When i try to add RSSI viewer app in nrf connect it shows error
Unable to install: Unable to download developer.nordicsemi.com/.../pc-nrfconnect-rssi: net::ERR_CONNECTION_RESET
I am missing somewhere?
Does it happen only for the RSSI viewer, or does it happen for other nRF Connect apps as well?
Terje
yes for all apps RSSI viewer, Programmer, power profiler etc.
I am sorry for the delay.
This sounds a bit strange.
The only thing we can think of is that there might be some blocking of the network traffic for the particular application, enforced by firewall and/or antivirus, either on your machine or on the network.
Do you have any form of firewall and/or antivirus, for which you can check the logs (or ask your system administrator to check the logs)?
Has this worked previously on the same pc and network?
Does it work on a separate network?
Do you see similar problems with other PCs on the same network?
Terje
I have checked the same things on another network on linux PC. same problem faced.
Yes Before updates it works fine in my PC.
It does not work on separate network. initially, i works on window PC. but now i am use linux system with different network same problem i face.
Did it work on Windows, but not on Linux?
What GNU/Linux distribution and version?
Terje
