SYSTEM OFF
Hi, I would like to ask how can i get the current consumption that was stated in the datasheet which is 0.7uA  and the value I get from the reading is about 8-9 uA.
#include "boards.h"
* @brief Function for application main entry.
NRF_POWER->SYSTEMOFF = 1;
Is this the right code as mention above?? Do I need to do any configuration in the other part of the FW or HW?
I am using the example code from : nRF5_SDK_14.2.0_17b948a\examples\peripheral\template_project
Thanks for helping!
Parents Reply
  • No, that is not your measurement setup. Your measurement setup is a description of the tools you use to measure, which measurement techniques your are using and how you connect the DUT to your measurement equipment.
    Are you using a power analyzer?
    Are you using an amperemeter or multimeter?
    Are you using a scope with current probe?
    Are you measuring voltage drop over resistor?
    Are you using the power profiler kit?
    Which hardware are you using for the chip? Is this a custom board? If so, please post schematics.
    If you are using a development kit, please give me the name of the development kit and the version.
    What type of power source are you using? USB, external voltage supply, battery? At which voltage are you powering the board?
    Which external components have you connected to the board? Are these always powered? Are you able to measure current without these connected?
    How do you connect your measurement device to the board? Which header are you using?
    If using a Nordic DK, how did you prepare the board for current measurements? Did you cut any solder bridges? Did you follow the user guide on the infocenter?
    I need some more info here, otherwise I'm not able to help you...
