Problem with provisioning after reset
Hi
We are able to provision several mesh-servers.
The log on the RTT-Viewer of the client looks normal:
 0> <t:     915394>, mesh.c,  178, Local provisioning link established
 0> <t:     916961>, mesh.c,  237, Using static authentication
 0> <t:     928785>, mesh.c,  248, Static authentication data provided
 0> <t:     939937>, mesh.c,  193, Provisioning complete! Added 01F4 as handle 1
 0> <t:     940270>, provisioner.c,  122, Getting composition data
 0> <t:     942757>, provisioner.c,  332, Composition data: 00590000000000200001000000030100000200040059000000
 0> <t:     942761>, provisioner.c,  130, Adding appkey
 0> <t:     943853>, mesh.c,  182, Local provisioning link closed
 0> <t:     946897>, provisioner.c,  139, Binding appkey to the Health model
 0> <t:     947742>, provisioner.c,  151, Binding appkey to the Simple message model
 0> <t:     949061>, provisioner.c,  176, Setting publication address for the health server to 0x0001
 0> <t:     952639>, provisioner.c,  198, Setting publication address for the message server to 0x0001
 0> <t:     957205>, provisioner.c,  207, Adding subscription
 0> <t:     958533>, mesh.c,  548, Configuration of device 0 successful
 0> <t:     958537>, mesh.c,  558, provisioner_config_successful_cb
When we reset (restart) the client(provisioner) board and then try to provision further servers we get
a Mesh assert.
 0> <t:     390869>, mesh.c,  178, Local provisioning link established
 0> <t:     392374>, mesh.c,  237, Using static authentication
 0> <t:     403809>, mesh.c,  248, Static authentication data provided
 0> <t:     415206>, mesh.c,  193, Provisioning complete! Added 01F5 as handle 2
 0> <t:     415540>, provisioner.c,  122, Getting composition data
 0> <t:     419283>, mesh.c,  182, Local provisioning link closed
 0> <t:     430889>, provisioner.c,  332, Composition data: 00590000000000200001000000030100000200040059000000
 0> <t:     430892>, provisioner.c,  130, Adding appkey
 0> <t:     434469>, provisioner.c,  139, Binding appkey to the Health model
 0> <t:     436060>, app_error_weak.c,   95, Mesh assert at 0x0003C562 (:0)
Addr2line leads to line 347 of provisioner.c:
    else if (p_event->opcode == CONFIG_OPCODE_MODEL_APP_STATUS &&
             m_prov_state == PROV_STATE_CONFIG_APPKEY_BIND_HEALTH)
>>>  NRF_MESH_ASSERT(p_event->p_msg->app_status.status == ACCESS_STATUS_SUCCESS);
        m_prov_state = PROV_STATE_CONFIG_APPKEY_BIND_ONOFF;
        do_config_step();
p_event->p_msg->app_status.status is ACCESS_STATUS_INVALID_ADDRESS instead of ACCESS_STATUS_SUCCESS
We are using Mesh_SDK 2.0.1 and nRF5_SDK_15.0.0 / Softdevice 6.0.0.
Question: What could lead to this invalid address state?.
Kind regards
Gerry
    I was not able to find provisioner.c, nor the line with the assert, in nRF5 SDK for Mesh v2.0.1... Did you mean provisioning.c, and can you recheck and confirm the nRF5 SDK for Mesh version?
    Crashing is "normal behavior" if you flash the mesh application without erasing flash first. This is because anything in the flash area designated for storing provisioning data, device status, etc. may be interpreted wrongly leading to undefined behavior or error in parsing the data.
    How are you resetting the client/provisioner board, what are the steps for reproducing?
    Terje
    attached the file provisioner.c. The nRF5 SDK Version was correct.
    By reset (restart) I mean pressing the reset button on the nRF52840 DK
    regards
    Gerry
    /* Copyright (c) 2010 - 2017, Nordic Semiconductor ASA
     * All rights reserved.
     * list of conditions and the following disclaimer.
