Name of the device we try to connect to. This name is searched for in the scan report data*/
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
/**@brief NUS uuid. */
#if 0
static ble_uuid_t const m_nus_uuid = {
    .uuid = BLE_UUID_NUS_SERVICE,
    .type = NUS_SERVICE_UUID_TYPE
static uint8_t m_scan_buffer_data[BLE_GAP_SCAN_BUFFER_MIN]; /**< buffer where advertising reports will be stored by the SoftDevice. */
/**@brief Pointer to the buffer where advertising reports will be stored by the SoftDevice. */
static ble_data_t m_scan_buffer =
    m_scan_buffer_data,
/** @brief Parameters used when scanning. */
static ble_gap_scan_params_t const m_scan_params =
    .active   = 0,
    .interval = SCAN_INTERVAL,
    .window   = SCAN_WINDOW,
    .timeout          = SCAN_DURATION,
    .scan_phys        = BLE_GAP_PHY_1MBPS,
    .filter_policy    = BLE_GAP_SCAN_FP_ACCEPT_ALL,
/**@brief Connection parameters requested for connection. */
static ble_gap_conn_params_t const m_connection_param =
    (uint16_t)MIN_CONNECTION_INTERVAL,
    (uint16_t)MAX_CONNECTION_INTERVAL,
    (uint16_t)SLAVE_LATENCY,
    (uint16_t)SUPERVISION_TIMEOUT
/**@brief Function to handle asserts in the SoftDevice.
 * @param[in] line_num     Line number of the failing ASSERT call.
 * @param[in] p_file_name  File name of the failing ASSERT call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function to start scanning. */
static void scan_start(void)
    ret_code_t ret;
    (void) sd_ble_gap_scan_stop();			/* multlink function */
    NRF_LOG_INFO("Start scanning for device name %s.", (uint32_t)m_target_periph_name);
    ret = sd_ble_gap_scan_start(&m_scan_params, &m_scan_buffer);
    APP_ERROR_CHECK(ret);
    // Turn on the LED to signal scanning.
//    bsp_board_led_on(CENTRAL_SCANNING_LED);
/**@brief Function for handling characters received by the Nordic UART Service.
 * @details This function takes a list of characters of length data_len and prints the characters out on UART.
 *          If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
    ret_code_t ret_val;
    NRF_LOG_DEBUG("Receiving data.");
    NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
    for (uint32_t i = 0; i < data_len; i++)
         do
            ret_val = app_uart_put(p_data[i]);
            if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
                NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
                APP_ERROR_CHECK(ret_val);
        } while (ret_val == NRF_ERROR_BUSY);
    if (p_data[data_len-1] == '\r')
        while (app_uart_put('\n') == NRF_ERROR_BUSY);
/*-< Echo Back Proc >-*/
    if (ECHOBACK_BLE_UART_DATA)
		for (uint32_t i = 0; i< NRF_SDH_BLE_CENTRAL_LINK_COUNT; i++)
			// Send data back to peripheral.
			do
				ret_val = ble_nus_c_string_send(&m_ble_nus_c[i], p_data, data_len);
					NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    static uint16_t index = 0;
    uint32_t ret_val;
    switch (p_event->evt_type)
        /**@snippet [Handling data from UART] */
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
					do
						ret_val = ble_nus_c_string_send(&m_ble_nus_c[i], data_array, index);
						if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_BUSY) )
				index = 0;
            NRF_LOG_ERROR("Communication error occurred while handling UART.");
        case APP_UART_FIFO_ERROR:
            NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
/**@brief Callback handling NUS Client events.
 * @details This function is called to notify the application of NUS client events.
 * @param[in]   p_ble_nus_c   NUS Client Handle. This identifies the NUS client
 * @param[in]   p_ble_nus_evt Pointer to the NUS Client event.
/**@snippet [Handling events from the ble_nus_c module] */
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
    ret_code_t err_code;
    switch (p_ble_nus_evt->evt_type)
        case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
			err_code = app_button_enable();
            NRF_LOG_INFO("Discovery complete.");
            err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
            err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
            NRF_LOG_INFO("Connected to device with Nordic UART Service.");
        case BLE_NUS_C_EVT_NUS_TX_EVT:
            ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
		case BLE_NUS_C_EVT_DISCONNECTED:
			NRF_LOG_INFO("Disconnected.");
			scan_start();
            // No implementation needed.
/**@brief Function for handling the advertising report BLE event.
