Trying to get AT Command example to compile from Fanstel
So I am brand new at this product line, and basically new at C in general, I come from VB land. So bare with me please
I purchased both a Nordic nrf52 dev kit evaluation board, as well as a Fanstel BT832XE mainly for its long range with its built-in amplifier IC. the link to get the AT commands project + SDK they have posted, is here: www.dropbox.com/.../nRF5_SDK_14.rar
the folder is in the examples directory, and has hc-05 or hc-08, something like that.
So I am running into a plethora of issues. They posted their example AT command codes on their website under SDK 14. However that is all setup for IAR and I have the free Segger studio installed. I tried to use the existing project folder and did an import with Segger, I ran into problem after problem .So I gave up there. Most of their documentation was written for nRFGo studio which I cannot find anymore. probably discontinued?
So after giving up importing the project, I attempted to "template" it into a working project, so I downloaded SDK 15 at first from Nordic, and I copied the C file from the AT commands example and it wont compile, too many errors because of SDK changes I suppose.
I rolled back to SDK 14.2, took the uart example, copied and again overwrote the main.c file from the AT commands example, it builds all the way up to this point:
Output/ble_serial_pca10040_s132 Debug/Obj/main.o: In function `fds_test_init':
undefined reference to `fds_register'
and on and on it goes with a whole bunch of fds stuff being undefined which makes no sense to me.
But, fds.h include is present! I also checked and made sure FDS was turned on in the sdk_config.h file. Made no difference. Tried clean, tried rebuild, tried build, it gives me the same error under all tries.
So I am at a complete loss, I cant figure it out. The ultimate end-game here is to make some changes to the example program so I can "log-in" to the module before it allows sending/receiving between the UART and the BLE. Right now its configured open relay, anyone can connect and send/receive. I dont like that.
