nRF52840 output the 32.768kHz clock on any GPIO in SPI Communication.
Dear Nordic Developer Zone,
I am working on MAX30003 ECG (https://datasheets.maximintegrated.com/en/ds/MAX30003.pdf)  with Nrf52840-DK. My sensor is work on the 32.768kHz external clock.
but in Nrf I don't know which GPIO_PIN is assigned for that.
I visited below link but I unable to find solutions:
https://devzone.nordicsemi.com/f/nordic-q-a/23474/nrf52832-fclk-pin/92210#92210
https://devzone.nordicsemi.com/f/nordic-q-a/15996/can-the-nrf52-output-the-32-768khz-clock-on-a-gpio
I am referring (SDK15.2 -PCA10056-spi code)
I have some questions about that:
1) Can I do the merging of timer and gpiote example code into SPI?
2) please give me detail about how to generate 32.768kHz clock ?
I have stuck  on below issue,
https://maximsupport.microsoftcrmportals.com/en-us/knowledgebase/article/000096610
Rohit Patil
  • " But if I merge this code into my Ble_app_uart I am not getting the frequency. "
    I need more information on this issue.
  • I need more information on this issue.
    OK;
    I am working on one sensor which is required 32KHz clock frequency. so I generated 32KHz frequency on one of NRF GPIO Pin using GPIOTE example.
    But I have to merge this code into Ble_app_uart, because of my plan to take sensor data using Bluetooth, so if I merge GPIOTE code (Which is already generated 32.0KHz Frequency) into BLE_APP_UART (SDK15.2.0- PCA10056-S140).
     But when I merge it with my working ble_app_uart code then GPIOTE stop working. it can't show 32.0KHz frequency, so please help me with these issues.
    please check my below code.
    Ble_App_Uart + GPIOTE
    /*Working ECG And RR Interval Code with Bluetooth and Pushing data on Server and Generating Interrupt (Timer) */
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrfx_spi.h"
    #include "nrf_drv_spi.h"
    #include "nrfx_spim.h"
    #include "nrf_delay.h"
    #include "boards.h"
    #include "app_error.h"
    #include <string.h>
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "stdio.h"
    //#include "app_uart.h"
    //#include "nrf_uart.h"
    #include <nrfx_ppi.h>
    #include <stdbool.h>
    #include <stdint.h>
    #include "nrf.h"
    #include "nrf_drv_timer.h"
    #include "bsp.h"
    #include "nrf_gpiote.h"
    #include "nrf_gpio.h"
    #include "boards.h"
    #include "nrf_drv_ppi.h"
    #include "nrf_drv_gpiote.h"
    #if defined (UART_PRESENT)
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "ECG_BLE_Timer_RR"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    #define SPI_SCK_PIN 3
    #define SPI_MISO_PIN 28
    #define SPI_MOSI_PIN 4
    #define SPI_SS_PIN 29
    #define   STATUS          0x01
    #define   EN_INT          0x02
    #define   EN_INT2         0x03
    #define   MNGR_INT        0x04
    #define   MNGR_DYN        0x05
    #define   SW_RST          0x08
    #define   SYNCH           0x09
    #define   FIFO_RST        0x0A
    #define   INFO            0x0F
    #define   CNFG_GEN        0x10
    #define   CNFG_CAL        0x12
    #define   CNFG_EMUX       0x14
    #define   CNFG_ECG        0x15
    #define   CNFG_RTOR1      0x1D
    #define   CNFG_RTOR2      0x1E
    #define   ECG_FIFO_BURST  0x20
    #define   ECG_FIFO        0x21
    #define   RTOR            0x25
    #define   NO_OP           0x7F
    #define SPI_INSTANCE  0 /**< SPI instance index. */
     const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
     volatile bool spi_xfer_done;  /**< Flag used to indicate that SPI instance completed the transfer. */
     uint8_t       m_tx_buf[4] = {0x00, 0x00, 0x00, 0x00};           /**< TX buffer. */
     uint8_t       m_rx_buf[4];    /**< RX buffer. */
    static const uint8_t m_length = sizeof(m_tx_buf);        /**< Transfer length. */
     uint32_t datareturn1 = 0x00;
     uint32_t datareturn2 = 0x00;
     uint32_t RR_Interval = 0x00;
     uint32_t HR_Read = 0x00;
     const nrf_drv_timer_t TIMER_LED = NRF_DRV_TIMER_INSTANCE(2);
     uint32_t i=0;
        uint32_t err_code;
    	  uint8_t ARRAY[10];
        uint16_t size = 9;
        uint32_t err_code1;
        uint8_t ARRAY1[3];
        uint16_t size1 = 2;
        uint32_t HR;
        uint8_t ARRAY2[3];
        uint16_t size2 = 3;
    #ifdef ARDUINO_1_PIN
        #define GPIO_OUTPUT_PIN_NUMBER ARDUINO_1_PIN  /**< Pin number for output. */
    #ifndef GPIO_OUTPUT_PIN_NUMBER
        #error "Please indicate output pin"
    static nrf_drv_timer_t timer = NRF_DRV_TIMER_INSTANCE(0);
    void timer_dummy_handler(nrf_timer_event_t event_type, void * p_context){}
     void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
                           void *                    p_context)
        spi_xfer_done = true;