 * @param[in] p_adv_report  Advertising report from the SoftDevice.
static void on_adv_report(ble_gap_evt_adv_report_t const * p_adv_report)
    if (ble_advdata_name_find(p_adv_report->data.p_data,
								p_adv_report->data.len, m_target_periph_name))
        // Name is a match, initiate connection.
        err_code = sd_ble_gap_connect(&p_adv_report->peer_addr,
                                      &m_scan_params,
                                      &m_connection_param,
                                      APP_BLE_CONN_CFG_TAG);
        if (err_code != NRF_SUCCESS)
            NRF_LOG_ERROR("Connection Request Failed, reason %d", err_code);
        err_code = sd_ble_gap_scan_start(NULL, &m_scan_buffer);
    // For readability.
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        // Upon connection, check which peripheral has connected, initiate DB
        // discovery, update LEDs status and resume scanning if necessary.
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connection 0x%x established, starting DB discovery.",
                         p_gap_evt->conn_handle);
            APP_ERROR_CHECK_BOOL(p_gap_evt->conn_handle < NRF_SDH_BLE_CENTRAL_LINK_COUNT);
			err_code = ble_nus_c_handles_assign(&m_ble_nus_c[p_gap_evt->conn_handle],
												p_ble_evt->evt.gap_evt.conn_handle, NULL);
            err_code = ble_db_discovery_start(&m_db_disc[p_gap_evt->conn_handle],
												p_ble_evt->evt.gap_evt.conn_handle);
			if (err_code != NRF_ERROR_BUSY)
            // Update LEDs status, and check if we should be looking for more
            // peripherals to connect to.
            if (ble_conn_state_central_conn_count() != NRF_SDH_BLE_CENTRAL_LINK_COUNT)
                scan_start();
        } break; // BLE_GAP_EVT_CONNECTED
        // Upon disconnection, reset the connection handle of the peer which disconnected, update
        // the LEDs status and start scanning again.
            NRF_LOG_INFO("LBS central link 0x%x disconnected (reason: 0x%x)",
                         p_gap_evt->conn_handle,
                         p_gap_evt->params.disconnected.reason);
            if (ble_conn_state_central_conn_count() == 0)
                err_code = app_button_disable();
            // Start scanning
            scan_start();
        } break;
        case BLE_GAP_EVT_ADV_REPORT:
            on_adv_report(&p_gap_evt->params.adv_report);
        case BLE_GAP_EVT_TIMEOUT:
            // We have not specified a timeout for scanning, so only connection attemps can timeout.
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                NRF_LOG_DEBUG("Connection request timed out.");
        } break;
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            NRF_LOG_DEBUG("BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST.");
            // Accept parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                        &p_gap_evt->params.conn_param_update_request.conn_params);
        } break;
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        } break;
        case BLE_GATTS_EVT_TIMEOUT:
        } break;
static void nus_c_init(void)
    ble_nus_c_init_t nus_c_init_obj;
    nus_c_init_obj.evt_handler = ble_nus_c_evt_handler;
     for (uint32_t i = 0; i < NRF_SDH_BLE_CENTRAL_LINK_COUNT; i++)
		err_code = ble_nus_c_init(&m_ble_nus_c[i], &nus_c_init_obj);
 * @details Initializes the SoftDevice and the BLE event interrupts.
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling database discovery events.
 * @details This function is callback function to handle events from the database discovery module.
 *          Depending on the UUIDs that are discovered, this function should forward the events
 *          to their respective services.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    NRF_LOG_DEBUG("call to ble_lbs_on_db_disc_evt for instance %d and link 0x%x!",
                  p_evt->conn_handle,
    ble_nus_c_on_db_disc_evt(&m_ble_nus_c[p_evt->conn_handle], p_evt);		/* BLE uart */
/** @brief Database discovery initialization.
static void db_discovery_init(void)
    ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
/**@brief Function for initializing the UART. */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = UART_BAUDRATE_BAUDRATE_Baud115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
 * @details Handle any pending log operation(s), then sleep until the next event occurs.
        nrf_pwr_mgmt_run();
/** @brief Function for initializing the log module.
static void log_init(void)
/** @brief Function for initializing the timer.
static void timer_init(void)
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
        NRF_LOG_INFO("ATT MTU exchange completed.");
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
/*-< Initialize. >-*/
    log_init();
    timer_init();
    power_management_init();
    ble_stack_init();
    gatt_init();
    db_discovery_init();
    ble_conn_state_init();
/*-< uart config >-*/
    uart_init();
    nus_c_init();
/*-< Start execution. >-*/
    NRF_LOG_INFO("Multilink example started.");
    scan_start();
    for (;;)
        idle_state_handle();
  • Hi.