    #include "provisioner.h"
    #include <stdint.h>
    #include <stdbool.h>
    #include <string.h>
    #include "log.h"
    #include "nrf_mesh_assert.h"
    #include "nrf_mesh_prov.h"
    #include "nrf_mesh_prov_bearer_adv.h"
    #include "nrf_mesh_events.h"
    #include "device_state_manager.h"
    #include "config_client.h"
    #include "access_config.h"
    #include "simple_message_server.h" // changed by BK
    #include "health_common.h"
    #include "mesh_app_utils.h"
    #include "nrf_mesh.h"
    #include "flash.h"
    // HOT: weil das einbinden von mesh.h Probleme verursacht:
    /* start provisioning of one node */
    extern void start_provisioning(const uint8_t * p_uuid, nrf_mesh_prov_bearer_type_t bearer_type);
    typedef enum
        PROV_STATE_IDLE,
        PROV_STATE_WAIT,
        PROV_STATE_PROV,
        PROV_STATE_CONFIG_FIRST,
        PROV_STATE_CONFIG_COMPOSITION_GET,
        PROV_STATE_CONFIG_APPKEY_ADD,
        PROV_STATE_CONFIG_APPKEY_BIND_HEALTH,
        PROV_STATE_CONFIG_APPKEY_BIND_ONOFF,
        PROV_STATE_CONFIG_PUBLICATION_HEALTH,
        PROV_STATE_CONFIG_PUBLICATION_ONOFF,
        PROV_STATE_CONFIG_SUBSCRIPTION
    } prov_state_t;
    /* Provisioning encryption key storage (this is not how you should store your keys). */
    static uint8_t m_public_key[NRF_MESH_PROV_PUBKEY_SIZE];
    static uint8_t m_private_key[NRF_MESH_PROV_PRIVKEY_SIZE];
    static nrf_mesh_prov_bearer_adv_t m_prov_bearer_adv;
    static nrf_mesh_prov_ctx_t m_prov_ctx;
    static prov_state_t m_prov_state;
    static uint16_t m_target_address;
    /*static void start_provisioning(const uint8_t * p_uuid)
        nrf_mesh_prov_provisioning_data_t prov_data =
                //.netkey = NETKEY,
                .netkey_index = NETKEY_INDEX,
                .iv_index = 0,
                .address = m_target_address,
                .flags.iv_update = false,
                .flags.key_refresh = false
            for (uint8_t i = 0; i < 16; ++i) {
              prov_data.netkey[i] = m_cfg_.network_key[i];
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "start_provisioning provisioner\n");
        ERROR_CHECK(nrf_mesh_prov_provision(&m_prov_ctx, p_uuid, &prov_data, NRF_MESH_PROV_BEARER_ADV));
        m_prov_state = PROV_STATE_PROV;
    static void do_config_step(void)
        switch (m_prov_state)
            case PROV_STATE_CONFIG_FIRST:
                m_prov_state = PROV_STATE_CONFIG_COMPOSITION_GET;
                /* fall through */
            /* Read the composition data from the node: */
            case PROV_STATE_CONFIG_COMPOSITION_GET:
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Getting composition data\n");
                ERROR_CHECK(config_client_composition_data_get(0));
            /* Add the application key to the node: */
            case PROV_STATE_CONFIG_APPKEY_ADD:
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Adding appkey\n");
                uint8_t appkey[NRF_MESH_KEY_SIZE] = APPKEY;
                ERROR_CHECK(config_client_appkey_add(NETKEY_INDEX, APPKEY_INDEX, appkey));
            /* Bind the health server to the application key: */
            case PROV_STATE_CONFIG_APPKEY_BIND_HEALTH:
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Binding appkey to the Health model\n");
                access_model_id_t model_id;
                model_id.company_id = ACCESS_COMPANY_ID_NONE;
                model_id.model_id = HEALTH_SERVER_MODEL_ID;
                uint16_t element_address = m_target_address;
                ERROR_CHECK(config_client_model_app_bind(element_address, APPKEY_INDEX, model_id));
            /* Bind the On/Off server to the application key: */
            case PROV_STATE_CONFIG_APPKEY_BIND_ONOFF:
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Binding appkey to the Simple message model\n");
                model_id.company_id = ACCESS_COMPANY_ID_NORDIC;
                model_id.model_id = simple_message_SERVER_MODEL_ID; // changed by BK
            /* Configure the publication parameters for the On/Off server: */
            case PROV_STATE_CONFIG_PUBLICATION_HEALTH:
                config_publication_state_t pubstate = {0};
                pubstate.element_address = m_target_address;
                pubstate.publish_address.type = NRF_MESH_ADDRESS_TYPE_UNICAST;
                pubstate.publish_address.value = PROVISIONER_ADDRESS;
                pubstate.appkey_index = 0;
                pubstate.frendship_credential_flag = false;
                pubstate.publish_ttl = SERVER_COUNT;