    //    NRF_LOG_INFO("Transfer completed.");
        if (m_rx_buf[0] != 0)
    //        NRF_LOG_INFO(" Received:");
            NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
     void led_blinking_setup()
        uint32_t compare_evt_addr;
        uint32_t gpiote_task_addr;
        nrf_ppi_channel_t ppi_channel;
        ret_code_t err_code;
        nrf_drv_gpiote_out_config_t config = GPIOTE_CONFIG_OUT_TASK_TOGGLE(false);
        err_code = nrf_drv_gpiote_out_init(GPIO_OUTPUT_PIN_NUMBER, &config);
        nrf_drv_timer_extended_compare(&timer, (nrf_timer_cc_channel_t)0, 251, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
        err_code = nrf_drv_ppi_channel_alloc(&ppi_channel);
        compare_evt_addr = nrf_drv_timer_event_address_get(&timer, NRF_TIMER_EVENT_COMPARE0);
        gpiote_task_addr = nrf_drv_gpiote_out_task_addr_get(GPIO_OUTPUT_PIN_NUMBER);
        err_code = nrf_drv_ppi_channel_assign(ppi_channel, compare_evt_addr, gpiote_task_addr);
        err_code = nrf_drv_ppi_channel_enable(ppi_channel);
        nrf_drv_gpiote_out_task_enable(GPIO_OUTPUT_PIN_NUMBER);
    void Frequency_init()
    //    err_code = nrf_drv_gpiote_init();
    //    APP_ERROR_CHECK(err_code);
        err_code = nrf_drv_timer_init(&timer, &timer_cfg, timer_dummy_handler);
    #ifdef NRF51
        //Workaround for PAN-73.
        *(uint32_t *)0x40008C0C = 1;
        // Setup PPI channel with event from TIMER compare and task GPIOTE pin toggle.
        led_blinking_setup();
        // Enable timer
        nrf_drv_timer_enable(&timer);
    static void timers_init(void)
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
     uint32_t led_to_invert = 1; //((i++) % LED_1);
            case BLE_GAP_EVT_CONNECTED:
    //					   bsp_board_led_invert(led_to_invert);
    //            NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
    //        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
        UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
        nrf_pwr_mgmt_run();
    /**@brief Application main function.
        bool erase_bonds;
        uart_init();
        log_init();
    	  timers_init();
    //  buttons_leds_init(&erase_bonds);
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        advertising_start();
        nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
        spi_config.ss_pin   = SPI_SS_PIN;
        spi_config.miso_pin = SPI_MISO_PIN;
        spi_config.mosi_pin = SPI_MOSI_PIN;
        spi_config.sck_pin  = SPI_SCK_PIN;
        spi_config.frequency = NRF_SPI_FREQ_125K;
        spi_config.mode = NRF_SPI_MODE_0;
        APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
        Frequency_init();
        for (;;)
    	      idle_state_handle();
    GPIOTE- 32.0KHz
    #include <stdint.h>
    #include "nrf.h"
    #include "boards.h"
    #ifdef BSP_LED_0
        #define GPIO_OUTPUT_PIN_NUMBER BSP_LED_0  /**< Pin number for output. */
    static void led_blinking_setup()
     * @brief Function for application main entry.
    #ifdef NRF51
        // Enable timer
        while (true)
            // Do Nothing - GPIO can be toggled without software intervention.
  • static nrf_drv_timer_t timer = NRF_DRV_TIMER_INSTANCE(0);
    TIMER0 is used by the SoftDevice, you need to use TIMER1 or above.
    See System On Chip Requirements: Hardware peripherals, from S132 spec.
  • Here is how you output exactly 32,768Hz.
    What do you need?
    1. LFCLK powered by a 32768Hz crystal.
    2. 1x TIMER, 1x RTC, 3x PPI channels. 1x GPIOTE channel
    How to configure the peripherals
    1. Configure a GPIOTE channel to drive the GPIO you want to output the clock to
    2. Configure a TIMER to count at 16MHz (PRESCALER = 0), in 16 bit timer mode
    3. Set CC[0] = 1 and CC[1] = 245. This will generate the 32,768 Hz with almost 50% duty cycle
    4. Use a PPI channel to connect the COMPARE[0] event to the GPIOTE->TASKS_SET
    5. Use a second PPI channel to connect the COMPARE[1] event to the GPIOTE->TASKS_CLR
    6. configure an RTC to generate the tick event (PRESCALER = 0)
    7. Use a third PPI channel to connect the RTC TICK event to the TIMER CLEAR task
    8. start the timer
    How it works?
    The timer will count at 16MHz (0.0625us per tick). When the timer reaches the value 1 it will set the output GPIO. When it reaches 245 (244 ticks later) it will clear the output GPIO. This will give a high pulse of 244 * 0.0625 = 15.25us which is roughly half of the 32,768Hz period (hence, close to 50% duty cycle).
    The timer will keep counting and would overflow if it reached 0xFFFF but it will never reach that value because the RTC will keep resetting it at the 32,768Hz frequency.
    Enjoy!
