HW: nrf52840
SW: nRF5_SDK_15.2.0_9412b96
I would like to learn how allocate Flash, RAM and SRAM setting and how do I find out the total RAM/ROM my application needed via Segger.
Q1:
There are something I dunno why, according to the nrf52840 datasheet the allocation should be as below.
FLASH_PH_START=0x0
FLASH_PH_SIZE=0x00800000
RAM_PH_START=0x20000000
RAM_PH_SIZE=0x20000000
FLASH_START=0x0
FLASH_SIZE=?? (how to check the flash size for my application using segger)
RAM_START=0x20000000
RAM_SIZE=??(how to check the RAM size for my application using segger)
Q2:
Those setting are so much different from the suggested setting I founded on nordic forum.
The example is as below.
FLASH_PH_START=0x0
FLASH_PH_SIZE=0x100000
RAM_PH_SIZE=0x40000
FLASH_START=0x26000 (may I know why flash start is 0x26000? Was it because of Softdevice firmware allocation?)
FLASH_SIZE=0xda000
RAM_START=0x200022e0 (may I know why the RAM_START start at 0x200022e0? which is extra 0x22e0 from the default RAM start which is at 0x20000000)
RAM_SIZE=0x3dd20
Q3:
And what is the different between the SRAM(0x20000000-0x40000000) vs RAM(0x60000000-0xA0000000) on the Memory map? when I allocate the RAM_PH and RAM_START should I use the SRAM or RAM?