    This is because of the API sd_ble_gattc_write():
    /**@brief Perform a Write (Characteristic Value or Descriptor, with or without response, signed or not, long or reliable) procedure.
     * @details This function can perform all write procedures described in GATT.
     * @note    Only one write with response procedure can be ongoing per connection at a time.
     *          If the application tries to write with response while another write with response procedure is ongoing,
     *          the function call will return @ref NRF_ERROR_BUSY.
     *          A @ref BLE_GATTC_EVT_WRITE_RSP event will be issued as soon as the write response arrives from the peer.
     * @note    The number of Write without Response that can be queued is configured by @ref ble_gattc_conn_cfg_t::write_cmd_tx_queue_size
     *          When the queue is full, the function call will return @ref NRF_ERROR_RESOURCES.
     *          A @ref BLE_GATTC_EVT_WRITE_CMD_TX_COMPLETE event will be issued as soon as the transmission of the write without response is complete.
     * @note    The application can keep track of the available queue element count for writes without responses by following the procedure below:
     *          - Store initial queue element count in a variable.
     *          - Decrement the variable, which stores the currently available queue element count, by one when a call to this function returns @ref NRF_SUCCESS.
     *          - Increment the variable, which stores the current available queue element count, by the count variable in @ref BLE_GATTC_EVT_WRITE_CMD_TX_COMPLETE event.
     * @events
     * @event{@ref BLE_GATTC_EVT_WRITE_CMD_TX_COMPLETE, Write without response transmission complete.}
     * @event{@ref BLE_GATTC_EVT_WRITE_RSP, Write response received from the peer.}
     * @endevents
     * @mscs
     * @mmsc{@ref BLE_GATTC_VALUE_WRITE_WITHOUT_RESP_MSC}
     * @mmsc{@ref BLE_GATTC_VALUE_WRITE_MSC}
     * @mmsc{@ref BLE_GATTC_VALUE_LONG_WRITE_MSC}
     * @mmsc{@ref BLE_GATTC_VALUE_RELIABLE_WRITE_MSC}
     * @endmscs
     * @param[in] conn_handle The connection handle identifying the connection to perform this procedure on.
     * @param[in] p_write_params A pointer to a write parameters structure.
     * @retval ::NRF_SUCCESS Successfully started the Write procedure.
     * @retval ::BLE_ERROR_INVALID_CONN_HANDLE Invalid Connection Handle.
     * @retval ::NRF_ERROR_INVALID_STATE Invalid Connection State.
     * @retval ::NRF_ERROR_INVALID_ADDR Invalid pointer supplied.
     * @retval ::NRF_ERROR_INVALID_PARAM Invalid parameter(s) supplied.
     * @retval ::NRF_ERROR_DATA_SIZE Invalid data size(s) supplied.
     * @retval ::NRF_ERROR_BUSY For write with response, procedure already in progress. Wait for a @ref BLE_GATTC_EVT_WRITE_RSP event and retry.
     * @retval ::NRF_ERROR_RESOURCES Too many writes without responses queued.
     *                               Wait for a @ref BLE_GATTC_EVT_WRITE_CMD_TX_COMPLETE event and retry.
     * @retval ::NRF_ERROR_TIMEOUT There has been a GATT procedure timeout. No new GATT procedure can be performed without reestablishing the connection.
    SVCALL(SD_BLE_GATTC_WRITE, uint32_t, sd_ble_gattc_write(uint16_t conn_handle, ble_gattc_write_params_t const *p_write_params));
    Try to modify your ble_nus_c_evt_handler() like this:
                if(err_code == NRF_ERROR_BUSY)
                  retry_operation_tx_notif_enable = true;
            case BLE_GATTC_EVT_WRITE_RSP:
                if(retry_operation_tx_notif_enable == true)
                    if(err_code != NRF_ERROR_BUSY)
                        retry_operation_tx_notif_enable = false;
             }  break;
                scan_start();
    This should work.
    Andreas
  • I was able to avoid errors
    Thank you very much
  • This program does not support pairing, please tell me how to make pairing support.
    Please tell me the method of operation below.
    1) Pairing is started
    2) Pairing stop
    3) Pairing time setting
    That's all, thank you.
  • Hi.
    Can you please create a new ticket for this question?
    I'm closing this ticket because it is very old.
    Andreas