                pubstate.publish_period.step_num = 1;
                pubstate.publish_period.step_res = ACCESS_PUBLISH_RESOLUTION_10S;
                pubstate.retransmit_count = 1;
                pubstate.retransmit_interval = 0;
                pubstate.model_id.company_id = ACCESS_COMPANY_ID_NONE;
                pubstate.model_id.model_id = HEALTH_SERVER_MODEL_ID;
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Setting publication address for the health server to 0x%04x\n", pubstate.publish_address.value);
                ERROR_CHECK(config_client_model_publication_set(&pubstate));
            case PROV_STATE_CONFIG_PUBLICATION_ONOFF:
                pubstate.publish_address.value = PROVISIONER_ADDRESS + m_target_address - m_cfg_.start_address;
                pubstate.publish_period.step_num = 0;
                pubstate.publish_period.step_res = ACCESS_PUBLISH_RESOLUTION_100MS;
                pubstate.model_id.company_id = ACCESS_COMPANY_ID_NORDIC;
                pubstate.model_id.model_id = simple_message_SERVER_MODEL_ID; // changed by BK
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Setting publication address for the message server to 0x%04x\n", pubstate.publish_address.value);
            /* Add a subscription to the group address to the node: */
            case PROV_STATE_CONFIG_SUBSCRIPTION:
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Adding subscription\n");
                nrf_mesh_address_t address = {NRF_MESH_ADDRESS_TYPE_INVALID, 0, NULL};
                address.type = NRF_MESH_ADDRESS_TYPE_GROUP;
                address.value = GROUP_ADDRESS;
                ERROR_CHECK(config_client_model_subscription_add(element_address, address, model_id));
                NRF_MESH_ASSERT(false);
    static void prov_evt_handler(const nrf_mesh_prov_evt_t * p_evt)
        switch (p_evt->type)
            case NRF_MESH_PROV_EVT_UNPROVISIONED_RECEIVED:
                if (m_prov_state == PROV_STATE_WAIT)
                    //if (is_provisioning_active())
                            start_provisioning(p_evt->params.unprov.device_uuid, NRF_MESH_PROV_BEARER_ADV);
                      //  else
                      //      __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Blocked UUID:%u\n",p_evt->params.unprov.device_uuid);
            case NRF_MESH_PROV_EVT_LINK_CLOSED:
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Local provisioning link closed\n");
                if (m_prov_state == PROV_STATE_PROV)
                    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Provisioning failed. Retrying...\n");
                    m_prov_state = PROV_STATE_WAIT;
                else if (m_prov_state == PROV_STATE_CONFIG_FIRST)
                    do_config_step();
            case NRF_MESH_PROV_EVT_COMPLETE:
                m_prov_state = PROV_STATE_IDLE;
                provisioner_prov_complete_cb(&p_evt->params.complete);
            case NRF_MESH_PROV_EVT_CAPS_RECEIVED:
                uint32_t status = nrf_mesh_prov_oob_use(p_evt->params.oob_caps_received.p_context,
                                                        NRF_MESH_PROV_OOB_METHOD_STATIC,
                                                        0,
                                                        NRF_MESH_KEY_SIZE);
                if (status != NRF_SUCCESS)
                    __LOG(LOG_SRC_APP, LOG_LEVEL_ERROR,
                          "Provisioning OOB selection rejected, error code %d. Retrying...\n", status);
                    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Using static authentication\n");
            case NRF_MESH_PROV_EVT_STATIC_REQUEST:
                uint8_t static_data[16] = STATIC_AUTH_DATA;
                ERROR_CHECK(nrf_mesh_prov_auth_data_provide(p_evt->params.static_request.p_context, static_data, 16));
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Static authentication data provided\n");
            case NRF_MESH_PROV_EVT_LINK_ESTABLISHED:
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Local provisioning link established\n");
    void provisioner_configure(uint16_t address)
        m_target_address = address;
            /* Wait for the NRF_MESH_PROV_EVT_LINK_CLOSED event. */
            m_prov_state = PROV_STATE_CONFIG_FIRST;
            do_config_step();
    void provisioner_wait_for_unprov(uint16_t address)
    void config_client_event_cb(config_client_event_type_t event_type, const config_client_event_t * p_event, uint16_t length)
