I use Eclipse, gcc and OS X to compile.
I had FW working just fine with SD 6 and SDK 5.2. I recently tried to upgrade and ran into many problems, but the latest is the worst. I am now using SDK 6.1 and SD 7.0, and I also tried SD 7.1 and saw the same issue.
I have a custom service that I use to send data to an Android app. The data is usually much more than 20 bytes, so I have a loop like this in the code:
for (int i = 0; i < len; i+=20) {
uint16_t size = (len-i > 20 ? 20 : len-i);
memcpy(buffer, data+i, size);
memset(¶ms, 0, sizeof(params));
params.type = BLE_GATT_HVX_NOTIFICATION;
params.handle = p_scs->data_up_handles.value_handle;
params.p_data = buffer;
params.p_len = &size;
int error = sd_ble_gatts_hvx(p_scs->conn_handle, ¶ms);
//when sending data very fast, we can use up all the buffers. this should protect us as we wait for the TX complete event
while (error == BLE_ERROR_NO_TX_BUFFERS) {
simple_uart_putstring("Hit a No Buffer error \n");
while (waitForTxComplete) {
nrf_delay_us(500000);
simple_uart_putstring("Still waiting \n");
waitForTxComplete = true;
simple_uart_putstring("Still getting an error sending \n");
simple_uart_putstring("Past it \n");
if (error != NRF_SUCCESS) {
simple_uart_putstring("Still caught an error transmitting \n");
if (error == BLE_ERROR_NO_TX_BUFFERS) {
simple_uart_putstring("It's a buffer error! \n");
return error;
Then I simply have a function in the class that listens for BLE events and does this on the event type:
case BLE_EVT_TX_COMPLETE:
simple_uart_putstring("Got an event telling us we are all clear \n");
waitForTxComplete = false;
This all worked fine with SD6, the event would come through after the TX was complete and the data would all go through. Now, I never see the BLE_EVT_TX_COMPLETE event, and so I get stuck in a loop waiting for the TX Buffers to clear. I output debug through UART and I can see the event never comes. It transmits 7 twenty packet payloads before it hits a BLE_ERROR_NO_TX_BUFFERS error, and then it just hangs forever in the loop.
I know the events are all working properly because I send data down to the nrf51822 first and that works just fine. So it seems the only issue is the BLE_EVT_TX_COMPLETE event isn't coming through anymore. I checked documentation on the latest SD7.1 version and I cannot find anything about this.
Is there an issue? Or did something change that I am not handling correctly anymore?
