AfterIi stop pwm and uninit pwm, I can't disable a pin left high by the PWM. I am using sdk16 with softdevice 6.0.0 proximity example.
Could you post the code you use to disable the pin?
ret_code_t err_code;
app_pwm_disable(&PWM1);
err_code = app_pwm_uninit(&PWM1);
nrf_gpio_cfg_output(BUZZER);
nrf_gpio_pin_clear(BUZZER);
ret_code_t app_pwm_uninit(app_pwm_t const * const p_instance)
app_pwm_cb_t * p_cb = p_instance->p_cb;
if (p_cb->state == NRFX_DRV_STATE_POWERED_ON)
app_pwm_disable(p_instance);
else if (p_cb->state == NRFX_DRV_STATE_UNINITIALIZED)
pwm_dealloc(p_instance);
p_cb->state = NRFX_DRV_STATE_UNINITIALIZED;
return NRF_SUCCESS;
void pwm_stop(void) {
1) So you are trying to set the pin low?
2) Do you get any error-codes returned somewhere?
3) What pin number is "BUZZER" ?
4) Maybe it's the buzzer that is pulling the pin high ?
The buzzer pin number is 20 . Not gtting any error code
