mesk SDK 2.2.0 example light_switch_proxy_server publish issue
HI, team.
I use two nrf52840 PDK run the example light switch, light switch proxy server and client.
for the light witch proxy client, when press button 0 it will call app_onoff_status_publish() to send msg to server board and set or clear the LED of server board.
but what can I do if I want send message to server board? Could I just call the function app_onoff_status_publish ()?
I try to call app_onoff_status_publish() at main() like:
while(1)
    nrf_delay_ms(5000);
    button_event_handler(0);
 provisioned and set publish address,  after reset ,5 seconds later the Error occurred.
app_error_weak.c,   95, Mesh assert at 0x0002AD0A (:0)
it seem that NRF_MESH_ASSERT_DEBUG(bearer_event_in_correct_irq_priority()) at timer_scheduler.c line 213.
But if I press the button 0 before 5 seconds , without reset , there is not error occurred .
I still can not figure it out.
  • Hi Enzo,
    To send a message from the server board to the client board you need to implement both the client and server model. We have an example on Github which sets a light switch client server proxy here https://github.com/NordicPlayground/nrf52-mesh-light-switch-client-server-proxy
    Follow the step by step guide in the Mesh Hands-on pdf and see if that works for you.
    Best Regards,
    Marjeris
  • Hi msromero,
    Thanks for your reply.
    I've already run this example and it works fine.
    I made some changes.
    To implement UART model I add uart_init() and uart_event_handle() to project.
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
    #if defined (UART_PRESENT)
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                         APP_IRQ_PRIORITY_HIGH,//  APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        static uint8_t data_array[UART_DATA_LEN_MAX];
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                      user_readyToPublishTag=1;
            case APP_UART_FIFO_ERROR:
    Then add uart_init() to mian(),When the program is running the UART works fine.
    My purpose is when I get UART data I can call generic_on_off_client_set_unreliable() to set or reset LED.
    Then I add this code to mian()
    if(user_readyToPublishTag==1)
      m_on_off_button_flag=!m_on_off_button_flag;
      generic_on_off_client_set_unreliable(&m_client,
                                                 m_on_off_button_flag,
                                                GROUP_MSG_REPEAT_COUNT);
      user_readyToPublishTag=0;
    So here's the process when I get UART data the value user_readyToPublishTag will be set and then in the main() the function generic_on_off_client_set_unreliable() will be called.
    But I found the same errror with this question I post.
    after every thing is configured.
    I power off the PDK board.Then power it on.If I get UART data first and call generic_on_off_client_set_unreliable(). Then I get this error. But if I press button 0 first ,generic_on_off_client_set_unreliable() will be called at button_event_handler(). there is no error. And then whenever I get UART data there's no error.
    My English is not good, I hope you can understand me