        if (event_type == CONFIG_CLIENT_EVENT_TYPE_TIMEOUT)
            provisioner_config_failed_cb();
            return;
        NRF_MESH_ASSERT(p_event != NULL);
        if (p_event->opcode == CONFIG_OPCODE_COMPOSITION_DATA_STATUS &&
            m_prov_state == PROV_STATE_CONFIG_COMPOSITION_GET)
            __LOG_XB(LOG_SRC_APP, LOG_LEVEL_INFO, "Composition data", ((const uint8_t *) &p_event->p_msg->composition_data_status), length);
            m_prov_state = PROV_STATE_CONFIG_APPKEY_ADD;
            do_config_step();
        else if (p_event->opcode == CONFIG_OPCODE_APPKEY_STATUS &&
                 m_prov_state == PROV_STATE_CONFIG_APPKEY_ADD)
            NRF_MESH_ASSERT(p_event->p_msg->appkey_status.status == ACCESS_STATUS_SUCCESS ||
                            p_event->p_msg->appkey_status.status == ACCESS_STATUS_KEY_INDEX_ALREADY_STORED);
            m_prov_state = PROV_STATE_CONFIG_APPKEY_BIND_HEALTH;
            do_config_step();
            do_config_step();
                 m_prov_state == PROV_STATE_CONFIG_APPKEY_BIND_ONOFF)
            m_prov_state = PROV_STATE_CONFIG_PUBLICATION_HEALTH;
            do_config_step();
        else if (p_event->opcode == CONFIG_OPCODE_MODEL_PUBLICATION_STATUS &&
                 m_prov_state == PROV_STATE_CONFIG_PUBLICATION_HEALTH)
            NRF_MESH_ASSERT(p_event->p_msg->publication_status.status == ACCESS_STATUS_SUCCESS);
            m_prov_state = PROV_STATE_CONFIG_PUBLICATION_ONOFF;
            do_config_step();
                 m_prov_state == PROV_STATE_CONFIG_PUBLICATION_ONOFF)
            m_prov_state = PROV_STATE_CONFIG_SUBSCRIPTION;
            do_config_step();
        else if (p_event->opcode == CONFIG_OPCODE_MODEL_SUBSCRIPTION_STATUS &&
                 m_prov_state == PROV_STATE_CONFIG_SUBSCRIPTION)
            NRF_MESH_ASSERT(p_event->p_msg->subscription_status.status == ACCESS_STATUS_SUCCESS);
            provisioner_config_successful_cb();
            /* Do nothing. */
    void provisioner_init(void)
        nrf_mesh_prov_oob_caps_t capabilities = NRF_MESH_PROV_OOB_CAPS_DEFAULT(ACCESS_ELEMENT_COUNT);
        ERROR_CHECK(nrf_mesh_prov_generate_keys(m_public_key, m_private_key));
        ERROR_CHECK(nrf_mesh_prov_init(&m_prov_ctx, m_public_key, m_private_key, &capabilities, prov_evt_handler));
        ERROR_CHECK(nrf_mesh_prov_bearer_add(&m_prov_ctx, nrf_mesh_prov_bearer_adv_interface_get(&m_prov_bearer_adv)));
        ERROR_CHECK(nrf_mesh_prov_scan_start(prov_evt_handler));
    I found this file now in the combined client+provisioner example from nRF5 SDK for Mesh v1.0.1. Have you ported this project over to nRF5 SDK for Mesh v2.0.1, from that older version?
    Terje
    yes, we started with mesh v1.0.1 and the updated to Mesh 2.0.1. Is there a Problem with that? We didn't make changes tp provisioner.c and the application is runnig fine accept the issue above.
    Regards
    Gerry
    It should not be a problem in and of itself that the example is ported, but it means now I better know the context of what you are doing.
    It seems to be related to the addresses stored by the device state manager (dsm). I would guess that the error of NRF_ERROR_INVALID_ADDR originated in packet_tx() in access.c, because of a mismatch between the addresses stored by the dsm and the index information stored in the model. A bit hard to tell for sure, of course, since the project is ported and things may have changed throughout the SDK revisions.
    In any case, while the dsm automatically stores changes to flash, this is not necessarily done for the data used by the access module (in access.c). Hence the function access_flash_config_store(). Further, if at the point of reset, either the dsm or access has stored data to flash, but the other has not, the data will be in an inconsistent state comparable to a dangling pointer, leading to the kind of error that you experience.
    I am afraid these things are complex, and I do not have enough time to properly get to the bottom of it before the holidays, but I know that this is an area where our mesh team want to improve the SDK. From what I understand they have done some work on that for later releases. It may even be that those improvements are what effectively renders the ported example prone to inconsistency if resetting the (combined client and) provisioner halfway through the provisioning steps.
    Hopefully I have at least provided some pointers to where to look. If anything is unclear, let me know and I will try to elaborate.
    Terje
